Got an EML & ASC Light + Limp mode? Fix to the TPS sensor (+pics) - Page 2 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
///M3 Forum
Thread Tools Search this Thread Rating: Thread Rating: 12 votes, 5.00 average. Display Modes
Old 10-09-2012, 10:13 AM   #21
illestminimike
My Ride: Project Drama
Bump tryna do this today.
Old 12-23-2012, 11:20 AM   #22
Chaz.T
My Ride: '03 SC'd M3
Originally Posted by kevro View Post
Next, was the gas pedal TPS sensor. There are six leads and to be honest, I don't remember which ones I used, but along the first row of three pins, try two of those and if it reads 0, try the other two. Same with the second row of pins.
I was hoping to re-address this, I have tested my tps from the front of the motor and found it to be good.
The pedal has 6 pins kinda like this
1 2 3
if i connect pins 1 and 2 i get zero reading
if i connet pins 2 and 3 i get a reading of .48 ohms.
however it does not change at all when the gas pedal is pressed/depressed
I have two gas pedals and both of them respond the exact same way.
when checking pins on top row, assuming the same numbers, same thing on both pedals.
I really feel like I am doing it wrong. If there was no change at all, the car wouldn't have moved at all.
I assume when you tested you separated the top row from the bottom row? I have read there are actually two tps built into one sensor to give the cpu a better idea of actual readings vs bad readings?
the tps from the front of the motor tested EXACTLY as you described above and smoothly throughout the range.
Any help would be greatly appreciated
I am having a similar issue. I have checked all combinations of pins and either get an open circuit, 461 omhs or 58 ohms. And as with kevro, when the pedal is pressed i get no change in resistance... Anyone else have better luck? Or is my pedal just junk?
Chaz.T is offline   Reply With Quote
Old 01-18-2013, 02:04 AM   #23
a4x4iwi
My Ride: E30
It looks like they use Hall sensors, not potentiometers.
These are a non contact mechanism using a magnet and a sensor that detect magnetic field. They offer high reliability.
See http://www.ge39.com/files/m54x5.pdf
Testing would need to be with the ignition in the run position using a volt meter.
Page 11_nr_
a4x4iwi is offline   Reply With Quote
Old 08-10-2013, 11:45 AM   #24
striker66
My Ride: 2001 M3 Convertible
Sensor can be tested while REMOVED from vehicle
This thread was helpful to me, but it was apparent from reading that there is some confusion about how to test the throttle postion sensor, namely whether it should be done in the vehicle or with the device removed.
This morning I removed the sensor which is located immediately next to the oil filter cap. I can echo a previous poster's comments that you need to use proper tools here. The two phillips headed screws which attach the sensor are not hardened and unless you have a tool which properly fits the screw heads you run a serious risk of stripping them. I used a right angled socket set with a very short philips driver in it, but even with this I found that I couldn't put enough sideways pressure on the lower screw to avoid some obvious slipping of the driver. I stopped, pondered for a moment how to proceed and eventually found that a large crowbar with the flat end turned sideways gave me a perfect lever to wedge against the engine hoist loop (I think that's what it was anyway) and the backside of my socket driver. With alot of force pushing the driver into the head I was just barely able to break the screw loose and it started turning.
Enough of the warnings ;-) The purpose of my post is to make clear to future readers that this particular sensor is essentially a variable resistor and should be tested outside of the vehicle with a multimeter set to resistance readings. I found it tricky to get the multimeter clips attached to the sensor connector because the tabs are recessed. I ended up modifying some crimp-style electrical connectors which have male and female sides. I cut the female side in half and then was able to slip it over a tab and effectively extend it so that it was easy to attach. After doing this on both tabs (I used an outside and the center tab) and then putting a wide flathead screwdriver into the rotating socket, I was able to (unfortunately) observe resistance changing from about 1.1 ohms up to about 4.9 ohms ( approximately, I didn't write these down) with no glitches. Of course this test isn't perfect, but it convinced me sufficiently that this sensor is likely working as designed.
Now I'm off to search for how to locate the next most likely sensor, either the one on the pedal or the one under the intake manifold!
striker66 is offline   Reply With Quote
Old 08-29-2013, 11:14 PM   #25
fayraree
flock killer
fayraree's Avatar
My Ride: 04 M3 vert
thanks for all the info on this thread and for ^^ your update with the warnings and attempt to measure the sensor with the multimeter. I want to DIY this and I think I'll just be replacing the sensor without the test. I'm about to head out on a 500 mile road trip, my code scanner said sensor "A" so I have no clue which sensor that refers to (code P0121). If there's a way to use my OBD2 scanner with some software on my laptop to diagnose the issue without a multimeter, etc. that would be awesome.
It'll be hard to get at the other two sensors, and I already have the TPS part from Tischer so I'm thinking I'll just replace the one next to the oil filter and hope for the best, lol.
fayraree is offline   Reply With Quote
Old 09-30-2013, 06:55 PM   #26
woahwoah
My Ride: 2002 330ci
oops....
so when I was taking off the tps sensor next to the oil filter housing I pulled off the tps sensor and the ring fell off and fell into the engine compartment and I cant find it..... I called my local bmw dealership and they cant find the part that i'm talking about and its not on the diagram : ( anybody know the part number for that or am I s.o.l.???
woahwoah is offline   Reply With Quote
Old 10-15-2013, 04:42 PM   #27
meccanoble
My Ride: 03 Steel Gray M3
Send a message via AIM to meccanoble Send a message via Yahoo to meccanoble
This was very helpful. I tested perfectly and did not strip the bolt thankfully! But my measurements did not jump. They were pretty consistent with no dead spots but the range was from 0.92 - 5.48. Would this mean the TPS is bad? I have similar symptoms as others. Go into limp mode ever so often. I'm going after the pedal next but still have to confirm best way to test.
///M3CCANOBLE
03 Steel Grey 6MT :shiftdriv
Volks TE37| Eisenmann Race 83mm + section II| RE Rasp Pipe| Vogtland Springs| Kenwood KDC X994| Poly RTABS| many more...
meccanoble is offline   Reply With Quote
Old 01-25-2014, 12:06 PM   #28
dbrumfield
My Ride: 2005 M3 Coupe
P0121/p0221
Similar issues. Ist got P1637 Throttle Valve Position Control - Control Deviation; checked TPS at oil filter - ohms right, smooth range & no spikes. Now getting P0121 & P0221, which spell out Throttle/Pedal Position Sensor A (& B) Circuit Range/Perfprmance. Will try to remove pedal & check resistance. Questions: (1) Do these 2 codes point only to accelerator pedal as it reads like they do? (2) Threads unclear on how to check out the pedal - guidance on doing so? Also, if problem were the throttle actuator sensor (under intake manifold), is that a different code? What is it? Thx.
dbrumfield is offline   Reply With Quote
Old 03-14-2014, 01:52 AM   #29
m3-4aj
My Ride: E46 M3 / F80-M3
Send a message via AIM to m3-4aj
can someone provide the part # for the Gas pedal sensor?
m3-4aj is offline   Reply With Quote
Old 03-17-2014, 09:23 PM   #30
dbrumfield
Gas pedal part # 35426786282, $114.34 online from getbmwparts.com. BTW, I also changed throttle valve switch (position sensor) at oil filter, 13637840383, $80.98, & it took care of the problem. No more limp mode!! I just wanted it fixed & I don't know which one fixed it, but preferred to try the 2 easier ones at once. Also, I broke the white plastic holder for the gas pedal & had to drill & screw it down. Good luck!
Old 07-21-2014, 01:23 PM   #31
KSK
My Ride: //M
BUMP!
I checked the pedal sensor and getting reading of ZERO ohms with no change as the pedal is pressed. Is this a sure sign the pedal needs to be changed? I ordered a new one regardless but curious since my problems only occur when the engine is hot (ie. after 20mins of driving)
KSK is offline   Reply With Quote
Old 08-31-2016, 09:22 AM   #32
psmura
My Ride: 98 M3/86 535i
Wanted to give an update on this issue for people searching for an answer. I was getting the dreaded EML light and then the DSC and limp mode as time went on. I started by replacing the TPS at the oil filter and that didn't fix my problem. I then replaced the gas pedal and still no fix. From my research it appears that most people get lucky and their problem goes away.
I then decided to replace the sensor under the intake. BAM!! problem fixed.
Everyone seems to think that this is a huge undertaking but really its not too bad. Take your time and make sure you disconnect everything from the intake box. There is a small connector in the far left corner of the box, make sure you don't break this.
Also, set aside time to clean the entire air box, and also the throttle bodies. I also found that it is a good idea to use a wax based lube (chain lube) on the throttle body springs.
I didn't find much information on the sensor under the intake. From my experience I would say to just spend the $200 and do all sensors at one time. Hope this can help somebody in the future.
psmura is offline   Reply With Quote
Old 03-15-2017, 09:00 AM   #33
Tcleaver
My Ride: 2003 325i
Found this post on the google machine, been having this same issue with my 03, cant wait to get off work and see if i cant recreate this lol. Limp mode not only hurts my pride, its dangerous on the highway.
Tcleaver is offline   Reply With Quote
