Old 10-30-2008, 03:42 PM   #1
AntB
My Ride: MTA :(
RPM Jump
I noticed this a while ago, it doesn't happen often, but when it does it's very strange.
It sometimes happens in stop and go traffic, when I'm shifting between first and neutral a lot. Lets say I get into 1st to move my car and just as my car starts moving the person in front of me brakes and I have to pop back into neutral. At this point my RPMs would start jumping up and down between idle (600 or so) and about 1200. It would stop on its own after a couple of jumps or if I give it a little bit of gas.
Is this my idle control valve or what?
** Tim330i waz hur **
AntB is offline   Reply With Quote
Old 10-30-2008, 04:12 PM   #2
Ervin87
My Ride: E92 M3 | S4 | E30
Send a message via AIM to Ervin87
Could be a vacuum leak somewhere.
EUROPROJEKTZ - NorCal Chapter
Ervin (Bay Area Detailer)
Ervin87 is offline   Reply With Quote
Old 11-03-2008, 12:04 PM   #3
AntB
My Ride: MTA :(
No one else has heard of this?
Old 11-07-2008, 07:10 PM   #4
blingman
My Ride: 01 330ci manual
same thing happens to me, but usually only when i shift from 5th to neutral could would stall. all the other gears tend to idle fine. i removed and cleaned my icv and disa and maf and that didnt help. i'm going to remove the intake and hose and continue looking for the vacuum leak as most suggested.
blingman is offline   Reply With Quote
Old 11-10-2008, 11:42 AM   #5
AntB
My Ride: MTA :(
I have a whistle under light acceleration, but I always attributed it to my K&N intake. Maybe it's a vacuum leak somewhere? Going to have my shop check everywhere anyway when I do Inspection 2, so I guess it can wait.
Old 11-10-2008, 11:46 AM   #6
pMak26
My Ride: '99 M3, '07 r6
I know exactly what your talking about, mine does this as well. I will be doing the VANOS seals hopefully sometimes this month hoping it will cure this issue as well.
Will double check for vaccuum leak, but I doubt it is this as there are no other vaccuum leak syptoms
pMak26 is offline   Reply With Quote
Old 11-10-2008, 12:38 PM   #7
Bimmerguy82
My Ride: 2004 ZHP 6 SPD
If I can remember correctly, the rpm jump and whistle noise could very well be a bad DISA valve.
BMWCCA member #407674
___________
-Joshua
ZHPMafia.com member
Ebay headers | 3.38 diff | 2.5" cat-less exhaust | K&N intake | AA stage 1 software | UUC stage 1 light flywheel and clutch | UUC Evo 3 ssk
Bimmerguy82 is offline   Reply With Quote
Old 11-10-2008, 03:44 PM   #8
AntB
My Ride: MTA :(
I also get occasional stalls from a stop... Letting go of clutch, giving a little bit of gas and very occasionally it might stall.
Old 11-10-2008, 04:36 PM   #9
Jason@Euro-Division
Past Site Sponsor
My Ride: e46
I had the same problem.
Turned out my lower intake boot was disconnected/not tightened when I replaced the part.
Check to see if you have cracks in any part of the intake hoses.
Jason@Euro-Division is offline   Reply With Quote
rpm jump, stall, vacuum leak
