Old 10-30-2008, 06:30 PM   #1
GRIFFIN
NWS
GRIFFIN's Avatar
My Ride: fast
The xenon bright on passenger side is not working
Here is my problem. I had a stray blown tire piece hit my car awhile back on I-5. It hit my passenger side foglight, and busted it up so I had to replace it. But ever since then, the bright from my xenon bulb doesn't turn on( on passenger side) . When I pull the turn signal towards me, the middle brights(non xenon) light up. But when I move the turn signal towards the dash, only the driver side xenon bright lights up. My regular low beams work fine on both sides. does anyone have any ideas how to fix, besides replacing the bulb? Is there a possible connection that came undone? I have not tried to switch the bulb yet, to see if that would narrow it down. Does the xenon bulb have a high filament and a low filament? Any help would be appreciated. The light picutures are with brights on.
ID:	289992   Click image for larger version
ID:	290002   Click image for larger version
ID:	290003   Click image for larger version
Old 10-30-2008, 11:54 PM   #2
kmazz
NEPA crew
My Ride: 323ci
I may be wrong but I believe the bixenons are shutter based. So when you flip on the highs it opens a shutter inside of the projector to enable to high function. Check to make sure that motor is still working and nothing is broken inside of the projector.
kmazz is offline   Reply With Quote
Old 10-31-2008, 09:55 AM   #3
GRIFFIN
NWS
GRIFFIN's Avatar
My Ride: fast
Where is the projector located? Is it in the bulb?
Old 10-31-2008, 11:32 AM   #4
kmazz
NEPA crew
My Ride: 323ci
No the projector is the lens/bucket the bulb is put into. If you loon at the front of your headlight the project is the item that has a round glass lens on the front.
I took this photo from ebay but the flap that may be broken you can see on the right projector. It has the motor connected to it.
Old 10-31-2008, 11:46 AM   #5
GRIFFIN
NWS
GRIFFIN's Avatar
My Ride: fast
So, let's say the flap on the projector is broken... Do I need to replace the whole headlight or just the motor and flap? And is it an easy DIY or should I go to the stealership? Is there anything I should look for to know if it is broken?(a test). when that piece of ttire hit my car it hit the passenger fog lamp area. So I was think maybe something was jarred loose. A connector or wire.
Old 10-31-2008, 01:01 PM   #6
kmazz
NEPA crew
My Ride: 323ci
Well if you take apart your headlight you can plug the projector back in and test it by having someone tap the highbeams. If you want to check if any wires are loose There should be a HID(red/black) plug for your lows/highs, a black plug for your day time running/flash to pass lights, and two smaller plugs in the headlights one for the auto leveling and one for the HID shutter. From there you can find out which parts are broken if any. If anything is broken you can pick up a projector off ebay cheap and just swap the part out yourself.
Old 10-31-2008, 01:17 PM   #7
GRIFFIN
NWS
GRIFFIN's Avatar
My Ride: fast
can I find the motor and flap on ebay? The projector is the housing for the bulb, so it has no part in what turns on the light. So I need to inspect the motor, flap, and connector? Is the correct?
Old 11-01-2008, 03:58 PM   #8
kmazz
NEPA crew
My Ride: 323ci
Yes those are the items you'll need to check. Im not sure if just the shutter and motor are sold alone but an entire projector is fairly cheap so you can just replace the entire unit.
