Old 11-01-2008, 09:32 PM   #1
Newanda
My Ride: 2000 323i
150K - what do I need to do?
I'm fast approaching 150K and I'm a novice in repairs. I replaced my rear springs today (broke the endlink in the process, but learned a lot), but aside from that, I haven't done anything more than change the oil or the air filter. What should I do? Do I bring in to the dealer and get cleaned out, or are there things I can/should do myself???
Newanda is offline   Reply With Quote
Old 11-01-2008, 09:41 PM   #2
328iBMW
My Ride: C320
belt and coolant system (2 hoses, expansion tank, part that holds the expansion tank, thermostat, water pump)
power steering fluid (cheap and easy)
transmission fluid
differential fluid
shocks/struts, front control arms and bushings, sway bar end links
Please let us know if you need more.
What makes you come alive?.........Go do it.
328iBMW is offline   Reply With Quote
Old 11-01-2008, 09:50 PM   #3
ABIe46
My Ride: e46
buy a new car
ABIe46 is offline   Reply With Quote
Old 11-01-2008, 09:52 PM   #4
vminev
My Ride: 325ci
Search "Kpeng" and his maintenance guide... he has everything covered...
vminev is offline   Reply With Quote
Old 11-01-2008, 09:54 PM   #5
328iBMW
My Ride: C320
Originally Posted by ABIe46 View Post
buy a new car
He's okay.
You don't want to do everything at once. But do the coolant system one day. The next month, do the transmission fluid and diff. A couple of months later do the suspension, etc.
But if you pay someone else to do it, then yes, buy a new car.
Have fun!
Old 11-02-2008, 08:15 AM   #6
Newanda
My Ride: 2000 323i
Originally Posted by 328iBMW View Post
He's okay.
Have fun!
The car is actually running fine, which I guess is surprising for 150K! You think these are all things somebody who hasn't done a lot of DIY can handle?
And you think the coolant should come first?
Many thanks!!
Old 11-03-2008, 07:01 PM   #7
chrisca70
My Ride: The Wayward Wagon
You can make it! I always tell my friends it's like a Lego for real men, hahah
Just do your homework, buy parts online, have your tools, get your bentley manual, and online DIYs. You will save a ton of money and you will learn a lot! I found working on my car pretty rewarding...
chrisca70 is offline   Reply With Quote
