Thread Tools Search this Thread Rating: Thread Rating: 14 votes, 5.00 average. Display Modes
Old 12-13-2009, 01:00 PM   #101
Glenn 328is
My Ride: 98 328is, 04 320i
12-81-0-304-879
I don't mind helping you out, but please don't be so lazy. Read the thread. All the info is there.
Originally Posted by phelix View Post
anybody have a BMW part number?
Glenn 328is is offline   Reply With Quote
Old 12-13-2009, 02:45 PM   #102
phelix
My Ride: 328i
Originally Posted by Glenn 328is View Post
12-81-0-304-879
You have my thanks and my apologies - believe it or not I did scan all 5 pages but ignored the pics and looked for a sequence of numbers that resembled a BMW part number. Forest and trees?!
phelix is offline   Reply With Quote
Old 06-22-2011, 04:22 PM   #103
rollin in beaumont
My Ride: 2005 325xi
Red face hey dreamliner, still got any of that paste left?
Originally Posted by Dreamliner330 View Post
Anybody know where to get THERMAL HEAT PASTE???????
rollin in beaumont is offline   Reply With Quote
Old 09-28-2011, 10:45 AM   #104
MrGone
My Ride: 2003 325xi
I ordered one through a dealer in Canada, they recommended using DOW Corning 340 compound, I ordered a tube off eBay for $26.
MrGone is offline   Reply With Quote
Old 01-18-2012, 05:56 PM   #105
FoxholeAtheist
My Ride: 1999 328i
I just got the block heater, plan on installing it tomorrow evening. (Got mine at Calgary BMW: $93.50 and they had 12 in stock)
The guys back in the shop where I work had some Dow Corning 340 Heat Sink Compound, so I didn't have to source that. If you DO have to source it, Acklands Granger sells it for ~$70 for a 142g tube.
Block heater kit: P/N 12-81-0-304-879
Kit includes the following:
Block heater itself: 88-41-0-000-009
Cordset with integrated fuse: 88-41-0-000-010
2 M8 x 25 bolts with washers
5 tie wraps
Instruction sheet (which is not nearly as good as the DIY guide here)
They specify that you can use the BMW silicone heat paste, p/n "99 00 9 100 340 142", which is apparently enough to do 14 cars. (10g/car, according to instructions) It strikes me that the "340" in that number is the same as the Dow Corning heat paste number. Considering that 142g is the same size tube that Acklands sells the 340 in, I suspect that it's the exact same stuff.
Hope this helps someone.
Edited to add: I called the dealer up asking about the part number the instruction sheet lists for the BMW heat paste, and he says it's not something they stock on the parts counter. (Most people get the heaters installed instead of DIY.) FYI
FoxholeAtheist is offline   Reply With Quote
Old 01-18-2012, 06:02 PM   #106
jabela
My Ride: 2002 325ci
Here's another alternative.
Proheat Heavy Duty Fluid Reservoir Heater Model 512csa (250 Watts, 2.1 Amp, 120 Volts)
http://www.amazon.com/gp/product/B00...00_i00_details
I bought one, but I haven't installed it yet. I'm waiting for a warmer day to do it and my FCABs.
2002 BMW 325ci /// Sport Pkg /// 5 spd
Modern Apothecary
jabela is offline   Reply With Quote
Old 11-20-2012, 10:09 AM   #107
MacSTi
My Ride: 2005 STi
Anyone willing to get one for me? Sorry for bringing this back from the dead.
MacSTi is offline   Reply With Quote
Old 11-20-2012, 11:33 AM   #108
jabela
My Ride: 2002 325ci
What do you mean get one for you? Just buy this off amazon. I used it last winter and it worked great. Should be even better than the BMW heater as it heats your oil pan as well, not just the coolant.
Modern Apothecary
Old 01-03-2013, 11:41 PM   #109
MacSTi
My Ride: 2005 STi
It's not available but I'd rather an OEM part.
Old 01-04-2013, 10:23 AM   #110
jabela
My Ride: 2002 325ci
Here's one in stock.
http://www.amazon.com/gp/aw/d/B000M4...sr=8-1&pi=SL75
Modern Apothecary
Old 01-21-2013, 10:56 AM   #111
MT325xi
My Ride: 2006 325xi W, 84 633
block heater
Hi Bruce,
Are you happy with your block heater - thinking of ordering one for my 2006 325 xi wagon. Any issues I should be aware of. Thx
MT325xi is offline   Reply With Quote
Old 01-21-2013, 11:36 AM   #112
jabela
My Ride: 2002 325ci
Still love my oil pan heater... -10'C the other day, but I get into car with oil/coolant at +11'C. Here's a Canadian source and more info
http://www.padheaters.com/in_pan_oil_heater.htm
Modern Apothecary
Old 01-21-2013, 01:13 PM   #113
MT325xi
thx Jabela... just ordered one... any issues putting it in or operating it?
Old 01-21-2013, 01:18 PM   #114
jabela
My Ride: 2002 325ci
No issues after over a year of usage. Just follow the instructions. I think there was only one way to fit it on our oil pan.
Modern Apothecary
Old 01-21-2013, 01:22 PM   #115
MT325xi
Thx again for the quick fix...
Old 01-21-2013, 01:57 PM   #116
jabela
My Ride: 2002 325ci
Just remembered a few things. I use an outdoor timer so I can plug it in when I get home and it only comes on before I leave. I also got a thermostatically controlled plug that only comes on under 2'C, but I haven't bothered using it http://www.amazon.com/Farm-Innovator...=pd_sim_auto_2. If it's warm I just don't plug in my car.
Also, to install the pad, it's easiest to remove the front aluminum brace, so you may want to do some other maintenance while you're under there (FCABs mostly).
Modern Apothecary
Old 01-22-2013, 11:17 AM   #117
MT325xi
Thx for taking the time to help me out Jabela - great tips and really appreciated. Will let you know how my install goes.
Old 01-22-2013, 06:35 PM   #118
taibinhvuong
My Ride: E46 99' 328i
Originally Posted by exeye325 View Post
Put one in last night. The instructions say to use some kind of silicone paste to aid in the heat transfer which I didn't have so I used some high heat silicone sealant instead....should help.
My dealer charged me $88 for the part so I did a little better than you.
The two are completely different products. Silicone paste is white stuff common used in between electronic parts and heatsink to aid heat dissipation while high heat silicone sealant is type of sealant similar to gasket sealant uses to seal or prevent oil leakage for auto industry, the use of high heat silicone sealant on the block heater actually isolated heat transferring to the engine, how much heat isolation depends on the thickness of the sealant applied.
You should unbolt the block heater and thoroughly cleanup this high heat silicon sealant, go to Radio Shack or electronics store and buy a tube of white silicone paste for few bucks and applies it evenly on the contact surface of the block heater and bolt it on to the engine, cleanup excessive white paste afterward.
Edit: didn't realize this was old post.
taibinhvuong is offline   Reply With Quote
Old 12-11-2013, 01:00 AM   #119
guyzer
My Ride: 325xi 323ic
hello
thanks
guyzer is offline   Reply With Quote
Old 12-11-2013, 01:05 AM   #120
STORMER
My Ride: AA SC 98 M3
E46 Block Heater Install
Originally Posted by guyzer View Post
Did you guys get the heater from a BMW dealership ?
thanks
It has been discontinued and no longer available.
360+rwhp
AA Stage 2, Arp2000, Underdrive Pulley, M50 Manifold, Cat Delete, Supersprint Exhaust, M5 Clutch w/ Lightweight Flywheel, Euro Fan, FK Coilovers, AEM Boost Gauge, Zhp Knob, Stoptech Brakes, R1 Rotors
Originally Posted by Sweetness View Post
You sir, just thread jacked the sh!t out of OP.
STORMER is offline   Reply With Quote
diy, heater
