Old 11-02-2008, 06:58 PM   #1
xflashjr
My Ride: supercharged miata
Help! Doing my window regulator but the window was not bolted down!
Hey everyone.
I have a buyer for my car who is coming in tomorrow and I told him I would fix both front regulators before the car is sold.
I finished the detail tonight and pulled the car into the garage to begin working on the regulators.
I started on the passenger side and everything came off really easy, it looks like it has been done before on this side so that made it even easier. When I got to the step of removing the bolts in the window there was a problem. I did not have to remove the window bolts and the red clip and the bolt remained attached to the window. I moved the window up and one of the bolts was laying on the bottom of the door well. the other one I undid from the plastic clip.
Well I finished fixing my regulator and now have no idea how to put this back together. I am assuming this might be part of the problem of why it did not work. Can anyone help!
Steve
www.Headlightsupercenter.com
Where there is real added value in good lighting
xflashjr is offline   Reply With Quote
Old 11-03-2008, 01:13 PM   #2
reynaldo
My Ride: 2001 325i Sedan
Send a message via Yahoo to reynaldo
the 2 red bolt should be attached to the window. the function of these 2 red bolts is to hold the window. If that si the one fell, you need to re-attached it to the window.
reynaldo is offline   Reply With Quote
