Brake Question - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Sponsored by BimmerWorld
Old 11-03-2008, 08:14 AM   #1
Glory22
My Ride: 323ci
Brake Question
Hi All,
Just re-did my front rotors/pads because i felt some vibration when i braked. Thought it could have been a warped rotor. After the install I tested my work and the shimmy, or "vibration" was gone. However it seems to be coming back. I did not do the rears yet; they don't seem to need it.
The question is, why would this vibration happen? Also, i need to apply more pressure than usual to stop. Not anything major, but more than i'm used to. I did not bleed the brakes, could it be I have some air in the lines? I compressed the pistons with a c-clamp when i installed the pads...
Thanks!
Glory22 is offline   Reply With Quote
Old 11-03-2008, 08:51 AM   #2
Black_Knight
My Ride: '02 330Ci
if you redid rotors/pads they need time to bed in order to get that initial bite IMO.
i think air in the lines would be obvious if you can "pump up" the brake pedal. also, you wouldnt have to apply more pressure, just more pedal travel, which would shorten after pumping.
if you require more pressure to get same brake force that means the pads arent biting the rotor as much as they did before
Black_Knight is offline   Reply With Quote
