Old 05-15-2002, 10:26 AM   #1
trkmedic69
Abominable Ho-Man
My Ride: 2000 BMW 323i
Send a message via AIM to trkmedic69
Question Question for the Techies about Brakes and Rotors....
About a month ago i replaced my OEM brake pads with Axxis deluxe... So far nothing but positive comments in all respects. When I did so, my OEM Pads were pretty worn and ready for replacement. My inspection 1 is coming up and I know they would have replaced the OEM pads then (had I not changed them)....
My question is - would the dealer do anything to the rotors or other brake equipment when changing the pads? I thought I had heard that the rotors were replaced when the pads were... Is this true (and will they still do it under warranty since I changed the pads)??
I just want to make sure if I'm supposed to do anything with the rotors, lines, fluid or anything else that it gets done. Thanks!
trkmedic69 is offline   Reply With Quote
Old 05-15-2002, 10:44 AM   #2
vinnymac
St. Louis BMW Fanatic
My Ride: 2011 335is
Send a message via AIM to vinnymac
It really depends on the condition of your rotors...
they may replace them if they do not meet OEM spec or if they are heavily warped.
vinnymac is offline   Reply With Quote
Old 05-15-2002, 11:02 AM   #3
trkmedic69
Abominable Ho-Man
Re: It really depends on the condition of your rotors...
since i changed pads though will they not touch my rotors? When is brake fluid changed?
Old 05-15-2002, 11:09 AM   #4
SteveL
My Ride: '02 330Ci & '98 528i
Depending on your dealer.....
They may charge for new rotors, claiming that the non OEM pads caused extra wear and voided the warranty. If they are still in good shape and meet factory specs, you shouldn't need to replace. If they are going to charge you for new rotors, go aftermarket and get cross drilled or slotted for less money. If you changed the pads yourself, you can easily do the rotors too.
SteveL is offline   Reply With Quote
Old 05-15-2002, 02:28 PM   #5
emi323i
E46 Pioneer
My Ride: none
you should replace rotors at least every 2 years...
just for the heck of it. they're not expensive if DIY. bmw recommends new Brake fluid every 2 years, but any real expert will tell you it should be done every year. especially if you live in humid areas (snow, rain, high humidity, etc)
emi323i is offline   Reply With Quote
