Old 11-05-2008, 02:31 PM   #1
BMW_Matt
My Ride: 135
Oil change
for changing oil,
Is it necessary to torque the oil filter to 25 NM?
Or can you just tighten it until tight?
BMW_Matt is offline   Reply With Quote
Old 11-05-2008, 02:33 PM   #2
redronin
My Ride: 330ci
depends on if you want to chance it leaking or not. torqueing to spec is always the safe/smart move.
redronin is offline   Reply With Quote
Old 11-05-2008, 03:02 PM   #3
BMW_Matt
My Ride: 135
alright, whats the chance it leaking if I tighten it a little past hand tight?
Old 11-05-2008, 03:20 PM   #4
Chris@ModBargains
Past Site Sponsor
My Ride: E46 325Ci
You'll most likely be okay, but it is always advisable to use a torque spec when available. I do understand that not everyone has a torque wrench handy.
Chris@ModBargains is offline   Reply With Quote
Old 11-05-2008, 03:56 PM   #5
BMW_Matt
My Ride: 135
Well I can get one. I work at a Dodge dealership and next to all the mechanics. I was just wondering if it was necessary, but thanks for the responses!
Old 11-07-2008, 04:42 AM   #6
GatorHawk
My Ride: 01 330ci M/T
Before getting my torque wrench, I would mark on the plastic oil filter cap a reference mark related to the metal housing.
Then when tightening it back on, I would tighten it until the marks matched. Not as accurate, but works in a pinch.
GatorHawk is offline   Reply With Quote
Old 11-07-2008, 06:50 PM   #7
Chris@ModBargains
Past Site Sponsor
My Ride: E46 325Ci
Assuming that who ever changed the oil last torqued it to proper specs.
Old 11-07-2008, 11:03 PM   #8
grafiksguy
My Ride: 2010 328xi
If you have access to a torque wrench, its always the way to go. I don't think I've ever heard of anyone shearing off a bolt or stripping a thread using a proper torque wrench, it's a worthwhile investment for the toolbox.
grafiksguy is offline   Reply With Quote
Old 11-10-2008, 05:43 AM   #9
GatorHawk
The first oil change was when the car was new (it's first oil change), so I had hoped and assumed that "Franz or Klaus" over in Germany had torqued it right, preferably before going to the BeirHauz.
Did end up getting a tq wrench after that change...best $ ever spent.
