Old 11-06-2008, 02:42 PM   #1
Hadezz
My Ride: 2001 BMW 330i
HELP! on Repairs -OEM or Aftermarket - have diagnostic
got couple things gone wrong with my car so went and got a diagnostic which is attached...
i got bad front lower control arm bushings.. tiny leaks in valve cover gasket n power steering n a squeaking a/c belt idler pulley
the valve cover gasket seems pretty easy DIY so am knock that off
power steering is just a small leak and put some lucas oil stop leak n seems to be working as my check engine light has turned off.
the bushings should i go OEM or aftermarket ?
the pulley just squeaks at the moment, was wondering should i jus replace whole set or just the a/c idler pulley n if whole set OEM or aftermarket
think i can knock off the bushings myself but idk about the pulleys should i take it somewhere or look for a DIY
oh and on the last page what the heck is "rear axle or driveshaft diagnosis rear diff bushing" and why does it cost almost $1,000
so any help would be great .. links are also good
ID:	290873   Click image for larger version
ID:	290874   Click image for larger version
ID:	290875   Click image for larger version
Hadezz is offline   Reply With Quote
