Old 11-07-2008, 09:16 AM   #1
spivey3
My Ride: Jet Black 325i
Replaced tensioner pulley ... awful noise
So I recently began hearing a noise from the engine bay during cold starts. The noise could be described as a whining/sqeaking sound. Anyway, I diagnosed the problem as the upper tensioner pulley. I am 99% sure that my diagnosis was correct. What led me to believe this was after removing the belts, it was very obvious that this pulley had a problem. The pulley spun too freely and was very rough (sounded/felt like sand in the bearing).
Fast forward 3 days. I got the pulley in from Pelican Parts (excellent price by the way) and installed it. Everthing is put back together and I crank the car for the first time. Immediately I hear a noise very similar to the one I had been hearing, but even worse. The noise lasted approximately 10 seconds, then it got quiet. My question is: Has anybody had a brand new pulley make a horrible noise the first time it was installed? Was I hearing some kind of "break-in" period for the pulley? The reason I think this is after that first 10 seconds of horror, it has been quiet as a mouse. Please tell me this is normal...
Thanks!
spivey3 is offline   Reply With Quote
Old 11-07-2008, 09:53 AM   #2
snowie007
My Ride: 2000 323i
i have replaced all belts, water pump/pulley, idler pulley, both tensioners and got a squeak after the first/second start of the engine. Now it is all quiet @ startup.
snowie007 is offline   Reply With Quote
Old 11-07-2008, 10:01 AM   #3
ddombrowski
My Ride: 01 330ci 5spd
Send a message via AIM to ddombrowski
If the belt is old, I suppose it may still be slipping and causing the squeak.
Any chance you got oil/grease on the belts as you were changing the pulley?
ddombrowski is offline   Reply With Quote
Old 11-07-2008, 10:28 AM   #4
smolck
My Ride: 2004 ZHP Sedan
You still have another tensioner pulley that could be bad.
Check out my BMW Blog
http://smolckbmw.blogspot.com/
Check my Youtube channel for DIY's and fun stuff
http://www.youtube.com/user/flipfinish?feature=mhee
smolck is offline   Reply With Quote
Old 11-07-2008, 11:14 AM   #5
nathancarter
My Ride: 02 330i
Or the idler pulley that's bolted to the front of the alternator. For me, that was worse than the tensioner pulley.
nathancarter is offline   Reply With Quote
Old 11-07-2008, 11:32 AM   #6
spivey3
First off, thanks for all the replies!
Thats good, this sounds very similar to my situation.
I did a very thorough inspection of the belt, because usually when I do something like replace a pulley, I go ahead and replace the belt. However, the belt looked in like-new condition, so much that that I didn't want to spend even $15 to get a new one.
I don't think I got any oil or grease on the belt, however, there was a significant amount of dirt that came out of the old pulley, and I'm sure plenty of it got on the belt. Not sure if that could cause this noise, but its an idea.
I should add that I've heard a lot of belts slip over the years on a lot of different cars, and to me this did not sound like a belt slipping. A belt slip is a screeching/painful sound, and this was more of a metal on metal sound (imagine a squeeky hinge).
I did check the other tensioner pulley, but it appeared to be fine. The movement of this pulley was very similar to the movement of the replacement part and VERY different from the movement of the bad pulley. I might give this a shot though if the noise persists.
I also checked the idler pulley for damage and signs of wear, but like the other tensioner pulley it appeared to be just fine. However, if the problem persists, this will also be on the list of parts to replace. I was very suprised at how affordable these pulleys are. So much so that I could go on replacing pulleys for quite a while before even coming close to the diagnosis fee from a shop.
Thanks for the ideas/suggestions guys! I'm gonna keep at this and I'll let you know how it turns out. Hopefully the noise stays away like poster #1 suggested.
Old 11-07-2008, 11:59 AM   #7
hummer
My Ride: 2001 330CI
Ah, but did you check the waterpump and alternator? Maybe the tensioners need to be replaced also. Did all mine at 114K. Absolute silence!
Old 11-07-2008, 03:12 PM   #8
SW222
Banned User
My Ride: is silver and slow.
Did you replaced the waterpump, alternator AND both belt tensioners?
SW222 is offline   Reply With Quote
Old 11-11-2008, 04:39 PM   #9
spivey3
Ok, just wanted to follow up on this thread. The noise has disappeared. My only explanation is a short "break-in" period for the new tensioner pulley. I've waited and listened for even a hint of the noise to still be there ... but nothing. Thanks for all the advice and suggestions!
Old 11-27-2008, 05:19 PM   #10
Blackspidey
My Ride: 02 325i
how much are the idler pulleys? bcuz the same thing is happening to me. when i start it up i hear the noise comin from the idler pulley/alternator area. and when i accelerate i can hear the noise turn into a squeaking but it'll be fine after 10mph. so ima fix it tomorrow. sadly i cant take it tonight
Blackspidey is offline   Reply With Quote
Old 11-07-2010, 02:52 AM   #11
e46rage
My Ride: 330ci 2001
had the same problem happend to me every morning till today when i went on a cruise up in the bay area with a couple of buddies and BAM ! steering wheel locked up and i was going into a turn and i slammed on the breaks HARD ! ended up like a inch from the barrier witch on the other side was a cliff... A VERRRY STEEP CLIFF . so i pushed my car to a turn out ,and i checked it out and it was my belt that went out , a pully shattered a well. got so lucky wish i could have checked it sooner. this actually happend today, had to get my car towed from a really bad road we were driving as group in witch took 5 hours !! well not shes home safe and sound waiting on monday to get her fixed
R.I.P. E46RAGE.
e46rage is offline   Reply With Quote
Old 11-07-2010, 03:08 AM   #12
-Jay-
My Ride: 06 X3 3.0i
Send a message via AIM to -Jay-
Had the same issue as you. Except mine was the idler pulley. After replacing it, I heard the noise one more time the. It's been quiet ever since.
-Jay- is offline   Reply With Quote
Old 11-07-2010, 10:32 AM   #13
cvx5832
My Ride: 325Ci, 325Cic, C300
Same here. Replaced all pulleys, at startup I heard one more squeak. Then all was well. That was 20k miles ago.
Regards,
Paolo
cvx5832 is offline   Reply With Quote
Old 11-07-2010, 10:33 AM   #14
xi_ter
My Ride: 2003 325xi
The grease that was packed into the bearing probably hardened and settled at the warehouse. The grease pack sounds like it took 10 sec to remix and recoat all the bearings.
