Old 11-08-2008, 12:52 PM   #1
christraylor2
My Ride: 2002 325CI
Exclamation 2nd New Thermostat, STILL NO HEAT!?!?!
I got a new thermostat, thinking that was what the problem was, as that was what the code said, so I replaced it. I still had no heat...... and my engine was still running cold. I got a new thermostat (under parts warranty on the other) and now it seems that the engine is running cooler than it did and I still have no heat!!!! WHAT IS GOING ON?!?!?
christraylor2 is offline   Reply With Quote
Old 11-08-2008, 01:01 PM   #2
E46 Coupe
E46 Coupe's Avatar
My Ride: Rules1 & 2: S T F U!
How do you know the engine is running cold?
E46 Coupe is offline   Reply With Quote
Old 11-08-2008, 01:02 PM   #3
christraylor2
My Ride: 2002 325CI
by the temperature gauge being almost completely below the 1/4 line on the gauge. It is nowhere close to the '12' o-clock position
Old 11-08-2008, 01:15 PM   #4
E46 Coupe
E46 Coupe's Avatar
So therefore it could be the gauge or the sensor connected to that gauge that is faulty and NOT the thermo?
Old 11-08-2008, 01:19 PM   #5
E46 Coupe
E46 Coupe's Avatar
In any other car.. (not exactly certain on the E46's) all these oil lights, temp gauges are known as "IDIOT lights / gauges" and DO NOT reflect what the engine is really doing.
ie.. in your Camry by the time you notice your oil pressure warning light on while driving.. you wouldn't be driving a n y m o r e. These things are made for the idiot mass's out there.
Old 11-08-2008, 01:39 PM   #6
christraylor2
My Ride: 2002 325CI
that wouldn't really represent my heat being out would it?
Old 11-08-2008, 02:13 PM   #7
christraylor2
My Ride: 2002 325CI
Any ideas you guys? Winter's gonna be a ***** this year so I'd like to have heat!
Old 11-09-2008, 07:13 AM   #8
christraylor2
My Ride: 2002 325CI
anyone?
Old 11-09-2008, 09:46 AM   #9
cgrizzly888
My Ride: 00 328i
Send a message via AIM to cgrizzly888
Do you have heat coming out of the vents? You could have a faulty temperature sensor located on your lower radiator hose.
cgrizzly888 is offline   Reply With Quote
Old 11-09-2008, 09:58 AM   #10
christraylor2
My Ride: 2002 325CI
There is no heat, about 3 weeks ago, for like 5 minutes heat came out, then nothing. Would that explain the engine temperature gauge consistently changing?
Old 11-09-2008, 10:02 AM   #11
DarkJoker
My Ride: 01 330ci
small possibilty of the cooling system not being bleed properly
DarkJoker is offline   Reply With Quote
Old 11-09-2008, 10:02 AM   #12
ransomed
My Ride: 2004 330i ZHP
where are you in Georgia?
2004 330i ZHP-AlpinWeiss-Natural Brown Leather-6MT
Dinan Signature Package - High Flow Intake, High Flow Exhaust, Stage 2 Software, Front Strut Brace
ransomed is offline   Reply With Quote
Old 11-10-2008, 12:04 AM   #13
christraylor2
My Ride: 2002 325CI
I will re-bleed tomorrow, because I got heat or about 5 seconds tonight then back to semi-cool flow.
I am west of atlanta by about 20 minutes..
Old 11-10-2008, 06:59 AM   #14
grafiksguy
My Ride: 2010 328xi
Air in the system generally tends to make things run hot, not cold. If you are having issues with the cabin temp, that could be related to the internal temperature sensor, not the engine temp. I had the "cool running" problem with the engine not wanting to come up to temp and a new thermostat solved it for me. Yours sounds like it may be a few different things. Good luck with the diagnosis.
grafiksguy is offline   Reply With Quote
Old 11-10-2008, 09:22 AM   #15
snowie007
My Ride: 2000 323i
Are you getting no heat when idling or moving? Check your fan.... I don't know if you have the electric or mechanical clutch fan but they are known to fail.
snowie007 is offline   Reply With Quote
Old 11-11-2008, 09:41 AM   #16
christraylor2
My Ride: 2002 325CI
alright, so weird up on weird. I took it to my mechanic friend and he simply opened the hood and wiggled a few things and my heat worked for the next 45 minutes until I parked it for the evening. I woke up and allowed my car to heat up and then turned the heat on....... cold air...... I don't know what's going on....?
Old 11-11-2008, 10:53 AM   #17
snowie007
My Ride: 2000 323i
what did your mechanic wiggle? sensor connections?
Old 11-15-2008, 09:00 AM   #18
christraylor2
My Ride: 2002 325CI
I don't know, he just popped open the hood because I took it to him saying it hadn't had heat for a while, but sure enough, he opens it up and just touches something and there's heat. I looked pretty dang stupid. But I am still having problems with the heat and my temperature RARELY moves past \ if looking like _\|/_ it very much tends to stay around the '\' What could this be....? I tend to smell burning coolant sometimes too, but I just thought it was the excess that leaked during bleeding and the thermostat change..... Anything from you guys?
Old 11-15-2008, 10:02 AM   #19
TitaniumCranium
/// Limitless
TitaniumCranium's Avatar
My Ride: 2002 BMW 330Ci
There are two places I would look. My guess is that this is a poor electrical connection to either the heating element connected to the thermostat that opens and closes the thermostat - based on input from sensors - or it is the the temperature sensor itself located on the lower left radiator hose (mentioned once before).
/// MODS
Old 11-15-2008, 10:56 AM   #20
christraylor2
My Ride: 2002 325CI
Do you think that either of those would cause the erratic temperature behavior and the loss of cabin heating? There is no heat even when the car's temperature is at the '12' position.
coolant, heat, thermostat
