Old 11-15-2008, 10:59 AM   #21
IxNay
My Ride: 2000 328Ci 5sp SP
Have you tried putting the heat up to the max (91 degrees) ? If heat comes out at the max only, then you likely have a problem with the heater control unit in the dash. It is the part with the digital display and buttons for the heat/ac on the dash.
IxNay is offline   Reply With Quote
Old 11-15-2008, 11:00 AM   #22
christraylor2
My Ride: 2002 325CI
The heat comes out at all fan speeds when the heat decides to come out, like the other night when it was working shortly at any fan speed I could get heat.
christraylor2 is offline   Reply With Quote
Old 11-15-2008, 11:24 AM   #23
330ciandr6
My Ride: .
Send a message via AIM to 330ciandr6 Send a message via Yahoo to 330ciandr6
connection at heater valves which decide if you get heat or not? i'd warm up the car, turn on the heat and touch a heater hose after the heater valves and see if coolant is flowing through it
Have a oil or coolant leak? Click here!:http://forum.e46fanatics.com/showthr...732&highlight=
ABS/DSC/Brake/Airbag light on?? Click here!:http://forum.e46fanatics.com/showthr...648&highlight=
330ciandr6 is offline   Reply With Quote
Old 11-15-2008, 11:25 AM   #24
330ciandr6
My Ride: .
oh and if its not bled completely heater will not work right.
Old 11-15-2008, 11:25 AM   #25
TitaniumCranium
/// Limitless
TitaniumCranium's Avatar
My Ride: 2002 BMW 330Ci
Originally Posted by christraylor2 View Post
Do you think that either of those would cause the erratic temperature behavior and the loss of cabin heating? There is no heat even when the car's temperature is at the '12' position.
Yes, I think it could cause the erratic temps you describe.
The wire coming from the thermostat acts as an electrically controlled valve. I believe it's a preheater for the stat. If your electrical connections are intermittent you woud experience unanticipated behavior.
It controls the direction of coolant flow through the block. It's plausible that one of those paths could bypass the heater core.
This has happened to me, including throwing the codes, but It was inspection time so I replaced everything - tstat, sensor, pump, expansion tank and hoses.
One other thing I remember. When I got my stat it looked odd. It wasn't pushed all the way into the housing. The metal legs that center the valve in the housing were not snapped into the housing... just a thought.
/// MODS
Old 11-15-2008, 11:28 AM   #26
TitaniumCranium
/// Limitless
True.
He mentioned that the mechanic just wiggled some stuff and it then worked so electrical connection sounds like it would be more likely.
Still I would not discount the air bleed. It could be a combination of things too.
I just have to ask... You have checked the coolant level - right?
/// MODS
Old 11-15-2008, 12:29 PM   #27
christraylor2
My Ride: 2002 325CI
Originally Posted by TitaniumCranium View Post
True.
Yes, I have bled, re-bled, re-bled that re-bleeding and re-bled once more for good measure. I doubt air to be the culprit of this. I am very confused still at this point. Darn euro engineering!
Old 11-15-2008, 01:24 PM   #28
330ciandr6
My Ride: .
umm....why didn't ya asking what he "wiggled"...
Old 11-15-2008, 05:26 PM   #29
christraylor2
My Ride: 2002 325CI
he 'wiggled' around the water pump, I watched him do it, and then almost immediately my heat was working but took a few seconds to reach a 'hot' temperature.
Old 11-15-2008, 05:39 PM   #30
330ciandr6
My Ride: .
wtf...wiggled the water pump? if your water pump can be "wiggled" you need a new one!
Old 11-15-2008, 11:56 PM   #31
christraylor2
My Ride: 2002 325CI
around it, not the actual pump.
Old 11-16-2008, 02:31 AM   #32
330ciandr6
My Ride: .
ok...i'm just trying to understand what he moved around...
Old 11-16-2008, 08:10 AM   #33
NoVaDreier
My Ride: 2001 325i
Did you re-secure the plug cable to the radiator hose with a cable tie? Make sure that the plug is fully inserted in the thermostat housing and that the female contacts in the plug of the electrical connection are clean. You could even apply a contact enhancer like Caig ProGold or Stabilant 22 if you have it.
If that fails, do a continuity test on the wires in the plug. One may have fatiqued from being disconnected.
NoVaDreier is offline   Reply With Quote
Old 11-16-2008, 08:14 AM   #34
christraylor2
My Ride: 2002 325CI
I'll make sure that it's fully inserted this morning, although I doubt that is to blame...
Old 11-16-2008, 04:24 PM   #35
strongbad
My Ride: 2002 325CI
Final stage resistor
Have you changed it? Its a PITA, 90 mins if you have big hands.. Get one for $55 and change it.
strongbad is offline   Reply With Quote
Old 11-16-2008, 05:26 PM   #36
330ciandr6
My Ride: .
^ takes me like 20-30 min in and out. its not that hard...
Old 11-16-2008, 05:38 PM   #37
strongbad
My Ride: 2002 325CI
20-30 after you have done it once already.
I found it difficult to get my big arse head and hands around in there whilst laying on my back with my head in the passengers floor board.
Also.. to the OP.. if it was your thermostat.. and your car never got to operating temp.. especially hot enough to provide 75F temps.. you would be running rich as heck all the time. Leave the engine components alone and change the FSU/FSR (called two different things, same unit.)
Old 11-16-2008, 07:42 PM   #38
DarkJoker
My Ride: 01 330ci
ive never seen a final stage cause erractic temps
erractic blower speeds yes but never temps and ive changed a buttload of em
DarkJoker is offline   Reply With Quote
Old 11-16-2008, 09:33 PM   #39
strongbad
My Ride: 2002 325CI
my car was blowing cold air before I changed mine. Just figured they guy can't loose by changing a $50 part.. he's tried almost everything else.
Old 11-16-2008, 09:40 PM   #40
Optio
My Ride: 328i
Your connector to the T-stat is bad......remove the connector and inspect the contact. BMW parts department sales connector repair kits.
Optio is offline   Reply With Quote
coolant, heat, thermostat
