Old 11-16-2008, 09:02 PM   #41
christraylor2
My Ride: 2002 325CI
A lot happened here while i was gone today!
I had thought about changing out the FSR but didn't know if it would solve my problem or not, so I let it be for the time...
Someone said my connection is bad....? Well I would like to believe that, however, today, in 37-40 degree weather the car almost the whole time I drove (100+ miles) essentially stayed in the '12' o clock position. However, I still had no heat.....
christraylor2 is offline   Reply With Quote
Old 11-18-2008, 06:16 AM   #42
christraylor2
My Ride: 2002 325CI
alright so drove around last night for a while with heat, cut off then back on, still had heat. I am convinced that my heat works only when I have low coolant, which my coolant light is on right now. My bet is a leaking expansion tank or a leak somewhere since I can smell burning coolant most of the time... This just keeps getting better and better..................
Old 11-18-2008, 06:26 AM   #43
franz
My Ride: 03 330i
wow
franz is offline   Reply With Quote
Old 11-18-2008, 08:38 AM   #44
Kurt V
My Ride: 2002 325i
Instead of spending two weeks guessing at what the mechanic might have done, why not just take the car back to him and ask him?
Kurt V
2002 325i Sport
1986 911 Carrera
2007 Bonneville T100
Kurt V is offline   Reply With Quote
Old 11-18-2008, 08:54 AM   #45
cgray4bmw
My Ride: 330I
Ive had this happen on two of my e46 bmw`s,,, very well could be your problem also,, for some reason there would be a air lock in the heater core lines and no heat,,, on the lower inside driver side strut tower there are two hose lines that run into a valve,,, I had to remove one of the lines and flush it with a water hose to bleed it back,,, no more heat problems... I found this out by googleing,, and It worked for me..
cgray4bmw is offline   Reply With Quote
Old 11-18-2008, 04:25 PM   #46
christraylor2
My Ride: 2002 325CI
he simply touched the water pump. Unless this man has the touch of God, which I don't think he does as it seems he can't fix my Mercedes to save his life, his touch did nothing.
I did let my car sit last night and started it back up this morning and had heat, left it for about 3 hours, came back, had heat.... Another 3 hours, came back, you guessed it, NO HEAT.
I don't want to take it back to anyone just yet to have them guess around with what it 'might' or 'could' be, which is what my local stealership told me, that a I needed a new thermostat a day AFTER I put a brand new one on myself.....
Old 11-19-2008, 08:57 PM   #47
christraylor2
My Ride: 2002 325CI
alright, I'll give this one more day before I give up and take back to dealership for which will inevitably be over 2 grand. any help is appreciated
Old 11-27-2008, 12:34 AM   #48
TitaniumCranium
/// Limitless
TitaniumCranium's Avatar
My Ride: 2002 BMW 330Ci
Well - some time has gone by. By now I figure you probably have fixed the problem (or someone else). I'm curious, what was the outcome?
/// MODS
/// Auto => 6-Spd Manual Conversion | Apex EC-7 | Koni/Ground Control Coilovers | Vorshlag Camber Plates | Meyle HD LCA | PowerFlex bushings | GruppeM CAI | Shark Injector | 6000k HID's and Fogs | BMW European MTechII | BMW Performance Shifter | ACS Mirrors and Rear Spoiler ///
Old 12-04-2008, 06:57 PM   #49
christraylor2
My Ride: 2002 325CI
So after about a week and a half in the shop for diagnostics (yea right) they come back and repair/replace my heater sensor and my air duct sensor to the tune of about $300. I'm not too upset, a fair price to have EXCELLENT working heat! However, when I go to pick it up........ I start the car in the indy's parking lot and the DSC and BRAKE light are illuminated yellow..... This is strange, well, simply because that wasn't like that when I dropped it off........ I'm under the impression the dash had to be removed to install one or both of these parts, my question is, could the mechanic have unintenionally screwed something up...? I'm taking it back up to him tomorrow AM to see if there are any codes thrown, or if he simply just didn't connect something the right way.... Anything?
Old 12-04-2008, 08:31 PM   #50
christraylor2
My Ride: 2002 325CI
Anyone have any ideas....? Trying to figure this out before I get nasty with the Indy
Old 12-04-2008, 09:35 PM   #51
DarkJoker
My Ride: 01 330ci
prob steering angle sensor
it is a possibilty
go lock to lock with the steering wheel see if it goes out
DarkJoker is offline   Reply With Quote
Old 12-04-2008, 09:45 PM   #52
christraylor2
My Ride: 2002 325CI
it is a possibilty
I'll try that here in a second... Would that trigger both the DSC and BRAKE lights to illuminate yellow?
Old 12-07-2008, 10:28 AM   #53
DarkJoker
My Ride: 01 330ci
well did it work?
Old 12-07-2008, 11:13 AM   #54
snowie007
My Ride: 2000 323i
how about accidently activating the DCS switch? d'oh!
snowie007 is offline   Reply With Quote
Old 12-07-2008, 11:53 AM   #55
TitaniumCranium
/// Limitless
That doesn't stay activated between starts though, at least not on any I've seen.
This dude has some issues (christaylor)
/// MODS
Old 12-07-2008, 04:04 PM   #56
Carlo323
My Ride: 99 323i
i had the same problem on my e36, i changed the temp sensor, then i found out my heater core sensor thingy, that looks like a pair of boobs, that was done, changed it, then flushed my rad fluid, it was a bit better, but after driving for a while i needed more rad fluid, it was too low, and problem solved, it was the funniest **** ever.
Carlo323 is offline   Reply With Quote
Old 12-29-2008, 05:32 PM   #57
tbehling
My Ride: 2002 Audi A4
Do you think that either of those would cause the erratic temperature behavior and the loss of cabin heating? There is no heat even when the car's temperature is at the '12' position.
this seems to be a common problem. i am experiencing the same thing right now. Im going to try to bleed my cooling system again as it seems that coolant is not reaching my heater core
Photobucket
tbehling is offline   Reply With Quote
Old 03-25-2011, 07:49 PM   #58
pudermcgavin
My Ride: 02 325i
no heat
ok ive been reading what you all have had to say on this no heat issue, mine just started doing this on tues, i was driving to work in the snow and sleet (im in minnesota ) and i got to the stop light by work saw steady steam from the front of car but no smell i opened the hood when i got to work it was all looking good no wetness or odor of coolant. the next day i warmed the car up temp guage was at about 12 had no heat held throttle at about 1500 and i had heat but as soon as i come to a stop instant cold air no lag or cool down instant cold air. now i flushed my radiator and did my water pump about a year ago have had no problems and fantastic heat untill a few days ago where it was getting worse and worse from heat when i was moving to heat if over 3k on highway to no heat at all, coolant level was good but a little low added maybe a 1/4 quart had a big air bubble then i could get heat again but only if i was on the throttle. now leading up to this i had an erratic internal fan it lopped intermittently but had done that for a while im assuming its not related, now im a body tech not a mechanic but can handle most work on my own im just scared im looking at a head gasket which i cant afford it would be by by bimmer hello 800 dollar beater untill i can can pay off what i owe on the car i will mention its got 184k on it ive put 65k of that on the car myself
pudermcgavin is offline   Reply With Quote
coolant, heat, thermostat
