Old 11-08-2008, 08:20 PM   #1
raptorman5174
My Ride: 330i ZHP
Aluminum Thermostat Housing
does anybody have any opionions on this? Is this a good buy or should I go with the normal plastic housing?
http://cgi.ebay.com/ebaymotors/Alumi...04595632QQrdZ1
18 VMR CSL's
Koni
Eibach Sport Spring's
UUC Power Pullies
Sprint Booster
CCV Delete
3:38 rear diff
raptorman5174 is offline   Reply With Quote
Old 11-08-2008, 09:51 PM   #2
mkodama
mkodama's Avatar
I would stay with the normal plastic housing thermostat. BMW never made a metal thermostat for our engines. The only one I have seen is a CNC machined housing for motorsports use and it costs in excess of $200 if I remember correctly.
Old 11-08-2008, 09:53 PM   #3
GRIDLOCK
My Ride: E36 / E46
Stick w/ OEM.
Have an EVAP code? Replacing gas cap did not fix? Give me a holler, I can do a smoke test for ya.
GRIDLOCK is offline   Reply With Quote
Old 11-09-2008, 12:23 AM   #4
Arsevader
My Ride: '90 325i, '02 325it
Aluminum housing is a popular replacement for m50/52 but I've never seen it for m54 before.
http://www.turnermotorsport.com/html...ID=11531722531
- James
'85 E30 325e
'90 E30 325i
'02 E46 325it
'03 E46 320i
'96 Volvo 850R
Arsevader is offline   Reply With Quote
Old 11-09-2008, 08:00 AM   #5
TxTorqueMade
My Ride: 330i
Send a message via Yahoo to TxTorqueMade
+1. OEM. I just replaced my entire cooling system with OEM parts. No aluminum radiator, or thermo. Well.. I did put in a Graff WP with metal impeller, but thats the only alteration I would make, is to the water pump.
BMW e30 Bling
TxTorqueMade is offline   Reply With Quote
Old 11-09-2008, 08:51 AM   #6
grafiksguy
My Ride: 2010 328xi
Assuming that the innards of this aluminum T-stat are the same (but how would you know), it probably wouldn't do any harm.
But a couple of things to consider:
Would the heat conductivity of the aluminum vs. the (somewhat) insular properties of the plastic affect the accuracy of the thermostat?
And secondly, while there are many areas where a more expensive metal part would be preferable to plastic, that usually involves an item under some sort of physical stress. While the thermostats do go bad all the time, it's usually because the internal wax-based thermostat gives up the ghost. I don't know of any cases (though there may be some) where the exterior of the unit cracked or failed in some way.
So my question would be "What's the advantage of aluminum?" in the case of a thermostat. Failing to see any real upside, as others have suggested, I'd stick with OEM.
grafiksguy is offline   Reply With Quote
Old 11-09-2008, 10:11 AM   #7
Arsevader
I've never heard of the m54 thermostat cracking but the m60 from the e34 and the m50/m52 used in the e39 and e36 platform is quite prone to cracking.
- James
'85 E30 325e
'90 E30 325i
'02 E46 325it
'03 E46 320i
'96 Volvo 850R
Old 11-09-2008, 10:23 AM   #8
TxZHP04
My Ride: ESS TS2+ ZHP
You can at least expect a minimum level of quality with OEM parts. This ebay piece is unknown and unproven within the community. I'd stick with OEM.
Old 11-09-2008, 05:04 PM   #9
Arsevader
For sure. If you are going to go aftermarket then order from a reputable source such as Turner or one of the sponsors.
- James
'85 E30 325e
'90 E30 325i
'02 E46 325it
'03 E46 320i
'96 Volvo 850R
Old 11-09-2008, 05:06 PM   #10
BMW_Matt
My Ride: 135
Dude the oem thermostat is only $50 max. Stick wit it...
BMW_Matt is offline   Reply With Quote
Old 11-09-2008, 05:11 PM   #11
jpr
My Ride: '99 323i
I think a good rule of thumb is to never buy a non-OEM part for which you cannot identify the actual manufacturer of the part.
jpr is offline   Reply With Quote
Old 11-09-2008, 07:08 PM   #12
teamdfl
Slow in, slower out
My Ride: 325it
That's the first I have heard about an aluminum thermostat for the M54. The M50/M52 have a thermostat separate from the housing so an aluminum housing is a nice reliability upgrade. M54 thermostats are a 24 month interval item (in my experience) so the plastic does not age enough to fail like radiators do.
I say skip it.
Mod the driver. Participate in your local BMWCCA autocross or driving school. Have you joined BMWCCA yet?
teamdfl is offline   Reply With Quote
Old 11-09-2008, 09:48 PM   #13
grafiksguy
My Ride: 2010 328xi
I say skip it.
Just an FYI, the M52 engines used in the early e46's (99-00) also use the composite thermostat, like the M54 engines, not the separate parts. But yes, it does seem like they have a fairly short life, and 24 months (about 28K miles) is about what I experienced as well.
Old 11-10-2008, 06:44 PM   #14
raptorman5174
My Ride: 330i ZHP
Thanks guys for all your response, I will be going with the normal plastic housing
THANKS AGAIN GUYS!
18 VMR CSL's
Koni
UUC Power Pullies
Sprint Booster
CCV Delete
3:38 rear diff
Old 11-10-2008, 07:33 PM   #15
bigfatvr6prik
My Ride: Z8
+1. Couldnt have said it better meself
bigfatvr6prik is offline   Reply With Quote
Old 11-10-2008, 10:09 PM   #16
monkeyjuice5150
My Ride: ///M3 droptop
Send a message via AIM to monkeyjuice5150
I say skip it.
http://www.zionsvilleautosport.com/s...ry_Code=CCSE46
monkeyjuice5150 is offline   Reply With Quote
Old 11-11-2008, 09:31 AM   #17
TxZHP04
Originally Posted by monkeyjuice5150 View Post
Zionsville makes a quality piece but it's not necessary and certainly not cost effective for a daily driven car.
Old 11-11-2008, 10:18 AM   #18
Arsevader
$489! wow.
- James
'85 E30 325e
'90 E30 325i
'02 E46 325it
'03 E46 320i
'96 Volvo 850R
Old 11-11-2008, 10:22 AM   #19
TxZHP04
$489! wow.
See what I mean about it not being cost effective? Much much cheaper to just preventatively replace the OEM every 60-80k miles.
