Old 11-10-2008, 08:10 AM   #1
lioe46
My Ride: e46
DIY need help!!
i am trying change me corner to smoke on my 2001 330ci. i cant remove the light. i know there is a clip that holds it in. i try to push the clip down and push the light out but its not coming out. there is a 90 degree plug on the light, how do i remove that? thanks.
lioe46 is offline   Reply With Quote
Old 11-10-2008, 08:21 AM   #2
madchef
My Ride: '04 ZHP Sedan MB/NB
Assuming it is like mine, the front corner is held in by one screw. Looks straight down from above and you should see the screw that holds it in just at the outside back edge of the light (looks like a little vertical basket that you insert the screwdriver into). Once the screw is out, should wiggle out easily
2004 ZHP Sedan - Mystic Blue/Natural Brown, Sunroof Delete
OEM M3 Stress Bar, AFE Intake, OEM Clears, CDV Delete
madchef is offline   Reply With Quote
Old 11-10-2008, 08:27 AM   #3
lioe46
My Ride: e46
mine is a push in type
Old 11-10-2008, 08:28 AM   #4
frobie15
My Ride: has a door star
Send a message via AIM to frobie15
It should take a little careful determination to get it out. There isn't a screw on my '01 Ci, just push the tab down and use the palm of your hand to slide it out of the fender.
Go ahead, ask me a question... Check out the CopTalk thread in the California forum
Thank you Sam
frobie15 is offline   Reply With Quote
Old 11-10-2008, 09:35 AM   #5
lioe46
My Ride: e46
thank you i will try it, what about the electrical plug? do i need to twist it ?
Old 11-10-2008, 09:45 AM   #6
paraklas
My Ride: ESS TS2 320ci
Push clip, pull light, rotate plug counter clockwise until it's released fromt the light
