Sponsored by BAVSOUND
Old 02-12-2003, 05:13 PM   #1
pimpinCI
My Ride: E46er323ci
Will a 02 BMW OEM in-dash CDplayer fit a 2000 323ci?
I was wondering if a BMW business OEM in-dash cdplayer from a 2001-2003 bmw will fit a 2000 323ci. Are there any different connetction in that back like antena??
Please let me know.
Thanks.
pimpinCI is offline   Reply With Quote
Old 02-12-2003, 07:19 PM   #2
pimpinCI
My Ride: E46er323ci
Oh and BTW it I have a 2000 323ci with the oem CASSET deck.
Thanks.
Old 02-13-2003, 03:30 PM   #3
BGReddy00
09 X5
My Ride: 2009 X5
should fit fine just switch the wiring harness in the back
BGReddy00 is offline   Reply With Quote
Old 02-13-2003, 06:38 PM   #4
Slpnbyu
My Ride: 2011 M3 (E90)
Actually, it may not fit just fine. I went through all of this late last year. I have a '00 328Ci. At some point, they changed the antenna input on the back of the stereo. You need to check out the back of the stereo that you are looking at. Make sure it has 2, let me say it again, 2 round jacks somewhere on the back. 1 of them is smaller (the size of a Bic Pen insert) and the other is a bit larger (the size of the outside plastic casing of the pen). Some of the newer radios DO NOT have the larger of the two and if that is the case, everything will work except the radio.
Just so you know...
Slpnbyu is offline   Reply With Quote
Old 02-13-2003, 06:40 PM   #5
Slpnbyu
Ohhh ya, if you wanna send me a pic of the back of the radio, or post it on here I will be able to tell you for sure!!
Old 02-13-2003, 06:48 PM   #6
pimpinCI
My Ride: E46er323ci
Remember, I have a casset deck in there now. I have heard that I need the radio with 3 inputs...is that wrong? Anyway, I just wanted to make sure that we understand each other. I am not sue if casset connection and cd connection in these cars is dif.
Old 02-14-2003, 08:09 AM   #7
mikemartin9
My Ride: 2000 328i
OEM indash CD
There are 3 connections,
1 BIG wiring harness
1 RCA type antenna lead (AM)
1 mini coax antenna lead (FM)
The 2003 has one incompatible (to the 2000) mini coax for both AM and FM
if anyone knows where I can get an adapter(200 antennas to 2003 radio) let me know
the CD and the cassete are interchangeable as long as the antennas match
Mike
mikemartin9 is offline   Reply With Quote
Old 02-14-2003, 03:48 PM   #8
Slpnbyu
Re: OEM indash CD
Mike
Ditto that! I did the same switch you are looking to do (Tape -> CD). Originally I picked up a 2003 deck and none of my radio functions worked, but everything else worked perfectly (i.e., CD, Changer, Steering Wheel Controls, etc.)! Now I have an early 2000 CD player that I am trying to replace with a late 2000 and up model so I can get the clock function back.
Old 04-28-2003, 06:00 PM   #9
rhuss2
My Ride: 1999 328i
Re: OEM indash CD
Mike
Has anyone found a place to get an adapter for a 2 antenna connection car to a single antenna connection radio? I would like to get a business cd radio from a 2002 into my 1999.
rhuss2 is offline   Reply With Quote
Old 04-30-2003, 02:10 PM   #10
vids_blk323Ci
DFW
My Ride: JB 323Ci SP PP
Send a message via AIM to vids_blk323Ci
take a look at this link for some pictures
http://forum.e46fanatics.com/showthr...dash+CD+Player
Dinan Stage I S/W | ACS RSB | ///M FSB |UUC TMEs & Pulleys |Ate Slotted Discs | ScanGuageII | RockyMounts MTB Carrrier | OEM Rear Clears | LED Euro City Lights & Rear Fogs | Two-Tone Suede DIY | ACS Pedals | Bimmian Gauge Rings & M3 Face | Smoked Frnt Corners w/ Luxeon LEDs | EAS CF Roundels | JLevi Ti CF trim | Blk Suede shift/ e-brake boots | ECS Smoked Frnt Bumper Reflectors | DICE Duo
vids_blk323Ci is offline   Reply With Quote
Old 04-30-2003, 02:23 PM   #11
gmhl10
Resident CF Whore
My Ride: '05 A08 M3
Send a message via AIM to gmhl10 Send a message via MSN to gmhl10
Hmmm.... Mine looks a little different.
It comes from a 2002 325i sedan.
Will this fit in older models?
BTW, you can find my stuff at:
http://forum.e46fanatics.com/showthr...threadid=79817
'05 Silbergrau M3 - mfg date: May '05
Modifications: WAY too much to list
gmhl10 is offline   Reply With Quote
Old 04-30-2003, 02:28 PM   #12
gmhl10
Resident CF Whore
My Ride: '05 A08 M3
Whoops... nevermind...
It's just because it's upside down.
Old 04-30-2003, 05:03 PM   #13
rhuss2
My Ride: 1999 328i
Adapter
I need an adapter that will allow me to connect a CD Radio with this single connection. (mini coax on the left side)
[IMG]\\gemini\my documents\My Pictures\BMW Car Stereo\Back of 2002 Business CD Radio.jpg[/IMG]
to a e46 with wiring that connects to a radio with these 2 connectors. (the connector on the left and the smaller one on the right side)
[IMG]\\gemini\my documents\My Pictures\BMW Car Stereo\back of 1999 Business CD Radio.jpg[/IMG]
Old 05-01-2003, 11:18 AM   #14
vids_blk323Ci
DFW
pictures are broke dude.
Old 05-03-2003, 11:55 PM   #15
CynicalWry
Doesn't like PMs...Email me
CynicalWry's Avatar
My Ride: 00 323i-05 cbr600rr
Send a message via AIM to CynicalWry
I want a Cd player in the dash so bad! GGGRRRRR!!!!! I can't find anybody w/ the correct one. Mine has two plugs aside from the HUGE wiring harness. ANYBODY?
is your friend
Authorized Umnitza.com installer
301-825-5871
http://www.robinsNestChildCare.com - - - - - http://www.tntTint.net
CynicalWry is offline   Reply With Quote
Old 06-30-2003, 01:27 PM   #16
rhuss2
My Ride: 1999 328i
Has anyone gotten a 2002+ radio installed on a 99?
Anyone found the adapter or a way to get a 2002+ CD Radio installed on a 1999?
