Sponsored by BAVSOUND
Old 06-30-2003, 03:57 AM   #1
daz
My Ride: 2003 Bmw Coupe 330ci
Send a message via AIM to daz
Low pass converter.
Just wondering if I need a low pass converter? Going to replace front components and put two 5.25 mids/subs in the back and remove OEM amp.. and put a new 4 channel a/b 75 per channel amp in the back.
Do I need a low pass converter?
daz is offline   Reply With Quote
Old 06-30-2003, 04:15 AM   #2
kb756
My Ride: pinto
Without a new Headunit, yes u will need a hi/low convertor. Splice a wire to one of ur speakers and hook the hi/low to it and from that to ur amp/amps. Get a really good hi/low because cheap ones will give u distortion.
kb756 is offline   Reply With Quote
Old 06-30-2003, 04:47 AM   #3
daz
I am confused? I will be removing the OEM AMP and Speakers and repalcing everything except head unit. DO you mean I attache HI/Low converter to headunits output?
please advise...
Old 06-30-2003, 12:27 PM   #4
millst
My Ride: BMW 330i
You should get a ven4. Read the E46 stereo saga.
tm
millst is offline   Reply With Quote
Old 06-30-2003, 01:08 PM   #5
VALMONT
The De46vil's Army
VALMONT's Avatar
My Ride: 325Ci, Passat
Send a message via AIM to VALMONT Send a message via MSN to VALMONT
high/low converter takes your speaker output wires and turns them into RCA's, better signal and cleaner install
VALMONT is offline   Reply With Quote
Old 06-30-2003, 02:14 PM   #6
kb756
My Ride: pinto
If you are going to remove everything but the HU, u still have to find some kind of source signal. I believe you would still have to find a speaker wire and tap into that.
