Old 11-11-2008, 08:07 PM   #1
tanzi
My Ride: 02' 325i
2 Codes P2096, P0313
My car is throwing these two codes. The P2096 i realise is the post cat O2 sensor on the bank 1 manifold which i will replace.
The P0313 is the missfire with low fuel level. What is causing this?
My search for the P0313 shows that people who throw this code usually are throwing a ton of other codes so i dont know if i have the same problem.
FYI, all this started happening after i replaced the intake boots.
tanzi is offline   Reply With Quote
Old 11-11-2008, 08:50 PM   #2
tanzi
My Ride: 02' 325i
Any thoughts? MAF perhaps?
Old 11-11-2008, 10:43 PM   #3
tanzi
My Ride: 02' 325i
bump
Old 11-12-2008, 01:44 PM   #4
tanzi
My Ride: 02' 325i
bump, need some help
Old 12-07-2008, 01:43 PM   #5
tanzi
My Ride: 02' 325i
Update:
changed the MAF, spark plugs, post cat O2 sensor on bank 1. Still getting 2 codes P0313 and P2096
Maybe clogged injectors on bank 1? I have used a couple cans of injector cleaner but no luck.
Thoughts?
Old 12-07-2008, 02:31 PM   #6
peanut_man
My Ride: 2008 335i Sport Pkg
P2096 or P2098 Post Catalyst Fuel Trim System Low Limit
P0313 Misfire Detected With Low Fuel Level
Do you have any other code from PEAKE tool? From the descriptions it seems you are having an issue with the fuel system delivery. Other cheap "normal" maint items you want to look at is changing the fuel filter, it maybe clogged or the pressure regulator in it maybe shot. Keep in mind when a sensor is telling you something that's bad, it doesn't mean the sensor is bad, usually means something else has gone wrong.
Just note that if all else failed, you probably want to get a mechanic check it out. Try not to replace costly items unless you know for sure it's the cause. (that MAF probably costs you some pretty pennies.).
Can you also post the condition of the car and also what mods / maint has been done on it?
peanut_man is offline   Reply With Quote
Old 12-07-2008, 03:24 PM   #7
tanzi
My Ride: 02' 325i
fuel filter was just replaced about 6 months ago. i am really thinking injector problems or maybe fuel pump?
Old 12-08-2008, 08:59 AM   #8
peanut_man
I think you can get the fuel pressure checked. Before starting to replace the part. Let us know how it goes.
Old 12-08-2008, 09:18 AM   #9
jbeurotech
Regional Sponsor
My Ride: 2000 E46 with 254K
Check the fuel pressure and volume. Also do some testing just don't radonly replace aprts you have already spent more that it would have cost to have it diagnosed by a shop or DIY either way test then replace!!!
SUBJECT
MS45.1 Oxygen Sensor Faults 2960, 2961, 2973 and 2974
MODEL
E46 3 Series (All models except 325xi and 330xi)
E60 5 Series (525i, 530i)
E83 X3 (All Models)
SITUATION
Customer complains the Check Engine Lamp is illuminated. Any of the following fault codes may be stored in the DME.
FC 2960 Exhaust Temperature Too High After Catalytic Converter Bank 1
FC 2961 Exhaust Temperature Too High After Catalytic Converter Bank 2
FC 2973 Oxygen Sensor Before Catalytic Converter Bank 1
FC 2974 Oxygen Sensor Before Catalytic Converter Bank 2
CAUSE
The DME Oxygen Sensor internal adaptation is incorrect.
PROCEDURE
Reprogram the DME using DIS CD 39.1 or CIP 13.2 or higher.
Seth Thorson
Service Manager/BMW Tech
JB Eurotech Service "Your Reasonable Dealer Alternative"
General Questions can be sent to appointment@jbeurotech.com
1. Do not argue with an idiot. He will drag you down to his level and beat you with experience.
2. Light travels faster than sound. This is why some people appear bright until you hear them speak.
jbeurotech is offline   Reply With Quote
Old 01-01-2013, 03:42 PM   #10
dino71
My Ride: 2003 BMW 330i
I had the same codes as the OP but I still can not seem to get rid of that blasted P2096 code. I replaced the water pump, thermostat and fuel filter and I cleaned the MAF and that got rid of P0313 (which I had twice...go figure) and P1619. My next step is to try and examine to see if I have an exhaust leak. If anyone has a possible fix for the P2096 then please post it.
dino71 is offline   Reply With Quote
Old 01-04-2013, 11:21 PM   #11
dino71
Can a really bad valve cover gasket that's leaking cause the P2096?
Old 11-12-2015, 07:20 PM   #12
cory80jacobsen
My Ride: 2003 BMW 325xi
I am having the same problem with the p2096 code, becoming a real headache trying to get this thing to go away. I replaced the O2 sensor post cat on bank 1 and that did nothing. Also put in a new MAF that did nothing. So before I go sinking anymore money into sensors that aren't bad some advice would be appreciated. I recently bought the car with the service engine light on for the cam position sensor I replaced that and the code went away not problem then a few days later p2096 shows up and doesn't want to leave. Car has 125k on the clock and runs flawlessly no rough idle starts right up and runs smooth cold or warm. This is why I thought it would be a sensor because there are no issues with the car running, if it were lean like the code says it would make sense that it runs like crap, but it doesn't. I also looked it over for intake leaks and I'm not seeing anything that looks suspicious. I looked for exhaust leaks quick I can't hear anything that sounds like an exhaust leak, everything seems to be in order. Really scratching my head on this one any advice or ideas of what to look for would be greatly appreciated.
cory80jacobsen is offline   Reply With Quote
Old 11-12-2015, 07:25 PM   #13
jfoj
My Ride: 330CiC, M5, X5, E93
Suggest you start your own thread on your problem, this thread has was last worked 2 1/2 years ago and the specific information DOES NOT apply to your engine.
Post exact codes, Freeze Frame data and KEEP your original MAF, it may be wise to reinstall it.
