Automatic transmission thermostat - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 11-11-2008, 09:31 PM   #1
simmons797
My Ride: 2001 325i
I was in the process of changing the expansion tank on my '01 325 when I broke the transmission thermostat. It's going to be a couple of days before I can get a replacement so I'm wondering if it will ok to drive without. My thinking is that without the thermostat coolant will be continuously circulating which will cause the ATF to take longer to reach operating temperature. Is this bad for any reason? Is there anything else that I'm not thinking of?
simmons797 is offline   Reply With Quote
Old 11-11-2008, 11:54 PM   #2
Lbert
My Ride: 325i
Remove the thermostat, you do not want the possiblity of any broken pieces floating around. Partially cover the transmission radiator with alumimum foil and strap it in place with tie wraps so it does not dispate heat as well as normal. Replace the thermostat as soon as the part arrives.
Lbert is offline   Reply With Quote
Old 11-11-2008, 11:55 PM   #3
GRIDLOCK
My Ride: E36 / E46
If you're not going to be hell on wheels right out of the gate, you should be fine. Just take it easy til you get the new thermostat in there.
Have an EVAP code? Replacing gas cap did not fix? Give me a holler, I can do a smoke test for ya.
GRIDLOCK is offline   Reply With Quote
Old 11-12-2008, 11:11 AM   #4
simmons797
My Ride: 2001 325i
Thanks for the replys.
Lbert I'm not sure I'm following what you are suggesting. I don't think there is a separate transmission radiator like some cars have. Do you mean the heat exchanger? If so I don't think covering it with foil would do anything.
Anybody else have an opinoin?
