#81 |
Nice. Didn't know they made those.
mujjuman
![]() 2003 325xi 5MT Jet Black, ZSP, ZPP, ZCW, OEM Xenon ^^RIP sig by Solidjake |
#82 |
Banned User
So , does 323 software run the b30 ? I imagine you'd loose quite some hp due to different IGN/fuel curve.
I remember reading the MAF can adapt up to 30% in air flowrate change , which would explain why the b30 works with stock injectors (2,5+0,5/2,5= 20% increase) |
#83 | |
i'm trying to figure out if a shark injector for 330 would do the trick
mujjuman
#84 |
Banned User
#85 |
You are right, but I dont want to go SC... at least not yet. And probably not anytime in the foreseeable future (starting med school, then 4 years of schooling, then after graduation I plan on getting rid of this car)
mujjuman
#86 | |
m3 engine wire harness ews keys dme cluster tranny driveshaft complete subframe dsc module fuel pump radiator ^ is the correct way..so yes basically an m3...plus most aftermarket suspension is better than oem m3
![]() -oem m3 front -oem m3 hood -oem m3 sideskirts-conforti intake -h&r race springs -TR Motorsport C2's -smoked corners/sidemarkers -smoked LED tails-CF CSL trunk-Black roof vinyl Last edited by E46 S54B32; 06-30-2010 at 11:24 PM. |
#87 |
You are right, that is the correct way. Personally I would just buy a E46 M3
mujjuman
#88 |
i am in... just need my 323 engine to die so my wife wont see this as just an upgrade.
UUC Shortshift w/ DSSR, UUC RK6A-L Shift Knob, Staggered 18" Breyton's Inspirations, Smoke Corners, 76" Dual Tip Remus Catback, Conforti CAI and Shark Software, H&R Sport Springs and Sway bars, and Bilstein Sports Shocks, 3.46 diff, UCC Pulleys.
#89 |
so can it be done? where is the clarification at? how much? Why is it so hard to find a write up? if some one could prove it and show facts and kits were available. these cars would value so much more if the swaps where here!
#90 |
Nope sorry can't be done
Just kidding. Just read the thread bro
mujjuman
#91 | |
using the 323 intake you are losing hp.
![]() Have a oil or coolant leak? Click here!:http://forum.e46fanatics.com/showthr...732&highlight= ABS/DSC/Brake/Airbag light on?? Click here!:http://forum.e46fanatics.com/showthr...648&highlight= |
#92 |
yeahh thats what i figured but the DBCable to DBWire swap is tricky... no?
mujjuman
#93 |
My Ride: 2001 325Ci
Hi,
Any chance you could PM me some photos of the conversion? I have a 323Ci, and would be looking at performing this swap in the future. Was it a straight swap? Does the 3.0L motor bolt straight up to the 5speed manual gearbox in the 323Ci? So no electrical equiptment needed to be changed? (i.e. ecu etc.) Cheers mate. |
#94 | |
Banned User
Or you could just use your old ones... |
#95 |
You'll lose a good amount of power using a TU manifold vs a B30 one.
#96 |
Bolts right up
Use Maf and injectors from 323 tho until you update your dme
mujjuman
#97 |
My Ride: 2001 325Ci
And then i guess if you do a 3" exhaust system with no cats, like i have on mine now, you will gain some power. Also do a CAI
#98 |
#99 | |
Intake manifold stays the same. I still didn't flash my ecu for the 330
mujjuman
#100 |
This thread should be stickied
| Tags |
| 323ci, 330ci, m52, m54, swap |
