From Auto-X to Trackday to Racing and Professional Motorsports – this is the place to discuss making BMWs fast
Old 11-13-2008, 02:58 PM   #1
tim330i
E46Fanatics Owner
tim330i's Avatar
My Ride: 03 Ti Silver M3
BMW Sauber F1.08 Chassis Over the Course of the Season
THE BMW SAUBER F1.08 CHASSIS OVER THE COURSE OF THE SEASON
Munich/Hinwil - There is a rule of thumb in Formula 1: Standing still means going backwards. Vehicles change from race to race. The engineers are continually modifying the vehicles depending on the characteristics of the different circuits – the extremely long straights in Monza require a different aero package than the tight and slow corners in Monaco. Willy Rampf, the Technical Director of the BMW Sauber F1 Team, uses a selection of technical drawings to describe the constant change undergone by the BMW Sauber F1.08.
BMW Sauber F1.08, Car Launch, Munich, January 2008
Willy Rampf: “The elimination of traction control meant that the cars would be more difficult to drive. Our goal was therefore to build a stable car with precise feedback at the front axle and lots of grip at the rear axle, in order to make the driver’s job easier. As far as aerodynamic efficiency was concerned, we wanted to take a significant step forward by comparison with the F1.07. We were able to achieve this objective by a number of measures including a special, compact engine cover. We opted for a very dominant front wing, the great potential of which allowed us to compensate for the entire range of different weight distributions. The vent chimneys combined with the lamellar outlet vents to permit good cooling without significant disadvantages for aerodynamics even under extreme conditions. By contrast with the rim covers, the Tomcat wings on the car’s nose and the vertical sidepod reflectors were not fitted to the car for the presentation.”
BMW Sauber F1.08, Melbourne, March 2008
Willy Rampf: “We optimized lots of details in the car during extensive winter tests and hence made good progress. However, only some of these modifications were visible. The newly mounted Tomcat wings influenced the air flow round the cockpit and therefore improved the aerodynamics at the rear end. The vertical sidepod reflectors calmed the air turbulence around the front wheels and ensured maximally harmonious flow of air along the sidepods. The under body benefited from this, in particular the diffuser. A minor modification to the tuning vane was also working towards the same goal. The monocoque wing conducted the air flow downwards, particularly from the mid-section of the front wing. The rim covers were not used in Melbourne because they changed the balance of the vehicle in a way that did not match the characteristics of this circuit.”
BMW Sauber F1.08, Monaco, May 2008
Willy Rampf: “Monaco demands maximum down force. This means that parts are used where the aerodynamic efficiency is not particularly good, but which generate additional down force. That is the circuit with the lowest average speed and down force therefore has maximum priority there. We used the front wing with maximum down force potential. The modified synchroniser retainer plates with the top deflectors combine with the flap to exert significant influence on the flow of air around the front tyres. There was also a small T-wing for more down force on the so-called batman in front of the rear wheels. The rear wing with the steepest wing position and maximum tread pressure was used. This was also mounted over central supports on the gearbox. We used rim covers in a modified version for the first time, which also generated additional down force.”
BMW Sauber F1.08, Montreal, June 2008
Willy Rampf: “Together with Spa, Montreal is the only medium-downforce circuit. The aerodynamic efficiency plays a very special role here. We used a front wing with smaller, modified flaps. The Tomcat wings also had to give way in favour of lower drag. The rear wing was again mounted on central supports and represented a new development. We also adapted the rim covers to the special requirements. No other circuit puts such a strain on the brakes as Montreal and we therefore paid particular attention to optimum cooling. Our one-two victory was not only the reward for the racing team on the track but also for all those people who are responsible for the development of the car in Hinwil and in Munich.”
BMW Sauber F1.08, Monza, September 2008
Willy Rampf: “Monza is the only genuine high-speed circuit left in the calendar. We therefore used a low down force aero package which was deployed exclusively at this venue. The main focus is on reduction of the drag. We accepted a thirty-percent loss of down force compared with Monaco and used a completely different front wing with only two elements. While the Tomcat wings were omitted, there were two additional wings on the monocoque, known internally as Manta Rays, which conducted the air flow optimally over the engine cover and hence improved the effect of the rear wing. The side wings on the engine covers were omitted for reasons of drag. The rear wing was very different from the other versions which were used in the course of the season. It had a strikingly small main element and a much bigger flap with serrated Gurney. The synchroniser retainer plates with a clearly defined cut-out were striking. They ensured a stable air flow when cornering.”
Rear wing, Canadian Grand Prix, June 2008
Rear wing, Italian Grand Prix, September 2008
Front wing, Car Launch, January 2008
Front wing, Monaco Grand Prix, May 2008
Front wing, Canadian Grand Prix, June 2008
Front wing, Italian Grand Prix, September 2008
tim330i is offline   Reply With Quote
Old 11-13-2008, 05:51 PM   #2
mcr_driver
My Ride: my favorite two feet
sick pics tim where did you get them?
mcr_driver is offline   Reply With Quote
Old 11-15-2008, 09:35 PM   #3
mikechungs330
My Ride: 330i
Honestly....
Great post, these guys are on top of everything.
mikechungs330 is offline   Reply With Quote
Old 11-17-2008, 04:24 PM   #4
tim330i
E46Fanatics Owner
tim330i's Avatar
BMW Press group
Glad you guys like this info, I love seeing how much work they do during the season.
Tim
