Thread Tools Search this Thread Rating: Thread Rating: 21 votes, 5.00 average. Display Modes
Old 01-02-2009, 11:11 PM   #21
LABMW13
My Ride: M3, 330i, '89 325i
Originally Posted by Bimmer Dude Xi View Post
Nice job. I would put a little scoop at the bottom of the tube to draw in air directly.
Originally Posted by Custom3 View Post
thats pretty cool...A+ for effort ....i would put like a L shaped tube on the bottom of the pipe...this way air will actually be forced up the tube.
Yeah that's a good idea
Originally Posted by romelio View Post
nice work!
Thanks!
Originally Posted by TrippinBimmer View Post
Did the intake sound get any louder?
It was a bit louder, then i took out the sound shield from under the hood and its definitely noticeably louder
Originally Posted by tiggaatl View Post
A water sock is just something that keeps water out of the intake while allowing air to pass through. I have one on my K&N intake. Instead of opting for the screen, i would have gone with some kind of low density foam as a filter. I'm sure it would do a better job of keeping debris out of the tube as well as limit the amount of water that would enter in case of snow or rain.
Nice, I'll have to get one...I never knew of these.
M3: SSR GT3 Wheels, H&R Coilovers, JL 12" W6, Eisenmann 83mm, SS Headers, 4.10's, CF CSL Trunk & Diffuser, Euro Front Bumper, Hamann CF front lip, 3000k Fogs, NX 125 Shot
UUC Parts: SSBC Brakes, Lines, Sway bars, 8LB Flywheel, twin disc clutch, Evo 3 Shifter, RK7A Shift Knob, CF E-brake, Rasp-X Mid Pipes
Coming Soon: VRS Vented Race Hood & VCSL CF Roof Panel
LABMW13 is offline   Reply With Quote
Old 01-30-2009, 01:54 AM   #22
Brinkley
My Ride: 99 328i, 07 z4 3.0
dont forget the oil sock. it's a replacement for you oil cap. works wonders.
Brinkley is offline   Reply With Quote
Old 02-21-2009, 02:23 AM   #23
330CI_DROOLER
My Ride: bimmer?
I hope that this thread is still active, regarding the water sock, is this the correct one?
http://www.sfxperformance.com/parts/INJX1034R.htm
330CI_DROOLER is offline   Reply With Quote
Old 03-26-2009, 11:51 PM   #24
330CiC2001
My Ride: 01 330CiC
I have a question about these CAI projects and cones and flat filters....etc.. what would be better this method like he did (except if I was to do it I would tilt the tubing L for the air to be sucked in) or just pop in a cone filter no shield no nothing?????? b.c this way the filter is inside sealed with the factory box and if you bought a K&N flat filter it would be better, but I just want to know what yall tink. or is the cone better f*** the shield????
Detailed Image Auto Detailing Supplies
330CiC2001 is offline   Reply With Quote
Old 05-23-2010, 05:05 PM   #25
TwoDuckDad
My Ride: 2001 330xi jet black
Thought this thread deserved a 2010 bump.
TwoDuckDad is offline   Reply With Quote
Old 05-24-2010, 09:58 PM   #26
turtzilla
My Ride: 04 325ci
yes it did! Im trying it out..
turtzilla is offline   Reply With Quote
Old 06-28-2010, 11:08 AM   #27
330exeye
My Ride: 2004 330xi
I've run modded airbox on all my cars and wasn't sure If I'd be able to pull it off on the 330, but its refreshing to see its possible. as for the water sock, I wouldn't worry about it as their are two holes in the airbox, the (i've always used dryer ducting 3") ducting goes to the front lower bumper and if ever submerged, it won't suck up water because of the second opening. its like a straw with a hole in it, I've always had two wholes in the box for that reason. I was just about to buy a short ram with a heat shield but this will have the same effect and usually results in the same intake growl. think I know what im doing this weekend
330exeye is offline   Reply With Quote
Old 06-30-2010, 11:59 PM   #28
junkiekommando
My Ride: 02 330i, 91 318is
i will try it this weekend.
junkiekommando is offline   Reply With Quote
Old 07-01-2010, 07:09 AM   #29
Snik
Snik's Avatar
My Ride: IR M3 Vert.
hmmmmmmm
Do you ride a sportbike?
Old 11-09-2010, 04:59 PM   #30
2001bimmer330i
My Ride: 2001 BMW 330i
I love this mod. Low-tech but works.
2001bimmer330i is offline   Reply With Quote
Old 11-09-2010, 05:13 PM   #31
eric_waltrip
My Ride: 2000 blk 323ci 5spd
I did that with a k and n drop in
Sent from my iPhone using BimmerApp
I road in my buddies with 350hp and he switched highways at wot scared tge piss out of me felt as fast other bodies 500hp supra awesome car they are rare hopefully they will bring them back rx8s r ok but I don't like tge rear doors and odd shape and lackbof turbos
eric_waltrip is offline   Reply With Quote
Old 01-24-2011, 12:30 AM   #32
CarbonFanatic
My Ride: 323I
Nice write up, I saw this and I want to do this as soon as the snow dies away.. You said you got better mpg, how much have you gain since you did this mod?
CarbonFanatic is offline   Reply With Quote
Old 01-24-2011, 09:43 AM   #33
My Wifes 330i
My Ride: White 330i, Outback
I'm thinking the Lg shop vac hose and then if you wanted a scoop you could get the piece for sucking up fluid. It is fairly sleek. and may be easily fitted. The whole thing would slide together and perhaps look more OE.
My Wifes 330i is offline   Reply With Quote
Old 01-27-2011, 05:57 AM   #34
e36-2.0
My Ride: 330xi
anyone know where you can find similar materials and parts that DINAN uses for thiers.
http://forum.e46fanatics.com/showthread.php?t=818676
'02 330xi
Konigsport/Ground Control/DPE/BMW Motorsport/Eurosport/Turner Motorsport/PowerFlex/RacingDynamics/Hotchkis/UUC/Beisan/Bimmerworld/Dinan/Conforti/RPI/GroupN/Technik/Dynavin
Alberta's BMW enthusiast forum.
-Projecttechnik.com
e36-2.0 is offline   Reply With Quote
Old 01-27-2011, 11:05 AM   #35
gaby1088
My Ride: 993
i did this, i didnt think it helped but oh well it was worth the try. It does sound growlier.
Pictures by boligrafo123 & ///OSS
gaby1088 is offline   Reply With Quote
Old 03-14-2011, 01:44 PM   #36
afghiranian
My Ride: 99' e46 328i
sorry for bringing this thread back to life
i did this and i didnt get any results? didnt even sound gorwlier like it usually does when you chop up your airbox... i did use a 1 1/2 inch pipe instead but i wouldnt think that it would result in no results?
afghiranian is offline   Reply With Quote
Old 03-19-2011, 09:43 PM   #37
Optio
My Ride: 328i
I did this a couple years ago and used Dinan parts. Just call them up and order the third air intake tubing kit. I think it was like $55.00...... Expensive, but it is very factory in fit and appearance. I also used an E36 inline six air filter that is deeper than the E46. I do detect a bump in power from this mod.
Optio is offline   Reply With Quote
Old 10-05-2011, 11:22 AM   #38
AkeemOfKings
My Ride: 02- 330ci
Bump.
AkeemOfKings is offline   Reply With Quote
Old 03-17-2012, 10:43 PM   #39
mattfarrington
My Ride: 04 325xi
I totally understand I'm bumping a thread that is SO old...
BUT!!!!
I read it and instantly ran to autozone, and grabbed some 3" tubing.
I'll be doing this in the morning, and I'm pumped. One thing I might do though, is instead of having it go through the splash shield.. Retrofit some kind of "scoop" in the middle of my bumper to scoop some air in right there, as it'd be more forced. I'd rather not mess with the brake duct's as they do serve a purpose. lol
But I'll be doing this tomorrow morning as it'll be FINALLY some nice weather up here in New Hampshire.
But thanks so much for the write-up. I can not wait to try this out!
ALSO!!!
I noticed you said you took out the shield?
"It was a bit louder, then i took out the sound shield from under the hood and its definitely noticeably louder"
What shield may this be? I want more sound! haha
mattfarrington is offline   Reply With Quote
Old 03-21-2012, 11:52 AM   #40
325i'02
My Ride: 2002 325i
BUT!!!!
ALSO!!!
This will be my weekend project. I am going to fix it behind the grill of the bumper. I think actually Lowes has 3 inch scoops in their air conditioning pipes section. This might snug easily behind the grill. Any way to take the grill out without the bumper?
M - One letter, one dream!
325i'02 is offline   Reply With Quote
