Old 11-17-2008, 01:30 AM   #1
bigjae1976
bigjae1976's Avatar
My Ride: 2011 E90 M3
Brake fluid and soft pedal
I just completed my first driving school and it was awesome! I'm kicking myself for waiting so long.
Anyway, I have the UUC/Wilwood BBK upgrade. I ran with street pads and 8 month old ATE blue brake fluid.
This is probably a stupid question but on the third session, I my brakes suddenly got mushy. I checked after the session and I still have about 1/2 of the front and 3/4 of rear pads left.
So I am guessing that this is a brake fluid issue, correct?
2013 F30 328i - Melbourne Red
2004 E46 M3 - Imola red
bigjae1976 is online now   Reply With Quote
Old 11-17-2008, 05:01 AM   #2
mkodama
mkodama's Avatar
I would also guess it's the brake fluid since it only happened after prolonged use.
8 months isn't too long, but over that time your brake fluid is going to absorb small amounts of water and its boiling temperature is going to go down...
From my experience, overheating the brake fluid gives a mushier feeling to the pedal while overheating the brake pads makes them smoke an lose some of their bite.
Old 11-17-2008, 09:04 AM   #3
bigjae1976
bigjae1976's Avatar
Thanks! When I first started, I couldn't believe how badly I was beating on my car. I felt bad for her and was sure she would be mad at me later.
I guess the lesson here is to bleed your brakes and bring some fresh pads before you go to the track.
Old 11-17-2008, 09:13 AM   #4
Lemonsqr
My Ride: 2001 TiAg 330i
Originally Posted by bigjae1976 View Post
Thanks! I guess the lesson here is to bleed your brakes before you go to the track.
Well if by "bleeding the brakes" you mean doing a complete brake fluid change, then yes. Getting rid of just some of your old brake fluid will not help the absorbed water or boil over problem. Usually "flush" = complete change of brake fluid and "bleed" = getting all the airbubbles in the brake line out. OK, I'll get off the soapbox.
Lemonsqr is offline   Reply With Quote
Old 11-17-2008, 09:24 AM   #5
bigjae1976
bigjae1976's Avatar
I meant flush.
Old 11-17-2008, 12:36 PM   #6
aggieE46
Keep it clean
aggieE46's Avatar
My Ride: 03 Evo, 07 Passat
Glad you had a good time! I'm a bit jealous.
Did you ever get your CEL taken care of? How was the twinscrew on the track?
Old 11-17-2008, 01:40 PM   #7
flacoy2k
My Ride: 2002 M3
I think the problem was your street pads. Yes it is true that fresh fluid meaning a flush a week or two before the event is best but 8 months old fluid should not be all that bad. Next time change your pads to a racing pad and it will be a night and day difference.
flacoy2k is offline   Reply With Quote
Old 11-17-2008, 02:22 PM   #8
teamdfl
Slow in, slower out
My Ride: 325it
...8 months isn't too long, but over that time your brake fluid is going to absorb small amounts of water and its boiling temperature is going to go down...
8 months is too long according to every driving school tech inspection form I have seen in 10+ years of track experience. Every BMWCCA, PCA, and SCDA tech form I have filled out has required a brake fluid fluid flush withing 6 months of the track day.
You might be exceeding the capability of the street pads. You may also have knocked loose some random air bubbles from the last brake fluid change. Do a good fluid flush with a pressure bleeder or via the MODIC or GT1 computer at the dealer. Then go out and get the brakes VERY hot on a lightly traveled stretch of highway to see how they react.
Mod the driver. Participate in your local BMWCCA autocross or driving school. Have you joined BMWCCA yet?
teamdfl is offline   Reply With Quote
Old 11-17-2008, 02:46 PM   #9
vaio76109
My Ride: Race Cars
Flush the brakes and get some real track pads.
vaio76109 is offline   Reply With Quote
Old 11-17-2008, 07:53 PM   #10
bigjae1976
bigjae1976's Avatar
Nope, still have the CEL. I think I need a new MAF but I'm not getting my hopes up that is the only issue. I'm going to drop it off at my shop before I go to Korea. Then they'll have 14 months to fix it.
The s/c was bad@ss! Too bad I couldn't take advantage of all the power since my skills are still not that good and my brakes went soft the first day. The only thing I couldn't catch up to on the straights were the vettes. The car would definitely shoot out of the corners pretty quickly and really didn't have to shift a whole lot. I'm sure an LSD would help a lot.
Thanks for the info. I definitely underestimated the beating my car would take. I guess somewhat worn street tires didn't help either.
So my plan is to first flush the brake lines with some Motul RBF600 fluid.
As far as track pads, what would be a good option? I'm not trying to spend an arm and a leg and plan to track the car 2-3 times per year.
UUC's website lists:
Pagid
EBC
Hawk
Performance Friction
Wilwood PolyMatrix
Carbotech
Old 11-17-2008, 08:08 PM   #11
vaio76109
My Ride: Race Cars
PFC-01's are the best pads I've used yet, but they're pretty pricey. I haven't used PFC06's yet, but they sound like they'd be a very good choice for you.
Old 11-30-2008, 11:11 PM   #12
bigjae1976
bigjae1976's Avatar
Dumb question...those are performance friction, correct? Thanks for the input. What do you think of the Hawk DTC70's?
I just flushed my lines, what a difference! The blue brake fluid that I bled looked navy blue. I guess it was time. There still is no bite and I am just waiting on the pads to arrive.
Old 11-30-2008, 11:59 PM   #13
delirium45
My Ride: 2004 M3
Yes, PFC-01 is Performance Friction's most aggressive track pad currently. The PFC-06 is similar but less torque and is designed to last longer, good for enduro racing (ie: 13hour+ races).
I ran Hawk HP+ in my 330i, they did pretty well, but if you have a supercharger you may be going a lot faster... i tried the HP+ on my M3, and they just laughed at me when i asked them to stop me. I will be dressing with PFC-01 for next season.
As far as fluid, superblue is just fine, do a full flush, i use a pressure bleeder to flush, then have someone pump the pedal afterwards and do a final bleed with them, this usually gets everything old and bubbly out.
Good luck !
_ Garrett
2011 Rocky Mountain Region GTS4 champion & "Rookie of the Year"
2012 Rocky Mountain Region GTS3 champion
Thanks Sponsors: SCR Performance & Built-by-Bones
delirium45 is offline   Reply With Quote
Old 12-01-2008, 12:19 AM   #14
vaio76109
My Ride: Race Cars
Yes, Performance Friction. I haven't used the DTC-70's, although I did use HT-10's for a while. For a first track pad they're decent, but PFC-01's really blow them out of the water. It's one of those things that you don't know what you're missing until you try it.
Old 12-01-2008, 09:15 AM   #15
bigjae1976
bigjae1976's Avatar
Good luck !
The PFC-01s don't seem to unreasonable. I think that's what I will be ordering. Thanks for the info.
