Thread Tools Search this Thread Rating: Thread Rating: 38 votes, 5.00 average. Display Modes
Old 11-20-2008, 10:26 PM   #1
mkodama
mkodama's Avatar
Valve Cover Gasket Change!
Finally got around to changing my old leaky valve cover gasket. Really easy to do, just time consuming. Didn't quite finish today since I ran out of time. And yes, I know the engine bay is dirty, it's gonna get cleaned up once the car is painted and out of this shop.
Removing the cabin micro-filter:
Twist the three knobs 90 degrees counter clockwise and they will pop up. Lift the cover up and out.
Remove the micro-filter, it is just sitting there.
Undo the 4 gold torx bolt and 4 plastic wire harness clips. The torx bots use a T30 torx bit.
With the wire harness clips undone the lower part of the wire holder comes off. Pull the wires down out of the holder. Lift the micro-filter tray up and towards the front of the car.
With micro-filter and housing removed.
Removing Cosmetic Engine Covers:
Pry out the bolt/nut covers using a flat head screwdriver.
Remove the oil cap and undo the two 10mm bolts and two 10mm nuts and remove the cosmetic engine covers.
Removing Ignition Coils and Harness:
Slide the metal clip of the ignition coils using your fingers, and then pull the electrical connector out of each coil.
Remove the 12 10mm bolts holding down the ignition coils. Then just pull each coil out and set them aside.
Undo the small brown grounding wire and move the ignition wiring harness over to the side and out of the way.
Engine with coils removed and ignition wiring out of the way.
Removing Wiring Attached to Valve Cover:
Remove the wires and tubes from the metal clips.
Remove the two 8mm bolts and grounding straps.
Removing Crankcase Vent Tube:
Squeeze the top and bottom of the crankcase vent tube and pull off the valve cover.
Removing the Valve Cover:
Remove all 15 nuts along with washer and seal.
This is what happens if you repeatedly start up your car, drive it 50 feet, and then turn it off before the car warms up. Condensation mixes with the oil and you get this kinda oily foamy mixture. I suggest you clean your valve cover, remove the old gaskets, and then put in the new
No sludge, so I'm happy.
This is where my leak was.
Happy looking camshaft lobes. Not bad after 74,000 miles.
Assembly is reverse of disassembly. Also make sure you don't clamp any wires underneath the valve cover during reassembly like what I did. And don't over-tighten the valve cover bolts.
Old 11-20-2008, 10:30 PM   #2
00bmw323
My Ride: 00 323/91 integra RS
Nice job! i gotta do this soon..I just started to smell Oil burning
-Jorge
All low no go
00bmw323 is offline   Reply With Quote
Old 11-20-2008, 10:37 PM   #3
DesertMotorWorks
Past Site Sponsor
My Ride: 2004 330CI
Very nice write-up!
DesertMotorWorks is offline   Reply With Quote
Old 11-20-2008, 10:42 PM   #4
kuksul08
My Ride: M3
Nice job, shoulda gone in the DIY forum
Look at that subtle jet-black coloring. The tasteful thickness of it. Oh my God, it even has a 6mt.
S54 Valve Adjustment Spreadsheet & Info: http://dl.dropbox.com/u/28231781/S54...ent%20info.zip
S54 VANOS DIY Video: http://www.youtube.com/watch?v=9SkT2j3jsU0
kuksul08 is offline   Reply With Quote
Old 11-20-2008, 10:51 PM   #5
mkodama
mkodama's Avatar
Originally Posted by DesertMotorWorks View Post
Very nice write-up!
Thanks for the valve cover gasket Ruben! Couldn't have done it without you.
Old 11-21-2008, 12:42 AM   #6
MATT200MPH
Past Site Sponsor
My Ride: E46 328i Sedan
Send a message via AIM to MATT200MPH
very well done. and a a good thing to add too the list of DIY lots of pictures! good work!
MATT200MPH is offline   Reply With Quote
Old 11-21-2008, 12:48 AM   #7
JK1150
My Ride: 2004 325CI
i got mine changed at 65k per BMW's recommendation. Only $100 under extended warranty so whatever, but I thought these things were supposed to last a lot longer...
JK1150 is offline   Reply With Quote
Old 11-21-2008, 01:00 AM   #8
DesertMotorWorks
Past Site Sponsor
My Ride: 2004 330CI
Welcome!
Old 11-21-2008, 02:04 AM   #9
mkodama
mkodama's Avatar
I got my valve cover gasket for less than half of that including shipping from Desert Motor Works, but of course it takes time to replace it.
Most rubbers deteriorate with exposure air, heat, and oils. I didn't even need to replace mine since I had no smell of oil nor did I ever have to top off on oil between changes. I probably could have gone to 100,000 miles. But as I said, it's really easy to change these out. The most exotic tool I needed was a T30 torx bit and the most time consuming part was cleaning the valve cover.
Old 11-21-2008, 05:30 AM   #10
Joey325Ci
My Ride: Black Fred
Nice Job and great pics !!!
I will be doing this sometime durring the week, I just got my parts delivered
Joey325Ci is offline   Reply With Quote
Old 11-21-2008, 07:45 AM   #11
chrisca70
My Ride: The Wayward Wagon
Wow your cover was a lot dirtier than my 137K, excellent job on the pics!!
chrisca70 is offline   Reply With Quote
Old 11-21-2008, 10:14 AM   #12
pMak26
My Ride: '99 M3, '07 r6
you did not use any RTV anywhere?
Did mine yesterday with the vanos seals but used RTV (red) on the vanos half moons and edge where vanos unit and head mate up.
Plan to be spontaneous tomorrow.
Base (SuperFlo Dyno: 211whp/199.5wtq)
Then S52 turbo, 442whp
Now LSx
pMak26 is offline   Reply With Quote
Old 11-21-2008, 10:24 AM   #13
GDA
My Ride: M5, 325i and 330i
Perfect timing. I am going to be using this next week when I got some time off to pull the cover and change plugs and O2 sensors.
Props for a well written DIY.
Mods - this should be added to the DIY sticky in the DIY section.
GDA is offline   Reply With Quote
Old 11-30-2008, 09:47 PM   #14
nitro3421
My Ride: 01 M3 TIAG
Send a message via AIM to nitro3421
awesome write up, thanks!!!!
-2011 M3 Competition Package 6MT
-2011 F250 6.7 Diesel King Ranch
-1969 Toyota Landcruiser FJ40
-2011 BMW 128i
-1972 Chevelle - sold
-1996 328i - sold
-2002 330i - sold
-2001 M3 - sold
-1995 M3 - sold
nitro3421 is offline   Reply With Quote
Old 12-01-2008, 12:12 AM   #15
mkodama
mkodama's Avatar
Nope, I didn't use any RTV. You are supposed to use it around the sharp edges of sealing surface near the end of the camshafts. I opted not to out of personal preference. No problems so far, but I haven't driven my car much.
Old 12-01-2008, 12:13 AM   #16
mkodama
mkodama's Avatar
My car has been sitting in a friend's auto restoration shop for like a year now.
Old 12-01-2008, 12:16 AM   #17
Patman015
My Ride: 05 Honda S2000
Nice nice, hope you have a nice torque wrench
Patman015 is offline   Reply With Quote
Old 12-01-2008, 12:38 AM   #18
mkodama
mkodama's Avatar
I actually didn't use a torque wrench at all for the entire process. I used a small ratchet and that's all. But I was very very careful not to over tighten the valve cover. There is a moderate amount of resistance as you tighten the valve cover onto the gasket, but after a little bit of that it gets a lot harder to turn and that's where I stopped. Maybe 10 ft/lbs for torque? Maybe less?
Old 12-01-2008, 12:39 AM   #19
Patman015
i was gonna say yea...probably inch lbs lol
Old 12-01-2008, 04:11 AM   #20
Breyton-BMW
Breyton-BMW's Avatar
My Ride: Ti
Send a message via AIM to Breyton-BMW Send a message via Yahoo to Breyton-BMW
Good diy.
Breyton-BMW is offline   Reply With Quote
