Thread Tools Search this Thread Rating: Thread Rating: 38 votes, 5.00 average. Display Modes
Old 12-01-2008, 07:27 AM   #21
peanut_man
My Ride: 2008 335i Sport Pkg
EWWWWWWWWW......
peanut_man is offline   Reply With Quote
Old 12-09-2008, 10:08 AM   #22
Custom3
My Ride: HellRot 330CI
i have the same creamy sludge on my oil...should i replace the oil as well once i put the new gasket?
Old 12-09-2008, 11:02 AM   #23
330ciandr6
My Ride: .
Send a message via AIM to 330ciandr6 Send a message via Yahoo to 330ciandr6
why did u take off the cabin filter assembly? i've done numerous vcg's on e46s and never taken that off.
Have a oil or coolant leak? Click here!:http://forum.e46fanatics.com/showthr...732&highlight=
ABS/DSC/Brake/Airbag light on?? Click here!:http://forum.e46fanatics.com/showthr...648&highlight=
330ciandr6 is offline   Reply With Quote
Old 12-09-2008, 11:58 AM   #24
pMak26
My Ride: '99 M3, '07 r6
why not? cabin filter assembly takes a minute to take off and frees up so much space to work.
Heck, I even pull it off to change the battery!
poor joke... i know
Plan to be spontaneous tomorrow.
Base (SuperFlo Dyno: 211whp/199.5wtq)
Then S52 turbo, 442whp
Now LSx
pMak26 is offline   Reply With Quote
Old 12-09-2008, 12:04 PM   #25
Custom3
lol
poor joke... i know
Old 12-09-2008, 12:22 PM   #26
Score
My Ride: 2002 330Ci
Does anyone know the torque sequence for the valve cover bolts?
Score is offline   Reply With Quote
Old 12-09-2008, 12:39 PM   #27
JSanders
My Ride: Breaks too often
I went from one bolt to the opposite side then the opposite side... ie: top right bolt to bottom left bolt and so forth.
JSanders is offline   Reply With Quote
Old 12-09-2008, 04:36 PM   #28
mkodama
mkodama's Avatar
Probably a good idea to change the oil after a valve cover change.
I really don't know why you wouldn't it's just 4 screws and the rest just slides out and gives you so much more room. I don't get how you could tighten the nuts in the back without removing it.
I'm not quite sure on this either. But I figured since the nuts are tightened down so little and they are tightened on a rubber gasket that it wouldn't make a huge difference. Head bolts on the other hand I would definitely make sure I did this exactly to a service manual.
Old 12-14-2008, 12:20 AM   #29
yogi799
My Ride: 99 328i auto
Here is my 5 cents to this helpful thread. This is my HARD PLASTIC valve cover gasket. I was amazed how hard it got - no wonder I had this bad smell inside the car each time the engine warmed up. No idea how this thing could seal anything anymore LOL.
This job is both relatively easy and cheap (less than $100), so might as well do it before 100k. I waited longer and hence the smell, I believe (oil dripping on exhaust pipes just below).
yogi799 is offline   Reply With Quote
Old 12-14-2008, 01:04 AM   #30
mkodama
mkodama's Avatar
Excellent video!
Old 12-14-2008, 02:07 AM   #31
Anub!s
My Ride: e46 330ci, e92 M
Send a message via AIM to Anub!s Send a message via MSN to Anub!s Send a message via Yahoo to Anub!s
have you done your vanos seals? I really regret not doing that when I did my VCG couple of months ago.
Nice right up bro.
Anub!s is offline   Reply With Quote
Old 12-14-2008, 02:16 AM   #32
mkodama
mkodama's Avatar
Nice right up bro.
Nope, haven't done that yet. I'm gonna try to do it within the next few months before the gasket gets too hard again.
Thanks for the compliments
Old 12-14-2008, 02:18 AM   #33
Anub!s
lol too late for me.
Old 12-16-2008, 12:28 PM   #34
reynaldo
My Ride: 2001 325i Sedan
Send a message via Yahoo to reynaldo
This is a very comprehensive DIY. Outstanding candid shots. I completed mine last year.
reynaldo is offline   Reply With Quote
Old 12-24-2008, 08:57 PM   #35
Whammy
My Ride: ZHP
Great Write-up Miles! Subscribed.
Whammy is offline   Reply With Quote
Old 12-25-2008, 03:55 AM   #36
mkodama
mkodama's Avatar
Old 12-25-2008, 09:02 AM   #37
Rickna
My Ride: '01 330xi - '09 IS-F
Great write up! Would there be any harm in using sea foam in the crankcase before doing the job?
2001 BMW 330xi
2009 Lexus IS-F
Rickna is offline   Reply With Quote
Old 12-25-2008, 08:43 PM   #38
mkodama
mkodama's Avatar
Thanks!
Personally, I see no reason in using seafoam. Just, something unnecessary and a risk of causing engine damage. But I doubt it will make a difference before doing the job, so do as you wish.
Old 12-25-2008, 11:20 PM   #39
Shayn
My Ride: 325ci
How did you get the gunk of your cover?
Shayn is offline   Reply With Quote
Old 12-26-2008, 02:01 AM   #40
mkodama
mkodama's Avatar
Wiped away all the easy stuff with a paper towel. Then it was just a matter of spraying it with a hose, then degreaser, waiting 10 minutes, and repeating. I had to repeat like six times but in the end, it looked like a brand new valve cover.
