Thread Tools Search this Thread Rating: Thread Rating: 38 votes, 5.00 average. Display Modes
Old 04-02-2009, 06:55 PM   #61
q0192837465
My Ride: 99.4 A4, 03 330xi
Send a message via ICQ to q0192837465
Originally Posted by frogg320 View Post
Hey, if it works, it works
I had a little bit of the same baked-on crud on my VANOS unit, I don't think it's anything to worry about. If your VANOS starts to go bad, then you have a problem. Until then, don't worry about it
Also note the lack of chocolate milk in my engine. Here's a closeup of where there isn't chocolate milk:
Unfortunately, I didn't take a picture of the valve cover itself, but I assure you there was no chocolate milk there either
Wow, ur engine is clean. BTW, can u re-use all the screws/bolts/nuts & wut not? Do we need to buy new ones?
q0192837465 is offline   Reply With Quote
Old 04-03-2009, 10:44 AM   #62
frogg320
My Ride: 2000 323i
Yeah, unless they're screwed up (no pun intended) they're fine. I cleaned each one off with a rag before I reinstalled it, you want to make sure the threads are clean before you try to bolt them back in. And new valve cover nut gaskets, obviously...that's actually where my leak started from (although I caught it well before anything was burning off)
frogg320 is offline   Reply With Quote
Old 04-30-2009, 10:33 PM   #63
i0kr1sol
My Ride: 330ci
Hey guys, I'm in the middle of doing this DIY - everything is off except the crankcase vent tube. I can't seem to pull it off. Can I spray something like brake cleaner or WD40 on it? Or what do you suggest?
i0kr1sol is offline   Reply With Quote
Old 05-01-2009, 12:04 AM   #64
frogg320
My Ride: 2000 323i
Pull harder?
Old 05-01-2009, 12:51 AM   #65
mkodama
mkodama's Avatar
I'd probably spray a little WD-40, but mine came out quite easily. Just make sure to firmly pinch it to release the clips and wiggle it loose if it is tight.
Old 05-01-2009, 01:02 AM   #66
i0kr1sol
My Ride: 330ci
Pull harder?
LOL, I did. Pulled so hard that I cracked the little spinning thing a little.
So you think its safe to spray a bit of WD40? Mine does not want to budge.
Old 05-01-2009, 01:05 AM   #67
mkodama
mkodama's Avatar
Yours is probably old and brittle from the years of heat. These end up cracking on a lot of people. Maybe just use some force to get it off and buy a new one which should be good for another 5-10 years.
And WD-40 is a pretty safe, and this breather hose is only to remove blow-by gasses anyway.
Old 05-01-2009, 02:25 AM   #68
i0kr1sol
My Ride: 330ci
thanks for the quick reply's mkodama, will try the wd40 tomorrow and when I get the car running, ill run to the dealer and get a new one and replace it.
Old 05-23-2009, 06:16 PM   #69
Sharky06
My Ride: 06 ZHP 6-SP
Send a message via AIM to Sharky06
subscribed
Sharky06 is offline   Reply With Quote
Old 05-24-2009, 01:04 PM   #70
rmavin
My Ride: 2003 330i
Hi guys
This is my first post so please be gentle. I just finished changing my valve cover gasket on a 2003 300i. The gasket was very hard and brittle. It was almost impossible to take off without cracking it and having pieces flying around and some did, they were about 1/8" x 1/8".
One piece fell into a spark plug well into the combustion chamber. A few landed on top of the cylinder head. Should I be concerned?
My gut tells me that the piece that landed in the combustion chamber would just get burned and blown out. The cylinder head pieces would either get crushed by the camshaft/etc or caught by the oil filter. Any input would be appreciated!
rmavin is offline   Reply With Quote
Old 05-24-2009, 01:12 PM   #71
inlinesicks
My Ride: E46, Jeep, Subaru
Originally Posted by rmavin View Post
Hi guys
I would be worried about the piece that went in the combustion chamber, there is a pretty good chance that would damage the rings and/or cylinder wall, I would try anything to get it out maybe a vacuum and make some sort of long thin hose to suck it out through the spark plug well.
inlinesicks is offline   Reply With Quote
Old 05-24-2009, 01:39 PM   #72
rmavin
My Ride: 2003 330i
what about the pieces on top of the cylinder head? And just for reference, the pieces are about the size of an oatmeal flake.
Old 05-24-2009, 01:43 PM   #73
inlinesicks
Well its never good to get any kind of debris in you engine so you should try to get it out but if its not possible I wouldnt really worry about it to much, like you said it will probably just end up in the oil filter.
Old 05-24-2009, 01:45 PM   #74
inlinesicks
Oh and by the way, welcome to the forum
Old 05-24-2009, 03:13 PM   #75
mkodama
mkodama's Avatar
Hi guys
This is why never do work on the engine with the head ports uncovered or spark plugs removed.
I would just hope for the best since the only way to get them out would be to remove the head which is $$$$.
Old 05-24-2009, 03:15 PM   #76
inlinesicks
this is why never do work on the engine with the head ports uncovered or spark plugs removed.
+1
Old 05-24-2009, 03:40 PM   #77
rmavin
My Ride: 2003 330i
So yeah, I am hoping for the best now. It would be a real bummer if something bad happens. I turned on the ignition, and so far so good. The engine revs fine and I don't hear any weird noises.
What should I be looking for? Or is it one of those problems that doesn't present itself immediately and I have to wait a few months/years before something happens?
Old 05-24-2009, 03:42 PM   #78
mkodama
mkodama's Avatar
What should I be looking for? Or is it one of those "hidden problems"?
Well, if your engine already started up and is running, than you should be good. The little bits of what not probably just got melted and burned away. Hopefully you have learned your lesson though. If it was something like a bolt or nut, then you would have had to completely remove the head to retrieve it, or possibly use some weird contraption to remove it.
Old 05-24-2009, 03:55 PM   #79
bmwTuner1
My Ride: Bmw, 330ci
great write up. Ill be doing this soon.
Photobucket
bmwTuner1 is offline   Reply With Quote
Old 05-24-2009, 04:03 PM   #80
mkodama
mkodama's Avatar
Thank you!
