Thread Tools Search this Thread Rating: Thread Rating: 38 votes, 5.00 average. Display Modes
Old 10-04-2009, 08:46 PM   #141
veuve
My Ride: ...
Originally Posted by X-vert View Post
Amazingly easy but really took my time. My cover was super clean! Tore the vacuum hose but easy fix.
Thanks Fanatics!
Looks nice and clean. congrats
veuve is offline   Reply With Quote
Old 10-06-2009, 12:30 PM   #142
spennI
My Ride: 2004 330i
Does anyone know of an easy way to cut-and-paste this DIY into a word document? When I do the normal cut-and-paste it copies only 2/3 of each picture.
spennI is offline   Reply With Quote
Old 10-06-2009, 12:34 PM   #143
sdbimmer
My Ride: 2004 325Ci
Download PDF995 from http://www.pdf995.com/download.html and use that to print these pages to PDF. That way, you will always have it. You will need to download the print driver and free converter.
sdbimmer is offline   Reply With Quote
Old 10-06-2009, 12:44 PM   #144
spennI
My Ride: 2004 330i
sdbimmer:
Thanks. I'll give that a try.
Old 10-12-2009, 09:41 PM   #145
1sickbmw
My Ride: ///M3--323i--RHD ek4
i will be doing this soon
1sickbmw is offline   Reply With Quote
Old 10-19-2009, 04:43 PM   #146
spennI
My Ride: 2004 330i
Thanks mkodama. I did this DIY last week and the directions were spot on. The only minor problem I had was removing the crankcase vent tube.
Old 10-20-2009, 12:31 AM   #147
mkodama
mkodama's Avatar
Yeah, I didn't have a problem but I've heard otherwise from many other people. Usually the plastic turns pretty hard and brittle as well as the oil vapor inside kinda seals it on.
Old 10-21-2009, 01:33 PM   #148
abrogan0319
My Ride: M3 6spd
anyone have any ideas to what the valve cover is made of, im thinking of throwing it in the hot tank at work to clean it up.. good idea or bad??
abrogan0319 is offline   Reply With Quote
Old 10-21-2009, 11:23 PM   #149
frogg320
My Ride: 2000 323i
It's plastic, don't push it. Also, it's a valve cover, there aren't any moving parts, don't worry about it too much. Wipe it off and move on with your life.
frogg320 is offline   Reply With Quote
Old 10-25-2009, 01:44 PM   #150
soro92
My Ride: 2003 330I
Great thread! Did mine last weekend, have only 59k miles, the gasket was really dry it turned into plastic and now the burnt oil smell is gooone!
soro92 is offline   Reply With Quote
Old 10-25-2009, 02:32 PM   #151
mcr_driver
My Ride: my favorite two feet
any tips on getting the valve cover off that thing is stuck on there like all hell
mcr_driver is offline   Reply With Quote
Old 10-25-2009, 02:47 PM   #152
jetskier88
My Ride: 330i ZHP S/C TS2+
Send a message via AIM to jetskier88
u just have to do it slowly. gradually go around in a circle applying pressure. dont just try and yank it from one side. it took me awhile but it eventually came off.
i think i used a fat flatheaded screwdriver to kinda wedge all the sides. just be careful
OHHHH and dont forget FYI.. i didnt read the directions on the manifold gasket glue.. it dries pretty quickly and i guess your supposed to wait an hour before starting the car.. i didnt wait that long but luckily no problem for me (knock on wood)
GL
ESS TS2+ - OEM M3 LSD rear end swap - Meth Injection - Recaros PP - Defi Guages - Dinan TB - Headers&M3 Custom Quad Exhaust - UUC LTW Flywhl - UUC SegKev Clutch - Rogue SSK - KW V2 Coils - H&R Sways - TMS Subfrme&Sway Reinfrcmnt - VMR V710 & M PS2's - Brembo X Rotors and more....
jetskier88 is offline   Reply With Quote
Old 10-25-2009, 02:49 PM   #153
Rickna
My Ride: '01 330xi - '09 IS-F
A metal putty knife should do the trick.
2001 BMW 330xi
2009 Lexus IS-F
Rickna is offline   Reply With Quote
Old 10-26-2009, 12:29 AM   #154
mkodama
mkodama's Avatar
Old 10-27-2009, 05:17 PM   #155
GRIFFIN
NWS
GRIFFIN's Avatar
My Ride: fast
Anyone in the Sacramento, Ca area, want to help me out with this?
*NWS GIF REMOVED*
*GIF REMOVED*
**You make me so horny.- Tim330i **
Old 10-27-2009, 06:43 PM   #156
mkodama
mkodama's Avatar
I'm only an hour and 20 minutes away and will do the job for $20. lol
I'm sure you'll get an answer if you make a quick thread in the regional forums.
Old 10-27-2009, 06:49 PM   #157
GRIFFIN
NWS
GRIFFIN's Avatar
My Ride: fast
It might be worth me driving down. I could this DIY, but I think it woudl take me 4 hours.
*NWS GIF REMOVED*
*GIF REMOVED*
Old 10-28-2009, 09:35 AM   #158
GRIFFIN
NWS
GRIFFIN's Avatar
My Ride: fast
Would you be willing to help out this weekend?
*NWS GIF REMOVED*
*GIF REMOVED*
Old 11-13-2009, 11:26 AM   #159
Reynard
My Ride: 330 CI
Will I need to replace fifteen valve-cover bolt grommets? Has anyone reused the rubber grommets?
Reynard is offline   Reply With Quote
Old 11-13-2009, 11:38 AM   #160
Rickna
Service manual recomends to change the gromets. Why risk a leak after all that work?
2001 BMW 330xi
2009 Lexus IS-F
