Beyern Mesh caliper clearance? - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Sponsored by The Tire Rack
Old 11-20-2008, 10:04 PM   #1
timsters330i
My Ride: E46
Unhappy Beyern Mesh caliper clearance?
I have a 2002 330i sedan. I recently put on Beyern Mesh 255/35/18's on rear (9.5), and 225/40/18's on front (8.5). The offset on rears is 45. I noticed when I mounted them that the clearance between the inside of the rear wheel and the brake caliper is REALLY close. Like a sheet of paper might fit sort of thing. But it doesn't actually touch. It occurs to me now a month later as I'm getting close to having to put new rear brake pads on that the caliper might shift outboard a bit, given the thicker (new) pads. Is my suspicion correct? If the caliper moves outboard it will likely interfere with the wheel, no?
Has anyone else experienced this? Here I thought going the Beyern route would minimize fitment issues given they're made for BMW's. But not sure now?
timsters330i is offline   Reply With Quote
Old 11-23-2008, 12:29 PM   #2
N330ci
My Ride: e92 M3
I've got the bayern mesh 19's (8.5 front 9.5 rear) on my coupe. I agree the caliper is very close in the rear, but doesnt touch at all. I've had mine for six months and just put new pads on a few weeks ago with no problems at all.
N330ci is offline   Reply With Quote
Old 12-04-2008, 07:16 PM   #3
timsters330i
My Ride: E46
Thanks for the info N330ci. Good to know.
Old 05-03-2009, 01:18 PM   #4
ZZen330
My Ride: 2002 330Ci
I found at least 3 people have the exact issue you refer to with the Beyern Mesh and their 330's. So it seems that it could be a potential problem. It's the reason I ruled the wheel out even though it had made m shortlist. The quotes are below.
"I used to have the Beyern Mesh on my old 330ci (traded in for a M3). But anyways, it all fits well at the beginning. However, when I went to the dealer to have my brake pads changed, the rear rim won't clear the calibers anymore. Seems like the new brake pads are thicker than the old OEM ones.... Anyone experience similar?" - Nov. 2006
"I have just bought a set of Beyern mesh wheels for my E46 330 and the spokes rub on the rear caliper, this is only an issue with the 330 models and Beyern are very upset to say the least. I am now going through the procedure of fitting 3mm spacers or maybe machining 3mm off the outer brake pad for clearance. So much for Research and development." - Feb. 2007
"Dave, I bought my Beyern wheels 6 months after your post and this issue was never mentioned to me. At the time my brakes allowed them to fit and no one questioned it. I just had new brakes/rotors installed and now they hit. Who confirmed for you that this was a known issue within Beyern/TSW? Also, what did you end up doing to resolve the issue (spacers, etc.), and how well has that worked for you? Thanks ... Clint" - Feb. 2009 (refers to the Feb 2007 quote, so bought his wheels Aug. 2007).
ZZen330 is offline   Reply With Quote
Old 05-03-2009, 01:22 PM   #5
frobie15
My Ride: has a door star
Send a message via AIM to frobie15
I have the Mesh's in 18's on my 330. With new pads the wheels WILL rub on the caliper. My fix? I took a grinder to the caliper and shaved off a little bit of material until the wheels cleared. Then repainted the caliper. Now I won't have to worry about clearance issues the next time I change pads.
Go ahead, ask me a question... Check out the CopTalk thread in the California forum
Thank you Sam
frobie15 is offline   Reply With Quote
Old 05-03-2009, 01:24 PM   #6
SeanC
My Ride: 330i
O man, not only they don't look good, but then this. And you're not the only one. People should stop buying these rims. There are a million other better looking rims with more clearance than these for the money.
Black Sapphire MetallicNatural BrownSilver Cube e46 330i ZHP/6MT - Sold
HellrotDove Grey e36///M3 - RIP
Black Sapphire MetallicNevada BrownDark Bamboo e70 X5 xDrive4.8
Alpine WhiteCoral RedAluminum f30 328i Sportline/6MT
Imola RedBlackBlack Aluminum e46 330i ZHP/6MT
SeanC is offline   Reply With Quote
Old 05-03-2009, 02:03 PM   #7
timsters330i
My Ride: E46
Well this is disappointing. As it turns out, I wasn't as close as I thought to needing new rear pads when I made this original post several months ago. Since I'd rather not have to invest in new wheels (again), what are the thoughts on a thin spacer to resolve the issue (assuming that when I do need new pads, I will be one of those experiencing this issue)? While grinding the caliper would seem to solve the problem as well, I'm not sure I'd like to possibly compromise the caliper (albeit only a small amount of material would likely need to be removed).
Any significant compromise in doing a thin spacer? Or am I looking at having to get different wheels should a ground caliper not be a route I choose?
Old 05-03-2009, 06:55 PM   #8
thefitter
My Ride: Is tight all night!
If and when this becomes an issue it's not that big a deal to put a spacer on. Here's some that are only 3mm from Turner.
http://www.turnermotorsport.com/html...UCT_ID=0675725
I would not grind my calipers.
2002 325i - BBS RK ~ Michelin PSII ~ Bilstein CoilOver ~ Rogue RSTM ~ Brembo BBK (custom yellow color) ~ H-Sport Sways ~ TMS endlinks ~ M-Sport CA ~ Powerflex CAB ~ M-Sport STB ~ Ground Control RCA ~ PowerFlex RTAB ~ SuperSprint catback ~ Vorshlag ACP ~ Dinan CAI ~ Dinan SW ~ Denso Iridium ~ Formula One Pinnacle 35.
2007 335i - 100% Stock except dumped the run flats for Michelin PSII.*SOLD*
2011 335d - 100% Stock *SOLD*
thefitter is offline   Reply With Quote
Old 05-03-2009, 07:13 PM   #9
///M3Turk
My Ride: M6 ,X5, R6, M5, M3
Send a message via AIM to ///M3Turk Send a message via MSN to ///M3Turk
they look bad ass ,abi
Firat
///M3Turk is offline   Reply With Quote
Old 05-03-2009, 08:00 PM   #10
SeanC
My Ride: 330i
not to me Firat, I'd take CSL reps or 135Ms over these any day of the week. But to each their own
Old 05-04-2009, 11:20 AM   #11
frobie15
I've got 64k miles on my rear calipers since the time that I ground them. Including plenty of hard mountain drives that got the brakes plenty hot. Haven't had an issue with them at all.
On the idea of running a 3mm spacer -- I know that on my car with rolled fenders, a 3mm spacer would most likely cause clearance issues. Grinding the calipers is free If I were closer, you could check mine out. I only had to take off a small bit of material.
Thank you Sam
Old 05-04-2009, 04:11 PM   #12
BeeamW
My Ride: 04' BMW 330Ci (vert)
Man, I just got my Beyern Mesh 18s last week after several weeks of sleepless night. Beyern was my 2nd choice and the reason I settled with them was because my first choice VMR V715 was not available in 18s. After I bought them they didn't look as good as they did in the pics. So I was disappointed initially but then they started growing in me. Just when I thought I was about to fall in love with them you guys tell me this? How come no body mentioned this to me when was asking for suggestion?
BeeamW is offline   Reply With Quote
Old 05-04-2009, 09:30 PM   #13
Xcelratr
My Ride: 04 330Ci ZHP
See this thread in addition to the quotes from ZZen.
While I understand the aversion to grinding down calipers, if you're careful and only need to take off a little bit, it's absolutely doable with 0 affect on the car's performance or longevity.
OP, let us know how it goes.
We will not tolerate intolerance.
Xcelratr is offline   Reply With Quote
Old 05-05-2009, 11:07 AM   #14
frobie15
Exactly. Look at how thick the caliper is on the top outside corner. Is taking off 1/16" really going to cause it to fail?
And, for what it's worth, when I bought my wheels, the shop said that the rear wheels are not listed as a size that fits the 330. I told them, nah a bunch of guys online have them on their cars, I'll take they fit, I promise. We all know how that ended up....
Thank you Sam
Old 05-05-2009, 11:47 AM   #15
BeeamW
What size rear wheels do you have? When I bought mine form Discount Tire Direct and they said it would fit per BMW's reccomendation. Besides, how could Beyern not know this, I thought they make wheels for bimmers only (even though that doesn't mean all their wheels would fit all models of BMW).
Old 05-05-2009, 01:13 PM   #16
frobie15
I have the 18x9.5 with a 45 offset.
Honestly, having to take a little bit off of the caliper is a small price to pay for the deep lip on the wheel.
Thank you Sam
Old 05-06-2009, 10:33 AM   #17
timsters330i
My Ride: E46
Thanks all for your responses. I suppose it is somewhat reassuring I'm not the only one. When it comes time for those new pads, I'll decide which route makes the most sense depending on how much interference there is.
Old 05-06-2009, 11:42 AM   #18
BeeamW
So spacers aren't a good solution? To be honest I'd rather use spacers to have a bit more flush look then grinding down the calipers and still have the way my wheels are right now. Are your Beyerns flush with the fender?
Am I choosing the wrong option? I know a lot of people don't want to use spacers, are they really that bad for your car?
Old 05-06-2009, 01:47 PM   #19
frobie15
I have 10mm spacers in the front. Had to do it to clear the coilovers, but it also got the wheel to the edge of the fender. There are pictures of my car here:
http://forum.e46fanatics.com/showthread.php?t=486285
Thank you Sam
Old 05-06-2009, 10:33 PM   #20
Xcelratr
^^^^ No light bar?
j/k, nice clean coupe, frobie
beyern, caliper, clearance
