Old 11-21-2008, 11:07 AM   #1
rblairjr
My Ride: Everywhere
Cool Front Ashtray Conversion to Non-smoking Storage Tray
I bought my '04 vert last year and it did not have a front ashtray at the time. I just got the OEM part for the non-smoking package and tried to install it last night, but it wouldn't fit. It looks like there's a little plastic piece that sticks out around the small light (that's not working by the way) that's preventing it from sliding all the way into the opening. I could either attemp to remove the piece or modify the little tray. Has anyone modified the non-smoking storage tray so it will fit into the smoking package ashtray compartment? Thanks!!!
rblairjr is offline   Reply With Quote
Old 11-21-2008, 11:08 AM   #2
VALMONT
The De46vil's Army
VALMONT's Avatar
My Ride: 325Ci, Passat
Send a message via AIM to VALMONT Send a message via MSN to VALMONT
ashtrays are so euro! why would you want to remove it?
VALMONT is offline   Reply With Quote
Old 11-21-2008, 01:10 PM   #3
Philbert
My Ride: 02M3|80 280ZX|87Yota
what part number is it? Do you have pics? just curious - this may go on my xmas list
02 M3 Vert | 87 4Runner | 80 280ZX
Dinan S. | Clears | DiCE | OEM Alarm Retrofit | ACS Rep. Peds | DDEs
My Valentine 1 Hardwire | Remote Display Gauge Cluster Mod
Considering selling 2002 M3 Convertible (~38,000 miles) this year (don't drive it enough...). If seriously interested, PM me. SF Bay area.
Philbert is offline   Reply With Quote
Old 11-21-2008, 01:16 PM   #4
TKC
My Ride: 330cic & R6
Send a message via AIM to TKC
Pics please
EUROPROJEKTZ - Director, NorCal Chapter
TKC is offline   Reply With Quote
Old 11-22-2008, 10:05 AM   #5
rblairjr
My Ride: Everywhere
Asthray - Eurotray non-smoking photos
Here are the pics of my problem. The part number is 51168208369. The arrow in the first picture shows where the plastic piece covering the light bulb prevents the euro tray from fitting in the opening. Has anyone modified one of these? Do I try to modify the tray or try to break off that plastic piece? Any ideas? Thanks!!!
Name:	BMW Ashtray Photo 1.001.jpg
ID:	292892   Click image for larger version
Name:	BMW Photo 2.002.jpg
ID:	292893   Click image for larger version
Name:	BMW Photo 2.003.jpg
ID:	292894   Click image for larger version
Name:	BMW Photo 2.004.jpg
Old 11-22-2008, 03:48 PM   #6
John in VA
My Ride: 328i/325xi
Would it help if you filed that edge off flush with the plastic "bump" closer to the front of the opening?
John in VA
'13 328i xDrive
'06 330ci ZHP
'03 530i
'02 325xi
'00 328i
'86 535i
'85 535i
'85 325e - RIP
'74 2002tii
John in VA is offline   Reply With Quote
Old 11-22-2008, 04:43 PM   #7
coby1
Just Road Miles
coby1's Avatar
My Ride: 325i sport pkg
Looks doable to me just need to go for it and start cutting.I have the ashtray and since seeing the "no smoke part" i will probably buy one to do the same as you.
<a href=http://img211.imageshack.us/my.php?image=coby112ef1.jpg target=_blank>[img=http://img211.imageshack.us/img211/3589/coby112ef1.th.jpg]</a>
coby1 is offline   Reply With Quote
Old 03-28-2011, 02:39 AM   #8
02e30e46
My Ride: '04 330i ZHP 6MT
non-smoking tray conversion with illumination
I ordered one of these non smoking trays without doing my research and found this thread after realizing it wasn't just a "drop in".
I dremeled the little piece of plastic to gain extra clearance needed to drop it in. Then I drilled a hole with a 3/8" bit and used a dremel to make it the appropriate shape to snap in the window from the ashtray. Wasn't very difficult, just need to go slow and check frequently to make sure you don't take off too much.
The led does stick out a bit too far, but it can be coaxed a little bit to make the new tray fit. Overall, I'm very happy with the result and am glad I went to the trouble to keep the lighting. Now I just need to get a non smoking lighter plug.
02e30e46 is offline   Reply With Quote
Old 03-28-2011, 09:57 PM   #9
John in VA
My Ride: 328i/325xi
I believe it's 51-16-0-141-037 - Stopper plug-in socket
John in VA
'13 328i xDrive
'06 330ci ZHP
'03 530i
'02 325xi
'00 328i
'86 535i
'85 535i
'85 325e - RIP
'74 2002tii
Old 05-28-2011, 05:57 PM   #10
Danoff
My Ride: '04 330i ZSP
02e30e46, I followed your instructions exactly and it worked like a charm. My storage package conversion is now complete with both front and rear ashtrays replaced with storage package parts with the red LED illuminating the front tray, and it even has the little plastic window. For good measure I went ahead and replaced the cigarette lighter with the non-smoking plug. Thanks for your tips!
Danoff is offline   Reply With Quote
Old 05-29-2011, 05:03 AM   #11
02e30e46
Thanks for the kind words!
It was a pretty easy little project that got me started. Just finished my bixenon retrofit, which was a bit more challenging...
Old 05-30-2011, 12:59 AM   #12
Kmoy2002
My Ride: 2002tii, 540i, 330i
Alternative:
Hope op doesn't mind me using his pictures, but my interior is pretty much the same. Picked up a momentary switch from Radio Shack. Profile fits perfectly into the cigarette hole. It serves as a garage opener for me because my car wasn't equipped with the UGO
Kmoy2002 is offline   Reply With Quote
Old 05-30-2011, 01:03 AM   #13
2000_328CI
2000_328CI's Avatar
My Ride: 328Ci | Range Rover
Timeless Motor Group
Old 05-31-2011, 01:59 AM   #14
StahlBlau3
My Ride: '99 328i, '88 528e
F'ing sick!!! Did you buy or design your set up there?
StahlBlau3 is offline   Reply With Quote
Old 05-31-2011, 07:26 AM   #15
2000_328CI
2000_328CI's Avatar
Design and built Not all that hard really. Sourcing the OEM Z8 push button was a pain though (as I didn't want to pay the $150 or so that the dealer wanted for it)
Old 06-05-2011, 04:35 PM   #16
StahlBlau3
Well it looks awesome!
Old 06-09-2011, 11:53 AM   #17
Danoff
My storage tray.
Old 07-21-2011, 04:06 PM   #18
Alex323Ci
My Ride: M3 & 323Ci (sold)
anyone have pictures of this storage tray compared to the ashtray that's there. is it really any bigger than if you gut the current one?
Old 07-21-2011, 08:16 PM   #19
02e30e46
The main difference is the lack of a "cigarette holder", so you can use the whole opening. And it is a nicer material on the inside - if that makes a difference. Mine looks exactly like Danoff's above with the plug.
Old 07-22-2011, 01:41 PM   #20
Elsamo
My Ride: 2004 325 Ci
02e30e46 - Food for though on replacing the lighter... I was looking for a replacement for mine and came across this
http://www.europeanautosource.com/pr...oducts_id=3676
Elsamo is offline   Reply With Quote
