Old 07-22-2011, 04:12 PM   #21
9deuce9rr
My Ride: '02 M3, '66 Chevelle
didn't know the non-smoking tray existed, so i just dremeled down the little nubs for holding cigarettes until they were flush with the rest of the tray, masked the light lens, and re-sprayed the piece so you couldn't tell.
Looks great in there thought, would have just ordered one, had I known about it
9deuce9rr is offline   Reply With Quote
Old 01-05-2014, 01:31 PM   #22
VAdriver
My Ride: 02 330i
Originally Posted by Kmoy2002 View Post
Alternative:
Hope op doesn't mind me using his pictures, but my interior is pretty much the same. Picked up a momentary switch from Radio Shack. Profile fits perfectly into the cigarette hole. It serves as a garage opener for me because my car wasn't equipped with the UGO
I know this is a super old thread, but I stumbled into it and love this idea so much that I had to do it myself. Just finished the install on my new button. Thanks for posting this!
VAdriver is offline   Reply With Quote
Old 01-05-2014, 01:50 PM   #23
YOLO89
My Ride: Hooptie
Front Ashtray Conversion to Non-smoking Storage Tray
You got any pictures of your install? Thinking about doing this soon also
YOLO89 is offline   Reply With Quote
Old 01-05-2014, 01:54 PM   #24
VAdriver
My Ride: 02 330i
Sure.
I tucked the wire around to the glovebox and put the remote in there. I wanted to be able to get to it so I can change the battery pretty easy.
If assuming you have a soldering iron, it only cost me about $10 for the button and wire.
I don't do much DIY stuff so if I can do it, I'm sure you can.
Old 01-06-2014, 03:26 PM   #25
MiniXP
My Ride: 08 335i & 01 325xi
I use that same button in the same place for the Mute on my V1. Didn't feel like Paying for the concealed display. I putt a little O ring around it under it to help hide some of the metal edges that you can see.
MiniXP is offline   Reply With Quote
Old 01-06-2014, 04:04 PM   #26
VAdriver
My Ride: 02 330i
That's a good idea. I'll look for something to dress it next time I'm at a hardware store.
Old 02-28-2014, 10:06 PM   #27
AgentJBOND
My Ride: '01 M3
I just did the ashtray replacement according to instructions in this thread - worked out great!
Notes: Whenever the DIY talks about using a dremel, use a sanding attachment (not a cutting wheel). The 3/8" bit cuts the hole nearly perfect, it only needs a little expansion (if any). I sanded a little indention from the back of the new tray leading to the hole I drilled - giving the bulb a sort of groove to allow it clearance, and this made it easy to fit the tray in.
AgentJBOND is offline   Reply With Quote
Old 05-27-2014, 03:06 PM   #28
TrentW
My Ride: 89 325is, 05 325xiT
A Dremel makes this a fairly easy mod. Transferring the light lens is easy, just need to make a small square cut-out and then super glue it in as the tabs won't hold due to thickness of the wall. Also made a groove for the bulb to clear as someone mentioned. Be careful when grinding away the plastic protrusion around the bulb though, it's easy to hit it with the grinder fitting.
ID:	559812   Click image for larger version
TrentW is offline   Reply With Quote
Old 05-28-2014, 08:45 AM   #29
markusmarkus
My Ride: 2001 330Ci
I installed a slide potentiometer in my ashtray. It's used to control the bass level.
