Old 11-22-2008, 07:45 PM   #1
lrogers80
My Ride: 323i
No Boost
Can anyone help me out here? AA is closed for the weekend. I got my kit installed. Car idles perfectly supercharger blows air, but car never goes into boost at idle vacuum is -20 and goes up to 0 at full or partial throttle.
I don't feel this 100 HP. I don't hear or feel any leaks. I removed the Intercooler and reved the engine. I could feel the air from blower (driver side) and I can feel the sucking on the passenger side with intercooler off. Something isn't right. SuperCharger sound really nice, but no boost or power to match. Please Help Any thoughts?
My 323i does not have a fuel pressure regulator if that helps AA said I didn't need it.
Thanks.
lrogers80 is offline   Reply With Quote
Old 11-22-2008, 08:02 PM   #2
beanfree
My Ride: 330i S'chgd ZHP
Centrifugal superchargers make most of their power on top. Drive the car in second and merge onto a highway. That way you can rev it up high and see if you can feel the power.
They also say it takes a few miles for the software to adapt. When I first drove my car it did not feel very quick. Follow the break in period.
TE ASA SC, 260/268 TE FI Cams, 38# inj, IK 27, TMS 3.07 finned LSD, F/R subfr reinf, rear cmbr rm reinf, UUC BBK F & R, Ltw fly, Seg kvlr clutch, Sways, Evo III ssk & DSSR, Hawk HPS, H & R C'overs, CDV, P'port SRX, 3M S'guard, MOMO seats, RT cats, Borla cat back, Odyssey 680 battery, Neez Eurocross 18/8.5 /9.5, 245,275 D'lop *spec, Oil nut, Clch stp, gauges, Cstm intake, 131mm pulley, vac. can, catch can & al. r. subfr bushings.
beanfree is offline   Reply With Quote
Old 11-22-2008, 08:07 PM   #3
lrogers80
My Ride: 323i
Break-in ?
AA and their instructions, which were very very very very very poor, said nothing about breaking the software or car in. How many miles before my gauge should see boost?
If anything the car feels slower...
Last edited by lrogers80; 11-22-2008 at 08:08 PM. Reason: forgot to add "If anything the car feels slower..."
Old 11-22-2008, 09:46 PM   #4
sataraid
My Ride: 2001 BMW 330ci
How many miles have you put on the car with S/Cer running??
sataraid is offline   Reply With Quote
Old 11-22-2008, 10:30 PM   #5
lrogers80
My Ride: 323i
not much...
I put about 3 miles
Old 11-22-2008, 10:53 PM   #6
sataraid
Yeah, you definately need to drive the car. The software needs time to adapt. Drive you car around. Dont go beyond 5000 rpms for 100 miles. Then call AA Monday if you dont see any improvement.
Old 11-23-2008, 12:20 AM   #7
lrogers80
My Ride: 323i
Break in...
Oh really? I already went past that several times today and didn't feel the boost. How do you guys know about this little bit of information. I spoke to Craig from AA many times and never did he mention this break in adaptation period nor does the install manaul say this. Can someone tell me if this is in fact true?
Old 11-23-2008, 01:47 AM   #8
Activ3
My Ride: gets DRIVEN.
Send a message via AIM to Activ3
You have a boost gauge installed and it's not moving past 0 at all?
-David www.e46nonm.com | My Videos
2000 328i - Custom Turbo tuned by AA
Activ3 is offline   Reply With Quote
Old 11-23-2008, 02:03 AM   #9
lrogers80
My Ride: 323i
Correct. At Idle it goes to -20, then when I drive and get up to 5-6 RPM it goes up to 0 and no further. I double check for leaks, but can't find any every hose is on tight. I disconnected the hose connected to the throttle body and the idle starting jumping up and down, but when I connected it back idle was perfect again. It just seems to me that I should be feeling some kind of boost unless the computer really is managing this.
Old 11-23-2008, 02:24 AM   #10
docwyte
My Ride: '89 944 Turbo
You have a leak somewhere. If you're hard on the throttle in the upper ranges of the tach, you should see boost. There is no "break in" period for the supercharger. It will make boost right out of the box, the ECU has no control over the boost level.
'98 M3, track beast
'06 Porsche Cayenne Turbo S 521hp daily driver
'07 KTM 990 Adventure
docwyte is offline   Reply With Quote
Old 11-23-2008, 02:30 AM   #11
lrogers80
My Ride: 323i
Now that's what I was thinking, but at what point could I have this leak? I removed the intercooler to test both sides. Driver side has pressure and passenger side has suction. I blew air into the passenger side and it was tight no air would go through. I placed my hand on the driver side and the supercharger was trying to push my hand away no leak in the upper area. So where could a leak be? Even if it was a little leak should I see a little boost?
Old 11-23-2008, 04:06 AM   #12
Maestroxl
My Ride: 330CI
Send a message via MSN to Maestroxl
Maybe something is blocked?
piece of paper in the intercooler maybe or something like that.
Maestroxl is offline   Reply With Quote
Old 11-23-2008, 04:57 AM   #13
sataraid
Can you place your air filter on the hose connected to the S/Cer?? Try to bypass intercooler and see if you get boost.
Old 11-23-2008, 05:40 AM   #14
blackbeard
My Ride: Is stock : (
somethigns off, a supercharger(as stated earlier) will perform right out of the box, you should have boost immediately, now is your gauge a vacume gauge or boost gauge? because a boost gauge wont go to -20. your engine vacume will be negative as its a steady suction created by the engine crankcase that sucks on your brake booster and will control some other aspects.
blackbeard is offline   Reply With Quote
Old 11-23-2008, 06:46 AM   #15
lrogers80
My Ride: 323i
This is exactly what I thought and that's why I removed the Intercooler and blew air into it from one side and air does come out and when i block one side and blow into it air will not come out so there isn't a leak from the intercooler it self.
My gauge is both vacuum on one side and boost on the other. At idle the needle is at the vacuum side and when I drive it does move to 0 but never passes 0.
Could I have a bad check valve?
Old 11-23-2008, 10:48 AM   #16
lrogers80
My Ride: 323i
Vacuum...
Here's an image of the boost gauge. I thought it was at -20 yesterday, but today it's at 11-12
I just got drove about 22miles on the hwy and I am not getting 29.5 MPG. I useto get 26. Car feels good, I got up to 100MPH at 5k RPM and it still never went pass the 0 mark on this gauge.
Name:	Boost Gauge.jpg
Old 11-23-2008, 11:10 AM   #17
docwyte
You sure the boost gauge is hooked up properly?
'98 M3, track beast
Old 11-23-2008, 01:30 PM   #18
lrogers80
My Ride: 323i
Yes, I have it connected to a plugged up vacuum port behind the intake manifold. It's sucking vacuum I can feel it. I had the car running while I was redirecting the line into the car and my check engine light came on. I read the codes and they were:
Oxygen Sensor Adaption Limit & Secondary air system flow too low and EVAP capillary leak (0.5mm) detected
I figured the first two codes came on because the vacuum line to the boost gauge was disconnected while I was routing it into the car. I reset the codes and the check engine light did not come back on, but before I had the charger installed I use to get the "EVAP capillary leak (0.5mm) detected" code I could never figure out what was causing this code to put up every now and then, but the check engine light never came on for this code.
Old 11-23-2008, 01:39 PM   #19
BimmerDude18
My Ride: 1998 528i
Where is the boost gauge tapped in? By that, I mean is the vacuum line actually connecting to the intake manifold, or to a hose that is rerouted during install to be before the supercharger.
Pictures of the install could be helpful as well. Try to capture as much of the piping as possible, sometimes something simple can be the issue.
-Tyler
1998 528i 5-speed Work in progress
1988 Toyota Pickup (4WD 5-speed) daily
2007 San Marino Blue 350z 6-speed sold
1996 328i 5-speed sold
www.e46nonM.com - www.precision-sport.com - www.flyingwindowtinters.com - www.techniquetuning.com
BimmerDude18 is offline   Reply With Quote
Old 11-23-2008, 02:38 PM   #20
derek0606
My Ride: 01 330CI Orient
Those codes may come back.... Give it some miles before you scratch this off your list.
derek0606 is offline   Reply With Quote
