Old 11-23-2008, 03:30 PM   #21
lrogers80
My Ride: 323i
The vacuum source is coming from the back of the intake manifold next to the firewall.
Originally Posted by BimmerDude18 View Post
Where is the boost gauge tapped in? By that, I mean is the vacuum line actually connecting to the intake manifold, or to a hose that is rerouted during install to be before the supercharger.
Pictures of the install could be helpful as well. Try to capture as much of the piping as possible, sometimes something simple can be the issue.
lrogers80 is offline   Reply With Quote
Old 11-23-2008, 03:31 PM   #22
lrogers80
My Ride: 323i
Old 11-23-2008, 03:34 PM   #23
lrogers80
My Ride: 323i
Old 11-23-2008, 05:56 PM   #24
lrogers80
My Ride: 323i
Ok I decided to change the boost gauge vacuum source. It's now connected to the bypass valve vacuum line and now I get -20 vacuum rather than -11, but still does not pass 0 at 5k rpm.
Old 11-23-2008, 10:11 PM   #25
MachRc
E46Fanatic
MachRc's Avatar
My Ride: 2003 Technik S1 M3
it should be -15
i think your gonna have to recheck your install, you should get atleast 3-4 psi above 4k rpm at WOT.
the blower WILL make its presence known when you first drive it..its a pretty big difference to be noticed.. and if you dont feel it in the sit of your pants...
id recheck the install...some mechanical gauges are faulty...but im sure its not that..
"I hated cutting suckers with my razor blade. But everyday it's a struggle to get major paid. Anyway
it's so hard on a Jigga in this city, no pity..And ain't no love for the scrubs that be buying dimes.. If you could walk a mile in my shoes.."
MachRc is offline   Reply With Quote
Old 11-23-2008, 10:12 PM   #26
docwyte
My Ride: '89 944 Turbo
No, -20 is pretty normal for vacuum at sea level. Are you sure you have the bypass valve plumbed properly? Realize that you have to be hard on the gas to get boost. If you're lightly on the gas, or cruising, it doesn't matter what rpm you're at, you won't be in boost.
If you're hard on the gas at 5k rpm and don't see any boost, you have a massive leak or a blown supercharger.
'98 M3, track beast
'06 Porsche Cayenne Turbo S 521hp daily driver
'07 KTM 990 Adventure
docwyte is offline   Reply With Quote
Old 11-23-2008, 10:28 PM   #27
lrogers80
My Ride: 323i
I can actually say I am not hard on the gas pedel. When you say WOT, you mean step on the pedal until it hits the floor? I never had a need to do that before the supercharger install to feel power. I thought the supercharger would give me power regardless or WOT? How could I tell if the Blower is bad?
Old 11-24-2008, 01:42 AM   #28
docwyte
If you're at partial throttle, alot of time the bypass valve will still divert the boost back into the intake tract. Stomp on the pedal! See if you get boost.
'98 M3, track beast
Old 11-24-2008, 05:37 AM   #29
lrogers80
My Ride: 323i
I currently have about 40 miles I should get it to about 100 today I'll hit it then, but before this I will be calling AA to make sure everything is working they way it should. I will post the results asap. Thanks again everyone for your help.
Old 11-24-2008, 06:50 AM   #30
lrogers80
My Ride: 323i
I started the car this morning as it was warming up. The check engine light came on again. This time I got two of the Secondary Air system flow too low (Peake tool F5 and F6 )
and a new one Air Mass Sensor(Peake tool 08)
I could hear my secondary air pump running fine this morning. Not good
Old 11-24-2008, 10:11 AM   #31
redronin
My Ride: 330ci
if you have vac at idle and no boost at WOT you (partially) blew the main boost line off the bottom of the charger (if its centrifugal)
i gaurantee it.
if the compressor was bad you would hear it.
redronin is offline   Reply With Quote
Old 11-24-2008, 10:18 AM   #32
redronin
My Ride: 330ci
p.s. i wouldnt drive this thing 100 miles in the condition. you will throw rich codes at WOT because there is not enough air making it to the block for all the fuel. could foul plugs or something.
Old 11-24-2008, 10:20 AM   #33
Active Autowerke II
Past Site Sponsor
Active Autowerke II's Avatar
My Ride: BMWs
Send a message via AIM to Active Autowerke II
To the OP, you should be receiving an email from Craig this morning.
Active Autowerke II is offline   Reply With Quote
Old 11-24-2008, 10:24 AM   #34
redronin
My Ride: 330ci
Originally Posted by lrogers80 View Post
Now that's what I was thinking, but at what point could I have this leak?
its the main line below the compressor. if the seal isnt right, it will hold air at atmospheric pressure (driving below boost etc) but under boost the seal will come apart and let loose all your boost, making you drive at atmosphere pressure when you should be at 130% or so. this is very hard to diagnose but seeing normal vac at idle, normal driving at low rpm,
and then seeing no boost at wot and blowing maf codes at wot is classic boost leak
if you paid for the install, have them fix it for free.
Old 11-24-2008, 10:53 PM   #35
lrogers80
My Ride: 323i
Ok I think the charger is working just fine. I went to homedepot and got some PVC piping and cuplers. I connected the boost gauge to the pvc pipe. In place of the intercooler. Picture below and the gauges does show boost when I get up to 3k RPM. It seems like my boost is getting to the engine, but Maybe the throttle boddy isn't taking it. I also replaced the bypass valve thinking that maybe it wasn't working, but that didn't help.
Also my valve didn't work I was able to blow air to both sides. I got a PCV valve from Pep post to take it's place still didn't help. Not sure what else to try now.
Old 11-24-2008, 11:19 PM   #36
docwyte
What's that grey valve? If you're bypassing the intercooler and get boost, then you have an issue with the intercooler. Take it to a radiator shop and have it leak tested.
'98 M3, track beast
Old 11-24-2008, 11:29 PM   #37
lrogers80
My Ride: 323i
That gray valve is a check valve used for who know what....
The intercooler is fine. I thought it was leaking that's why I brought the PVC pipe. I drove it and same issue, That's when I decided to tap into the PVC pipe to measure boost and it went up to 8psi. This confirms that the charger and piping is sealed good. After the air gets into the throttle body that's when I have a problem. Maybe the TPS Sensor not ready correctly?
Old 11-24-2008, 11:57 PM   #38
mm325
My Ride: ESSe36325is,04zhp
Is that the check valve for the charcoal cannister?
mm325 is offline   Reply With Quote
Old 11-25-2008, 12:10 AM   #39
lrogers80
My Ride: 323i
Yes.
Old 11-25-2008, 08:23 AM   #40
redronin
My Ride: 330ci
but Maybe the throttle boddy isn't taking it. ]
thats what i meant. not the charger outlet, the throttle body is what i blew a boost line off.
im telling you this is the problem, you need to reinstall your upper boost lines ( from the IC back to the throttle body.
i had the exact same thing happen to me, its the only explaination if the compressor doesnt sound broken (and you would hear it)
