Old 11-28-2008, 07:40 PM   #81
lrogers80
My Ride: 323i
I just tapped my Boost gauge to the 90 degree elbow just before the throttle body. AA provided a little blocker I was able to especially unscrew and install a barb connector. If I rev it up, I get almost 10psi of boost and this is with my intercooler installed. That boost is getting to the throttle body just fine, but after that point not sure what's happening to it. If I connect the boost gauge to the manifold, I don't get any boost barely 1 psi at times.
lrogers80 is offline   Reply With Quote
Old 11-28-2008, 08:21 PM   #82
lrogers80
My Ride: 323i
Old 11-29-2008, 06:42 PM   #83
BimmerDude18
My Ride: 1998 528i
I doubted the intercooler as the issue, you'd feel the leak.
-Tyler
1998 528i 5-speed Work in progress
1988 Toyota Pickup (4WD 5-speed) daily
2007 San Marino Blue 350z 6-speed sold
1996 328i 5-speed sold
www.e46nonM.com - www.precision-sport.com - www.flyingwindowtinters.com - www.techniquetuning.com
BimmerDude18 is offline   Reply With Quote
Old 11-29-2008, 06:49 PM   #84
lrogers80
My Ride: 323i
I replaced the Tensioner and the Belt and still no difference.
As I drive I notice that if I press the gas pedal WOT I completed loose boost, but if I lightly give it gas, I get a little boost up to 5 psi. It feel like when you give a car too much gas and it fall flat. It really feels like my throttle body is closing and forcing the boost to get pushed back to the bypass valve. This is just really weird. I have no clue what AA programmed or even if there is an option to tell the throttle body that it's OK to accept the extra air. To me it feels like that's what the throttle body is doing.
Old 11-30-2008, 12:55 PM   #85
docwyte
My Ride: '89 944 Turbo
The throttle body is a mechanical device. The ECU doesn't need to tell it to "accept" boost. It's either open or closed, it could care less how much air is going through it.
'98 M3, track beast
'06 Porsche Cayenne Turbo S 521hp daily driver
'07 KTM 990 Adventure
docwyte is offline   Reply With Quote
Old 11-30-2008, 04:43 PM   #86
lrogers80
My Ride: 323i
From what I have read my 323i has a cable but that cable is to move a potentiometer that sends a signal to the butterfly motor. The computer can control it for traction control purposes. This just suck I really wish I could figure this out, it's just killing me.
Old 11-30-2008, 05:24 PM   #87
docwyte
Yeah, but in 4th gear, you won't have traction issues. So I really doubt the ECU is slamming the throttle plate closed.
'98 M3, track beast
Old 11-30-2008, 05:46 PM   #88
lrogers80
My Ride: 323i
Do you think its a boost leak under load that I can't find because I am not underload in neutral and reving in neutral won't let me feel the boost leak?
Old 11-30-2008, 06:58 PM   #89
docwyte
Well, you don't make boost when you're revving the car in neutral, so yes, I'd wager you have a boost leak.
'98 M3, track beast
Old 11-30-2008, 09:28 PM   #90
lrogers80
My Ride: 323i
Got boost!!!!!!!!!!!!!!!!
Old 11-30-2008, 09:39 PM   #91
sataraid
My Ride: 2001 BMW 330ci
What the hell you didnt remove the protective cap??? I thought your intercooler was clogged. Thats why I said to try to by pass it.
sataraid is offline   Reply With Quote
Old 11-30-2008, 09:40 PM   #92
sataraid
That cant be on your car.
Old 11-30-2008, 09:49 PM   #93
lrogers80
My Ride: 323i
Yep. My friend that helped me install this kit, installed the supercharger and and I did the piping, I had no clue that that cover was there simply because he had already installed that elbow to the compressor side.
I soon as I took it off and got everything put together, the car spiked into boost and I almost lost the rear. This car has so much power I was a little nervous hitting it. I knew it had to be something simple. I actually was going to remove the entire supercharger and start from scratch until I noticed this big red cap looking at me.
I am so happy. Thanks everyone for helping me keep this quest going.
Old 11-30-2008, 10:57 PM   #94
AntB
My Ride: MTA :(
One of those D'OH! moments. We all have them.
("My computer isn't working, I took it apart, I checked the compoents, etc!" "Well, is it plugged in?" "SH1T!")
Have fun with the car and be careful.
** Tim330i waz hur **
AntB is offline   Reply With Quote
Old 12-01-2008, 01:13 AM   #95
paraklas
My Ride: ESS TS2 320ci
Next time tell your friend to limit the help to watching/taking photos/bringing f00d
Old 12-01-2008, 01:15 AM   #96
Maestroxl
My Ride: 330CI
Send a message via MSN to Maestroxl
Congrats! Told you something was blocked.
Maestroxl is offline   Reply With Quote
Old 12-01-2008, 02:31 AM   #97
parad0x
My Ride: E46 M3 Jet Black 6sp
your lucky that didnt damage your SC unit.. I would check the entire plumbing for left over bits, primarly your intercooler (inside the tanks on both ends), as well as intake manifold.
parad0x is offline   Reply With Quote
Old 12-01-2008, 05:38 AM   #98
lrogers80
My Ride: 323i
This was a stupid mistake. I almost didn't want to post the solution, but I know someone out there might run into a similar problem one day. I really hate when people start threads and never post the solution in the end. Thanks again everyone.
Old 12-01-2008, 10:12 AM   #99
Active Autowerke II
Past Site Sponsor
Active Autowerke II's Avatar
My Ride: BMWs
Send a message via AIM to Active Autowerke II
Glad to see everything worked out.
Active Autowerke II is offline   Reply With Quote
Old 12-01-2008, 11:33 AM   #100
docwyte
Wow, that's crazy. Definitely check everything to make sure you don't have bits and pieces in the intake tract.
'98 M3, track beast
