Old 11-23-2008, 06:00 PM   #1
ou330ci
My Ride: 330ci
car is driving me crazy!
alright so about 2 months ago my car started stalling and idling rough so i took it to the dealer and they told me i had a cracked intake boot and bad cam sensor and thremostat was stuck open. so while i was replacing these i noticed my alternator was well on its way to going bad so i went ahead an replaced that also. the next day after fixing everything my starter goes out. so after all of this the car drives good for about two weeks..then the cars idle gets worse than ever and while driving it misfired so bad it would barely move. so i babied it home and had the codes pulled and it said lean bank 1 and 2 along with cam sensor and O2 sensor heater problem. but i got to looking at it and saw that my intake boot came off at the throttle body and i fixed it and cleaned MAF and replaced air filter. it drove good for a day then when driving around the city it started idling bad again and would barely move... it seems to do it more after the engine heats up. i checked the boot again and it didnt fall off again so now im stuck on what could be doing this? anyone have any ideas?
ou330ci is offline   Reply With Quote
Old 11-23-2008, 09:13 PM   #2
reynaldo
My Ride: 2001 325i Sedan
Send a message via Yahoo to reynaldo
I have the same code. Bank 2 (code E4) I believed is oxygen sensor adaptation limit Cyl 4-6. I will replace my plugs, ignition coil and boots. Will keep you posted if the Code E4 will vanish.
reynaldo is offline   Reply With Quote
Old 11-23-2008, 10:00 PM   #3
ou330ci
My Ride: 330ci
let me know if that solves the problem. i have read about people having this same code but most people just have rough idle. once my car gets hot it will barely move because its misfiring so bad so i have no clue what the problem could be
Old 11-23-2008, 10:38 PM   #4
prznskillz
My Ride: 2001 JetBlack 330ci
Send a message via AIM to prznskillz
i had a similar problem turned out to be my ccv/ oil seperator...01 330ci
prznskillz is offline   Reply With Quote
Old 11-24-2008, 11:17 AM   #5
ou330ci
My Ride: 330ci
bump
boot, maf
