Under-heating...??? - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 11-25-2008, 08:42 AM   #1
umermariner
My Ride: 1999, 328I
Under-heating...???
Hello,
About a week ago I noticed that the temp. Gauge in my car was not going to 12 O Clock. The gauge would just move 1/4 instead of 1/2. I checked the coolant, and it was really low (I could not see it). So I added more coolant (without any draining procedure). I was expecting it to take a lot more coolant then it took (maybe an air lock).
However, my baby is still under-heating, and the heater is also not working as good, even if I take it for a 20 mile ride.
I am confused. I thought if there is air trapped, it should over heat.
I will appreciate any help.
Thanks.
umermariner is offline   Reply With Quote
Old 11-25-2008, 08:54 AM   #2
vminev
My Ride: 325ci
Maybe your gauge is not working properly....
vminev is offline   Reply With Quote
Old 11-25-2008, 08:56 AM   #3
umermariner
My Ride: 1999, 328I
I would think that if the climate control works properly. I set it at 91 now, and it still does not push in as hot air as it used to.
Old 11-25-2008, 06:36 PM   #4
M3GA
My Ride: 2003 BMW M3
Check your thermostat!!
M3GA is offline   Reply With Quote
Old 11-26-2008, 04:55 AM   #5
mkodama
mkodama's Avatar
Thermostats in the E46 are designed to fail in the open positions. It won't light up the SES light on your dash but it will give a code. They aren't too expensive and they aren't hard to replace. Good luck!
Old 11-26-2008, 05:44 AM   #6
umermariner
My Ride: 1999, 328I
So you mean, I should be able to get a code?
Also, what is the best way to confirm Thermostat failure, before actually taking it apart... temperature difference b/w hoses? I tried that this morning.. but was not sure...
Any other way?
Thanks.
Old 12-01-2008, 09:31 PM   #7
kuksul08
My Ride: M3
If your car has a lot of miles you might want to replace the thermostat anyway. I recently did it and the car heats up much quicker.
I had a code before that said coolant temperature below engine regulating temperature or something like that which means it was running too cold.
Look at that subtle jet-black coloring. The tasteful thickness of it. Oh my God, it even has a 6mt.
S54 Valve Adjustment Spreadsheet & Info: http://dl.dropbox.com/u/28231781/S54...ent%20info.zip
S54 VANOS DIY Video: http://www.youtube.com/watch?v=9SkT2j3jsU0
kuksul08 is offline   Reply With Quote
Old 12-02-2008, 09:14 AM   #8
umermariner
My Ride: 1999, 328I
I ll run the codes too... but I just had it changed around 15000 miles ago
Old 12-02-2008, 09:28 AM   #9
thearmyman83
My Ride: E46 M3 THE SLVRBULET
im in an 03 m3 and my temp is just a cunt hair under 12 oclock sometimes a little lower within .25" of the "correct" position but it is 20-30 degrees here right now. NORMAL?
KICKIN ASS IN THE SLVRBULET
thearmyman83 is offline   Reply With Quote
Old 12-03-2008, 03:50 AM   #10
mkodama
mkodama's Avatar
Any other way?
Thanks.
Yeah, the only way I found out that I had a thermostat failure is when I went to the dealer for my broken transmission and they gave me a code readout. So I bought a new thermostat, installed it, and sure enough, it warmed up a little quicker than normal and my mileage improved slightly.
Obviously though, if you car never gets to the 12 o'clock position than something is wrong. If you recently replaced your thermostat and don't think that is the issue you can have the codes read.
Old 12-03-2008, 08:16 PM   #11
my1stbimmer:)
My Ride: '00 323i ---'06 X-5
Have you bled the air out with the heat turned on?
my1stbimmer:) is offline   Reply With Quote
Old 12-03-2008, 08:45 PM   #12
umermariner
My Ride: 1999, 328I
I tried.. .. i losen the plastic screw just near the radiator oppening.. the heat was at 91, and the fan was at the min.. but still no air bubbles.. i didnt lift the front end though
Old 12-03-2008, 08:50 PM   #13
simsima325
'a certain moderator'
simsima325's Avatar
My Ride: Honda Civic
thermostat. replaced mine in 20min, topped up on coolant, and she settles nicely at 12 oclock. gets there fast too.
-Brendan
Old 12-03-2008, 08:51 PM   #14
umermariner
My Ride: 1999, 328I
20 mins :O... didnt you have to take out the fan and stuff?
Old 12-03-2008, 08:57 PM   #15
simsima325
simsima325's Avatar
fan comes right out, gotta remove the belly pan too, there will be some coolant drippin
-Brendan
Old 12-03-2008, 10:08 PM   #16
umermariner
My Ride: 1999, 328I
hmmm.. u mean.. taking out the fan... and then replacing it will be about 20 mins.. hmm.. thats not bad (even if it is up to an hr.. its ok).
What do u mean by belly pan?
Old 12-03-2008, 11:14 PM   #17
simsima325
simsima325's Avatar
the plastic panel under your engine
-Brendan
Old 12-04-2008, 06:15 AM   #18
umermariner
My Ride: 1999, 328I
hmmmmmmmmm
I ll do that... as soon as the weather gets better ... any other hint that may help me?
Old 12-04-2008, 09:42 AM   #19
umermariner
My Ride: 1999, 328I
Question:... I looked at it.. seems like I can open it easily.. without even taking out the fan and the plastic pan..
but why everyone is suggesting to take these things out? Do I need to? I have manual transmission, and it has an electric fan.
Old 12-06-2008, 07:49 PM   #20
ApathyCsl
Banned
My Ride: 2002 325i
Thread Jacking.
Just replaced my upper hose and expansion tank after a bad overheating incident. Bled the system and Car runs fine now but the temp gauge is a few hairs past 12oClock. is this normal?
ApathyCsl is offline   Reply With Quote
