Rating:
Display Modes |
#1 |
So on a cold night last week, I went to pick up a friend. Pulled up out front, rolled down the passenger window to yell out something smart, then went to roll it back up, and nothing happened...
After a cold ride home, I pulled the door panel apart to get a closer look at what was happening (and get the window back up manually). Upon disassembly of the panel, I found that the motor was still functional, but (get this) it only turned in one direction. If i pushed the button to roll the window up, the motor spun clockwise. If i pushed the button to roll the window down, the motor spun clockwise. Really weird. So I've disabled the button (pulled the power to the motor), and manually raised the window. My troubleshooting is leading me to suspect a faulty window switch - anyone have any ideas/experience with an issue like this? I couldn't find anything on the forums. Also, anyone interested in a straight-up trade? My 330ci with a busted passenger window, for your low mileage alpine white m3 convertible . Just throwing it out there... |
#2 |
window regulator?
#3 |
My Ride: Bus,Metro,Train,325i
if there was snow on your window then water got in ...
Next Stop: ProchaineStation™ ![]() Montreal, world transit & infrastructure enthusiast. www.youtube.com/AntoDamicoShow |
#4 |
My Ride: 3.0 | 200hp | 214trq
could be either a faulty switch or a faulty motor.
#5 |
#6 |
-JoeVert
#7 |
Could be either a faulty switch or a faulty motor.
#8 |
#9 |
#10 |
Similar situation happened to me and it turned out to be the window regulator! If you do a DIY search you'll find great instructions on how to repair it! I took mine to the stealer and it costs nearly $400!!!!
#11 |
if you have a multimeter you can test the voltage to your switch, and after your switch. if its good there than its the motor.
00' 323Ci
Performance: Magnaflow Exhaust no resonators, K&N Drop-in, Ebay headers, Redline D4ATF Exterior: Painted 44's Gunmetal, Yellow Fogs, Tinted Windows, Debadged, Clear Corners Audio:Kicker 12" CVR, Kicker 400.1 on factory HU Purchased 11/11/2008 |
#12 |
had an old audi that would do that, if you rolled the window all the way down it wouldn't come back up unless you pulled the switch out and shorted the "up" pins with a paperclip.. fun times..
i got a new switch at a junkyard and fixed it.
#13 |
could be a swtich or motor.
most likely switch. |
#14 |
Thx all. Funnily enough the actual switch for that window has been a bit loose. Have ordered a replacement which should be at home when I return.
Is it possible for something in the motor to "go" in a way that would make it only spin in one direction? It still operates perfectly normally when rolling the window down, but when I pull it to roll the window back up, it just rolls down further, same speed. Got the window jimmied up so its closed (not tucked under though, the motor does that once the door's closed) and disabled the switch, but the wind whistle at highway speeds is gonna kill me on my 12 hr drive home (PA to ATL) Monday |
#15 |
Modifiziertes ///Mitglied
| | | dun dun duuuunnnn |
#16 |
My Ride: '90 325i, '02 325it
if it's the switch couldn't you just use another window switch in your car to get the window up?
- James '85 E30 325e '90 E30 325i '02 E46 325it '03 E46 320i '96 Volvo 850R ![]() |
#17 |
i had a similar experience. After replacing the relays, then the window regulator I was fixing to replace the motor,
but then I noticed it turned one way only. The Bentley manual doen't help much here but after figuring how the switch works I shorted out the pins that make it roll back up and could roll the window up.The other switch for the passenger side has a different teminal connector so I couldn't swap them over. I read a lot of posts where people had the same problem - motor only turns one way. But nobody explained about the switch. Anyway hope this helps someone else. |
#18 |
lmao @ the repeats.
#19 |
Im having the same problem . The window will roll down but i hear the motor running and it will not roll back up ... interesting but i have yet to find a solution
#20 |
I'd put money on a regulator...I've had to replace both rear window regulators and my front right is starting to click. In both of my rear windows, the cables/plastic parts broke and cable was all tangled so it would go down but so tangled it would not go back up. I bought both of mine off ebay, been over a yr and they still work fine. 30-40 min job depending on skill.
| Tags |
| only down, switch, window |
