#1 |
Does anybody know of any published numbers we should be shooting for when compression testing an M54 330i?
Also, assuming that such numbers exist, how would they take into account the fact that different length hose extensions can produce vastly different compression numbers? |
#2 |
I've never heard of published numbers in those terms, I think there could be to many variables, I've always understood that your looking for numbers to be within a certain percentage or window between all of cylinders.
#3 | |
Still, I've heard that there are "service limits" to these things, and some professional sources have cited that there should be published figures somewhere. If I can't find it though, oh well. Relative measurements should do OK. |
#4 |
My Ride: 2005 330I 6Spd.
142 to 156 psi, 7 psi max deviation cyl to cyl. Bentley manuals are only $70 on Amazon. You can cook the ECM if you do it wrong, so get the Bentley and
! New ECM or Bentley......I think you would rather buy the latter! |
#5 |
Just did mine 2 weeks ago, first you'll be using a gauge with only "one" length
of hose for all cylinders, don't add or shorten as you go. More compression is always better than less, having said that, what your looking for is consistency between all cylinders. If your within 5% for all 6 your doing very good, if your within 10%, thats still considered OK. A) Good- 180-179-182-181-178-180 B) Bad- 180 179-94-181-179-180 If you have engine "A" your engine is in great condition. If you have engine "B" you have a real problem. Rob |
#6 | ||
![]() Quote:
Also, how'd you hold the throttle plate open? I'm still unsure as to whether or not holding the gas pedal to the floor would open the throttle on a DBW car (like ours) when the engine isn't operational. |
#7 |
#8 | |
I'll make a call tomorrow, find out exactly, and get back to you. Rob |
#9 | |
That'd be awesome, thanks. I'm considering doing a DIY as soon as I gather all the available info. Considering. |
#10 | |
Bentley has 3 pages covering compression/leakdown testing on the 330i. One of the Cautions reads "Failure to remove the DME main relay or attempting to disable the ignition system by other methods may result in damage to the engine control module" from 113-31 in the Bentley. Some here may have run a compression test without removing the DME main relay and done it with no ill effects, but is there any solace in that fact for you to follow their lead and cook your ECM???? |
#11 | |
I read in several places that I should remove the DME main relay, but none cited why. See? Multiple sources will eventually lead to an extremely accurate conclusion. Wikipowar. Until I start doing more serious business, I don't want to buy a Bentley Manual. |
#12 |
OK here it is, first it's a 2 man job. Pull out all coil packs, remove all
plugs. Remove the DME main relay. Have helper crank motor with throttle wide open, about ten revolutions per test. Your looking for the average number per test, so if the needle on your gauge is going between 170 & 180, that cylinder is 175. Move to next cylinder until your done. Ideally you want all cylinders as close as possible, within 10% is OK but 5% or less would be better. Rob |
#13 | |
Also, this is something nobody's been able to answer. Can the throttle plate even open when the gas pedal is to the floor? These cars are Drive-by-Wire, so I'm wondering how to keep the damn thing open to allow the max. amount of air. |
#14 | |
relay/location. Next, remember your cranking the car, it's electrically on, so the drive by wire throttle is obeying your commands. Rob |
#15 |
That's what I thought, only difference between contact and "full operation" is the fact that the engine's spinning. I wasn't sure though because when I get in, put it on contact, and tap the throttle, I hear nothing from the engine... Probably just can't hear the plate though.
