Old 11-29-2008, 08:36 PM   #1
curlesw
My Ride: 01 325i
Need help on fault codes (Peake reader)
I purchased a Peake R5/FCX(3) code/reset tool for my 2001 325i. I have reset the "service engine" light a couple times and get the following codes:
1) 19 - Ignition Coil Cyl #1 or PreCat 02 sensor heater insufficient, cyl #1-3
2) A8 - Idle speed actuator (open)
I'd appreciate any insight into if there is anything I can do to fix these items.
Thanks.
Wayne C.
2001 325i
curlesw is offline   Reply With Quote
Old 12-09-2008, 09:31 PM   #2
joson5
My Ride: 2003 CiC
Send a message via Yahoo to joson5
Wayne,
I hope you don't mind me correcting how you read your fault code. You made a mistake interpreting your code, it should have been go to Table 19 then the code is A8. A8 according to our peake research fault code is a "Coolant thermostat jammed or stucked open".
I have the same problem, I will take it to the Dealer because I bought an extended warranty on my car and it's still covered.
Regards,
Emmanuel Joson
joson5 is offline   Reply With Quote
