Sponsored by BAVSOUND
Thread Tools Search this Thread Rating: Thread Rating: 82 votes, 4.95 average. Display Modes
Old 07-30-2011, 05:19 PM   #61
KuyaPatrick
My Ride: 2003 330i
how did you take out the headlight switch? I am trying to take mine out and it seams like I might have to cut some wires off?
KuyaPatrick is offline   Reply With Quote
Old 07-30-2011, 09:21 PM   #62
KuyaPatrick
My Ride: 2003 330i
Thanks a lot for the directions and the pics. they were very helpful in takeing mine apart. I have to get to the evaporator core. Any ideas on how to take that crossbar off? my main concern is the connection to the steering column. ideas?
Old 08-18-2011, 09:33 PM   #63
bimm3rman1991
My Ride: 2006 BMW 325ci
wow that's intense
bimm3rman1991 is offline   Reply With Quote
Old 07-02-2012, 09:45 PM   #64
gavi
My Ride: BMW 330Ci sport 6MT
Can't remove the gearshift surround please help!!! Stuck on the rear part I pulled the front part off(close to ashtray)
gavi is offline   Reply With Quote
Old 07-02-2012, 11:30 PM   #65
gavi
Done thanks. Just pulling the leather cover, then unscrew two screws and it comes out!
A BMW can't take you as far as a diploma.
Joyce Meyer
Old 08-10-2012, 01:48 PM   #66
royalratch
My Ride: 03 320d SE Touring
Originally Posted by BoomBoy View Post
I dont now the exact word for those.. but they cover the airbags in both sides and sit between the door and the windscreen. You have to remove them to get the dashboard out because of some clips
You mean the A-Pillar airbags.
I did describe how to remove these - prize off the strip covering 3 or 4 torx screws. Then remove the main trim. The actual airbags do not need to come off.
royalratch is offline   Reply With Quote
Old 08-24-2012, 01:10 AM   #67
81forest
My Ride: skinny tires
Royalratch, this is an incredible write up and by far the best that I could find on the web for E46 dash removal, well done! I am about to purchase a 328i Sport that has a plugged heater core. The seller was quoted $1000 by an indy shop to replace the core, mostly labor for the dash removal. Did you see the heater core behind the dash, and is there any additional stuff that needs to come out to get at the core? Trying to do it myself and get the car for cheap. Again, thanks for the time and energy of posting this DIY, it is really good stuff.
81forest is offline   Reply With Quote
Old 09-06-2012, 07:02 AM   #68
royalratch
Once you get the dash out the hvac set up is there but the core (the actual mini radiator / matrix) will be buried inside somewhere - I wouldn't have thought it was too difficult to replace once the dash is out - drain the car of coolant fully first!
Old 09-06-2012, 07:43 AM   #69
'busa
'busa's Avatar
My Ride: E90 335i (sold)
This was very useful to me. Glad the pics are still up! Thanks a bunch!
'busa is offline   Reply With Quote
Old 09-29-2012, 03:55 AM   #70
Ballistic325
My Ride: slow and steady
Bump for an awesome DIY
I can help with
* Reading Codes / Coding your car
* R&R FCAs, Tie Rods, Sway links....
* RTABs
Need an RTAB tool? Or clutch fan and water pump tools? PM me.
Ballistic325 is offline   Reply With Quote
Old 03-21-2013, 10:29 PM   #71
M3HER310
My Ride: 2003 BMW M3
Very helpful thanks! Took about 1.5hour
ID:	496580   Click image for larger version
M3HER310 is offline   Reply With Quote
Old 03-21-2013, 10:49 PM   #72
2000_328CI
2000_328CI's Avatar
My Ride: 328Ci | Range Rover
badass
| 435 HP 328Ci | RRT Racing | Designer Wraps | Active Autowerke | Vorsteiner | STATUS Racing |
Timeless Motor Group
Old 03-21-2013, 11:24 PM   #73
M3HER310
Haha thanks
Old 09-21-2013, 11:36 PM   #74
Avetiso
My Ride: 2003 ZHP 6MT
I reinstalled my dash, but it doesn't seem to sit flush at the side where it comes into contact with the lower A pillar (around the area where the door and dash come very close to each other when the doors are closed). Anyone have any ideas? I've reinstalled it multiple times, and just went with it and fully installed everything back. Everything seems just fine but the fitment just seems off, and it bothers me.
Avetiso is offline   Reply With Quote
Old 11-05-2013, 06:50 PM   #75
Kenbobo
My Ride: e46
I have the same problem. Any ideas?
Kenbobo is offline   Reply With Quote
Old 11-05-2013, 07:58 PM   #76
M3HER310
Re: E46 Dash Removal / Replace - Detailed Pix
The same had happened to me also but after 2 months the gap closed. I think it is because it loses it's shape once its out of the car?
Old 01-15-2014, 02:14 PM   #77
KrasivataSabine
My Ride: 323Ci
Sub'ddddddddd
#BattleBimmer #323RS
KrasivataSabine is offline   Reply With Quote
Old 08-19-2015, 06:11 PM   #78
thegenius46m
My Ride: E46 M3, E63 M6
Bump. Same issue here. Everything seems to fit and function fine other than my center console not being a tight fit and the a pillars don't seem to fit in properly. Seems like the dash may need to be pushed higher up, so can I just remove the screws attaching it to the frame and the bolts holding it behind the trim to wedge it further forward? Everything else went into place, so it didn't seem to be my issue until I did further research and have struggled to get the a pillars in.
2003 E46 M3 TiAg/Cinnamon 6MT
Purchased:11/13 with 58k miles
thegenius46m is offline   Reply With Quote
Old 08-20-2015, 03:11 AM   #79
thegenius46m
Well everyone I GOT IT!
Had to remove half of the dash on each side to allow it to sway a little outward (must not have been aligned perfectly from the swap), then I was able to shove the corner in and pull back BEHIND the dash (read this somewhere and it proved successful). Can gladly say they are IN! These better last another 10 years because No way in hell am I ever doing that again!
Old 11-16-2015, 09:43 AM   #80
royalratch
Well done everyone for having a go - glad I could help in some small way.
Dash alignment is pure trial and error but you MUST get it right before you bolt anything in - fiddle with it any which way that works until its siting perfect then add bits back in. Its easy to get it caught up on various tabs or for cables and plugs to get caught behind the dash preventing it for going back in perfectly.
dash, dashboard, diy, install, remove, replace
