Ok, so certain of the e46's have a Self Adusting Clutch
According to the Bentley manual, this requires several special (read expensive) tools to fit. Fortunatley i have found it's possible with some more common ones.
The SAC works by having a rotary plate inside the cover plate assembly that is pushed clockwise by springs. As the clutch wears, this rotary plate slowly moves clockwise to take up the wear.
NB. It seems that new clutches come with this SAC pre-reset in the anti-clockwise position with a shipping plate. But if you want to refit an existing clutch you need to reset it.
To reset the SAC you will need a large 3 legged bearing puller as in the picture (these are relatively cheap, i picked up a set of 4 for about $30).
Before the SAC can be reset the diaphram spring must be compressed. I made a cylindrical block on a lathe which just sits inside the spring fingers. If you dont have a lathe, some improvisation could be done.
1. Insert the puller as shown & compress the spring. Note that the silver SAC plate underneath can be freely moved now.
2. Fit the clutch disc on to the flywheel with the normal centering tool.
3. With the spring still compressed (puller attached) fit the cover plate to the flywheel & tighten all the cover bolts.
4. Using a screwdriver or similar, rotate the silver SAC plate fully anti-clockwise. Note there are alignment marks near the small springs to show this.
5. Keep the SAC plate in the anti-clockwise position with the screwdriver while removing the pressure on the diaphram spring, and remove the puller.
Well if you want to replace your clutch than maybe it is also better to replace the pressure plate the SAC system self. If you buy a clutch set than you will get a new clutch with the pressure plate already setup. Only you have to do is remove the new diaphram when the installation is complete. This D.I.Y is great really but, its only comming handy if the installer want to re-use the pressure plate.
This is great, I'm just hoping that it'll work for me. I'm converting my 740iL from an auto to a 6spd that I picked up from an M5 w/ 24k on the odo. I'm curious though, so bear w/ me and tell me if I understanding this correctly.
It seems that the SAC is a wheel that slowly spins clockwise as the clutch surface wears, so use that puller to just press the fingers, turn the wheel counterclockwise back to zero, then release the fingers and it'd lock the spinning wheel? I realize that I need to bolt on the flywheel, then the put up the clutch and pressure plate, but then how am I getting the alignment tool in there if the puller is in the way holding the fingers down on the pressure plate?
That makes sense. What about my idea of just resetting the SAC disc then just releasing the puller. Is my understanding correct and is that possible so I don't have to have the puller on while installing the clutch.
Exactly...why replace my clutch w/ a brand new one when the one I have now only has 24k on it.
I'm still curious as to if I can just reset the clutch w/ the need to be installing it in the car at the same time. Can I just reset it on the bench and remove the clamp and it'll stay reset? I got a 3 finger puller set from Harbor Freight and we able to push the fingers of the pressure plate down, but I couldn't get anything to spin or find anything moveable.
Maybe, but you would have to find some way to lock the mechanism in place while you fit it (like the transit lock the new clutch comes with)
Is it not easier to do in-situ as my photo's?
I have no issue doing it the same way you did, I was just hoping to not have to go re-purchase the puller again. I stripped the 1st set I purchased trying to remove the CV Joint in my X5, so I returned them. I'll just buy them again when the time comes to install the clutch into the 7. Thanks Hoss.
You dont have to remove the pressure plate to reset it, just hook up the puller as in the photos.
But, why would you want to do that? the only reason to reset the SAC is if you have fitted a new friction disc....
Thanks for this post, it may of saved me 700 bucks(I'll send you a check). So if I don't reset the springs properly, whats the worst that can happen? Will my tranny go back on if its done improperly?
If you dont reset the springs properly, then as the clutch wears, it will not self-adjust - i.e. more & more pedal travel until (possibly) clutch slipping even when there is still life in the friction plate.
But there's no reason not to reset the springs properly if you follow this procedure, it really is easy.
I have a rear seal leak and need to get to it. What centering tool do you need to center the pressure plate? Is there a non BMW method, or do I need to buy a centering tool just for this? Many thanks indeed!!
I'm trying to do this and I have the 3 legged puller but what can i use that i can pick up from a retail store in place of the cylindrical block made on a lathe. I do not have on nor have access to one. Any ideas would be greatly appreciated. Thanks in advance
Since this is a DIY and will help someone in the future, I'm going to be a necromancer and bring this thread back from the dead to share my experience.
Get a 1/2" pipe flange like the one pictured along with a 1/2" pipe plug like the second picture. centers the puller nicely and worked great for me to compress the springs. About $4 at my local Menards. YMMV.
RE bump. Had to swap M54 2.5 in my 2001 Touring. After looking at this thread (THE best that I found) I bought an 8" 3 jaw puller at Harbor Freight and used a plate out of a bushing driver set I own. Worked perfectly. The existing clutch disc had less than .2mm wear, so I saved plenty on a new clutch kit. To the OP (from 2008 !!!), thanks for posting and sharing the pictures.
This is the tool you need to turn the SAC mechanism...a shorty pry bar!
Related Threads
E46 Fanatics Forum
17.9M posts
592.5K members
Since 2001
A forum community dedicated to BMW E46, E90, and F30 owners and enthusiasts. Come join the discussion about M performance, turbo kits, engine swaps, builds, modifications, classifieds, troubleshooting, maintenance, and more!
