Old 12-03-2008, 06:58 AM   #1
WilkesE46
My Ride: 04' 330Ci 6SP
Replacement Cooling System Hoses
Hey guys,
Does anyone know if there is an aftermarket manufacturer of cooling system hoses for E46's? I have looked at Samco, but it seems like they only make them for up to E36's.
Also, does anyone know an online retailer that sells a complete cooling system replacement kit? AKA, new hoses, expansion tank, thermo + housing, etc...
I think I will tackle this job after I get my intake/spark plugs/ fluids changed. Thanks in advance!
WilkesE46 is offline   Reply With Quote
Old 12-03-2008, 07:18 AM   #2
bigjae1976
bigjae1976's Avatar
My Ride: 2011 E90 M3
Originally Posted by WilkesE46 View Post
Hey guys,
Turner sells something like that. I'm not sure if it comes with hoses though.
2013 F30 328i - Melbourne Red
2004 E46 M3 - Imola red
Old 12-04-2008, 01:49 PM   #3
WilkesE46
If I recall, there is some online retailer that sells complete coolant system replacement kits, with hoses, coolant, water pumps, etc. I think Turner just sells the pieces separately...
Old 12-04-2008, 03:04 PM   #4
bigjae1976
bigjae1976's Avatar
http://www.trademotion.com/partlocat...catalogid=4462
Tischer does as well.
Old 12-04-2008, 03:36 PM   #5
Evan@Tischer
Your #1 BMW Part Source
Evan@Tischer's Avatar
My Ride: Honda Ridgeline
Send a message via AIM to Evan@Tischer
Hey guys,
It's a good idea to stick with the OEM parts as you'll be covered under BMW's 2 year/unlimited parts warranty if anything goes bad.......we have the complete kit here!
Kit includes genuine BMW:
Thermostat w/ housing/gasket (11537509227)
Waterpump (11517527910)
Upper radiator hose (17127510952)
Lower radiator hose (11531436408)
Expansion Tank (17117573781)
Radiator Cap (17111742231)
Engine drain plug crush ring (07119963200)
Lower hose temp sensor (13621433077)
1 gallon BMW antifreeze (82141467704)
*Price includes Free Ground Shipping! (US only)
Evan Winstead
Internet Parts Manager, getBMWparts.com
Email: getHelp@getBMWparts.com AIM: Evan at Tischer Follow: FaceBook | Twitter
Evan@Tischer is offline   Reply With Quote
Old 12-04-2008, 10:34 PM   #6
WilkesE46
THAT'S what I was looking for! Thank you very much!
Old 12-12-2008, 01:40 PM   #7
WilkesE46
Oh, I plan on calling you guys to ask, but thought I'd ask here as well: Is there any way to substitute the Stewart water pump for the OEM one in this package?
Old 12-12-2008, 02:24 PM   #8
bigjae1976
bigjae1976's Avatar
Probably not. The Stewart pump really isn't worth it unless you plan on driving your car for another 180k and/or track your car.
And I have not seen any reassurance that the Stewart pump will last that long.
Old 12-12-2008, 02:44 PM   #9
WilkesE46
Well, I plan on building the car for club racing next year, so I figure I might go with the Stewart. Where have you heard that the Stew. pump will not last?
Old 12-12-2008, 03:46 PM   #10
bigjae1976
bigjae1976's Avatar
I meant I haven't heard anything that says it WILL last.
I have the stewart pump and haven't had any cooling issues so far. It looks much beefier than the OEM one.
Old 12-13-2008, 01:20 AM   #11
vaio76109
My Ride: Race Cars
Originally Posted by wilkese46 View Post
well, i plan on building the car for club racing next year, so i figure i might go with the stewart. Where have you heard that the stew. Pump will not last?
bmwcca? Jp?
vaio76109 is offline   Reply With Quote
Old 12-13-2008, 07:19 PM   #12
WilkesE46
bmwcca
Old 12-14-2008, 01:34 PM   #13
vaio76109
My Ride: Race Cars
bmwcca
What class?
Old 12-14-2008, 04:22 PM   #14
WilkesE46
Stock hopefully, and I know that in the 2009 rules the water pump can be replaced with something like the Stewart unit. I'm also trying to find the darn volume of our stock expansion tank because I want to upgrade it to a metallic unit, but thus far I have had no luck finding that number out...
Old 12-14-2008, 10:10 PM   #15
bigjae1976
bigjae1976's Avatar
Zionsville makes an all aluminum radiator with a built in expansion tank. It is expensive though.
Old 12-15-2008, 07:08 PM   #16
WilkesE46
Jesus that thing is expensive! But it looks damn nice though...Does anyone make an aluminum radiator for our car that is not THAT wild? Maybe a visteon unit?
Old 12-15-2008, 07:52 PM   #17
vaio76109
My Ride: Race Cars
BimmerWorld has 1 or 2 sources, call them.
Old 12-16-2008, 08:47 AM   #18
bigjae1976
bigjae1976's Avatar
Hey, don't say that I didn't warn you.
Old 12-16-2008, 11:28 AM   #19
mrshelley
My Ride: 2004 330i
Behr or Nissens make really good radiators. It'll fit perfectly. That's all I use in my racecar. A Behr goes for around $160.
Are you going to replace the two plastic water pipes (with the four rubber O-rings) on the engine along with the four heater hoses? All of those parts should be replaced at the same time as they are just as old and see the same heat as the rest of the cooling system. Then there's the aluminum washer on the drain for the engine block.
Old 12-16-2008, 09:32 PM   #20
WilkesE46
Do you have links to the Behr or Nissen units? Also, I apologize, but what exactly do you mean by "the two plastic water pipes", do you have a diagram?
cooling, hoses, replace, system
