Go Back   E46Fanatics > Everything Else > The Off-Topic > Home Improvement
Home Improvement
Home Improvement ideas, help, DIYs, and show room. Got a home improvement project you need help with or want to share. Post your project now!
Old 12-05-2008, 12:28 AM   #1
slo323ci
My Ride: 00 323ci
2 Gang wall plate big enough?
Hey guys trying to figure out if a 2 gang wall plate will be big enough for:
22 or 24 gauge DVI-HDMI(inwall)
18 guage 3 RCA(Component)(inwall)
Skinny RCA
2 VGA(inwall) from Monoprice
I will be using This
Or do you think a 1 gang will be enough? Thanks in advance!
slo323ci is offline   Reply With Quote
Old 12-05-2008, 01:58 PM   #2
'busa
'busa's Avatar
My Ride: E90 335i (sold)
What is this? How do you use it?
'busa is offline   Reply With Quote
Old 12-05-2008, 04:30 PM   #3
slo323ci
My Ride: 00 323ci
Clean way to allow wires to go in and out of the wall, but without putting an coupler inbetween.
Old 12-05-2008, 04:34 PM   #4
tmerrick
My Ride: 2001 330i
Send a message via AIM to tmerrick
I have had great luck with http://supercellaudio.com/ you design it and he makes it custom, whatever your pattern / needs are. I would rather be safe and terminate at the wall, you never know how much extra cable you will need in the future.
Tyler Merrick.com
tmerrick is offline   Reply With Quote
Old 12-05-2008, 06:28 PM   #5
GlockMan
GlockMan's Avatar
My Ride: Suburban LT 4x4
use this...
the least connections the better
make sure your doesnt say "monoprice" on it
kinda tacky
!!! ROLL TIDE ROLL !!!
National Champs: 1925, 1926, 1930, 1934, 1941, 1961, 1964, 1965, 1973, 1978, 1979, 1992, 2009, 2011, 2012, 2015, 2017?
Ranting about Panny plasmas, Canon cameras, Glocks, BlueNile, and HDMI on a BMW board since 2005.
2016 Honda Accord Sedan V6 Touring (wife)
2007 Chevy Suburban LT 4x4 with Nav/Bose/DVD
1968 Ford Mustang with Polk/ADS (my first car)
2007 Lexus GS350
2000 BMW DINAN M5
2001 BMW 330ci
GlockMan is offline   Reply With Quote
Old 12-05-2008, 09:37 PM   #6
'busa
'busa's Avatar
Any "wall mount / cable wiring behind the wall" DIYs? Also, is it OK to run power cables with these cables?
Old 12-07-2008, 10:00 PM   #7
slo323ci
My Ride: 00 323ci
Originally Posted by glockman9c View Post
use this...
kinda tacky
Glockman, will a 2 gang be the right size? Or would a 1 gang work?
Old 12-07-2008, 10:02 PM   #8
slo323ci
My Ride: 00 323ci
Use the wall mount as a guide for the screws... drill a hole in the wall and fish down the video cables. Put an outlet behind the TV but not behind the wall and plug in the tv there. Do not put power the wire behind the wall.
Old 12-08-2008, 08:25 AM   #9
'busa
'busa's Avatar
Huh?
Why is that not recommended? Interference?
Old 12-08-2008, 09:55 PM   #10
trippinbillies4
trippinbillies4's Avatar
My Ride: '02 Mini, '13 FR-S
2 gang should be fine for that, just work from biggest connectors to smallest connectors.
__________________________________________________
'02 Mini Cooper #40HS, '13 Scion FR-S #40CS, '12 Ducati SF848
trippinbillies4 is offline   Reply With Quote
