Go Back   E46Fanatics > BMW News from around the Web
Submit the latest BMW news from around the world for other E46Fanatics members to check out.
Old 11-30-2008, 09:53 PM   #1
simsima325
'a certain moderator'
simsima325's Avatar
My Ride: Honda Civic
Clutchmasters FX100 Clutch and JB Racing Flywheel Review
The topic of clutch and flywheel replacement is of increasing interest to the E46 community, as these cars get on in years. Having found my clutch engagement becoming messier over the last two years, the search was on for a replacement.
My 2001 325Ci is a daily driver, so naturally I was focused on finding the clutch and flywheel setup that would best meet my goals of retaining the best drivability while adding a sporty feel to my shifting. After searching the internet and hearing many positive reviews of the entire line of Clutchmasters FX clutches, I set about deciding which stage clutch was best for my needs.
With the 2.5L powerplant, I don't require something that holds massive amounts of torque, nor do I need a system that would bang off jerky shifts ideal for racing conditions. The FX100 Stage 1 Organic clutch fits the bill, offering me increased pedal feel and weight, clutch life, and an increased holding capacity of 70%, (should I ever feel the need to produce that much). Speaking at length with Rob from Bimmerworld.com was an immense help in making this decision.
With the new clutch surface, a new flywheel was in order, and I decided on the 10lb JB Racing flywheel for E46 non-M. This clutch and flywheel combination weighs about as much as the OEM BMW flywheel alone, and this drastically changed the driving experience for the better. Rob assured me that I would retain excellent drivability for my daily commute, yet have the sporty feel I was looking for.
Having followed the 500 mile break in period, I could properly assess the changes this made to my car. While the RPM's may not climb much faster, they sure drop more quickly, allowing for quicker shifting and very smooth re-engagement with the drivetrain during spirited driving.
Here are the respective weights for each of the old and new units:
(See Thumbnail Pics below)
OEM Clutch- 12lbs
OEM Flywheel- 23lbs
FX100- 14lbs
JB Racing Flywheel- 10lbs
After 1500 miles on the new setup, my car has come to life again. Shifting is crisp and sporty, a huge improvement over my worn stock unit. These benefits far outweigh the only negative I have found to date: the increased flywheel chatter. During 97% of downtown driving, I never hear the flywheel chatter and really forget it is there until I enter a parking garage or enclosed area, and sit at idle. While moving, there is slightly increased transmission noise below 2000rpm, but with the addition of a sporty exhaust system, this additional noise is even less noticeable.
A special thanks must go to Rob and James at Bimmerworld.com for their mechanical expertise! Superb customer service and quick delivery in time for my scheduled install at a local shop helped make this a very positive experience.
ID:	294386   Click image for larger version
ID:	294387   Click image for larger version
ID:	294388   Click image for larger version
ID:	294390   Click image for larger version
ID:	294391   Click image for larger version
ID:	294392   Click image for larger version
-Brendan
Old 12-05-2008, 03:59 PM   #2
Custom3
My Ride: HellRot 330CI
Great review!
i wonder if this would be a better option then UUC flywheel and the M5 clutch
Old 12-05-2008, 04:18 PM   #3
TKC
My Ride: 330cic & R6
Send a message via AIM to TKC
Price? (parts and labor, please)
EUROPROJEKTZ - Director, NorCal Chapter
TKC is offline   Reply With Quote
Old 12-05-2008, 06:25 PM   #4
simsima325
simsima325's Avatar
www.bimmerworld.com/ for pricing details. Price will vary a bit, model to model. I paid ~400 for installation at a local shop
-Brendan
Old 12-05-2008, 11:22 PM   #5
jeffro3000
My Ride: 2000 328i
Originally Posted by Custom3 View Post
Great review!
the M5 clutch is heavy.
jeffro3000 is online now   Reply With Quote
Old 12-06-2008, 03:50 AM   #6
330i ZHP
330i ZHP's Avatar
My Ride: have 5 doors and FI
jb racing flywheel and clutchmasters stage iii clutch....engagement great, grip good, but DAMN the trans rattles and when its cold the clutch (kevlar) makes a screaching noise when slipping the clutch (first gear or reverse on a hill) or downshifting (mostly into third) from 6th or 5th
otherwise happy with rpm drops (and I have the other duplicate engine/trans to compare) and the grip
/_________\
O==[][]==O
Old 12-06-2008, 03:57 AM   #7
simsima325
simsima325's Avatar
^ i haven't experienced any of the screeching your car shows, but I am running an organic clutch, to your kevlar.
-Brendan
Old 12-06-2008, 01:05 PM   #8
323power
323power's Avatar
My Ride: '11 335i
I drove simsima's car, and now I want the same setup Definitely a worth while upgrade if your clutch is bad.
Jeff
323power is offline   Reply With Quote
Old 12-06-2008, 07:00 PM   #9
BMW_Matt
My Ride: 135
Nice review, Brendan...
BMW_Matt is offline   Reply With Quote
Old 12-07-2008, 11:32 AM   #10
zeppelin4
My Ride: 328ci
what happens if you dont allow for the 500 mile break in period
zeppelin4 is offline   Reply With Quote
Old 12-07-2008, 12:30 PM   #11
simsima325
simsima325's Avatar
For break in i just kept it under 4k RPM and avoided full throttle.
I guess if you did not follow break in, the clutch surface could be scarred, and this would hamper its longevity/performance down the road.
-Brendan
Old 12-07-2008, 06:54 PM   #12
zeppelin4
My Ride: 328ci
i changed my tranny fluid recently after having a sport clutch and lightweight flywheel installed to reduce that flywheel rattle but ever since then my shifts havent been as smooth im just hoping i didnt mess up my clutch and flywheel cause i didnt wait exactly 500 miles...more like 400
Old 12-08-2008, 11:43 AM   #13
hummer
My Ride: 2001 330CI
That's because you didn't make the mistake he did by buying way more clutch than he needed. Racing gear on street cars can have negative results!
Old 12-08-2008, 12:12 PM   #14
simsima325
simsima325's Avatar
He is going big power. Prob needs the holding capacity.
-Brendan
Old 12-08-2008, 12:34 PM   #15
330i ZHP
330i ZHP's Avatar
hey hummer - my car will potentially be breaking the 500hp mark when its all over at the flywheel. it is already at 364 at the rear wheels and i havent gone to stage III yet or the other things...
/_________\
O==[][]==O
Old 12-09-2008, 03:00 PM   #16
JamesClay
My Ride: Any BMW with 4wheels
It isn't a strict mileage thing - it is really a matter of transfering the disc material onto the friction surfaces. I can do it in an hour at the racetrack, but that is a lot of shifting and I am very aware of what the goal is and I use my clutch pedal accordingly. By the same token, 400 miles on interstate will not at all break it in...
Worth the effort to make sure it is done properly. Even more so with Kevlar.
James Clay
Race Proven Performance
www.bimmerworld.com
www.bimmerworldracing.com
Bimmer World
JamesClay is offline   Reply With Quote
Old 12-23-2008, 05:18 PM   #17
rcryder
My Ride: 2003 325i sports pkg
I have the uuc stage II moderate lightweight steel flywheel with the m5 clutch, while the clutch is heavier than the stock clutch the flywheel makes it so it is still much lighter than the stock combo, I have some chatter at idle which is louder when you put on the AC. I used a combo of two different redline trans fluids to help out with this and the sprung hub design of the clutch helps too. Overall I love my setup, my car (325i) accelerates so much quicker, smoother downshifts because its easier to match revs, the clutch peddle is obviously stiffer but you don't notice it after about a week
I chose the steel lightweight instead of the aluminum lightweight because my car is purely a street car right now and I wanted to have the quietest and most comfortable yet sporty set up I could, and damn is it sporty.
- Shark Injector - Dinan Intake - Highline Exhaust - UUC Stg. 2 LTW Flywheel - M5 Clutch - H&R - Miro CSL - M-Tech II Front - M3 Lip -
rcryder is offline   Reply With Quote
Old 12-24-2008, 09:45 AM   #18
Tater49
My Ride: 04' G35 Coupe
Does anyone have or know how the Stage II performs. Do I even need a Stage II because I'm trying to go for a little N/A build with around 250 to the wheels. Do I get the Stage II or stick to the Stage I?
2000 328i 5 Spd Black on Black SOLD!
2004 G35 Coupe 6 Spd Gray on Black Current
Daily
FS. JB Racing Lightweight Flywheel (Non-M 6 Speed ONLY) - $450 obo
FS. Spec Stage 3 Clutch Kit (Non-M 6 Speed ONLY) - $400 obo
Tater49 is offline   Reply With Quote
Old 12-24-2008, 11:02 AM   #19
simsima325
simsima325's Avatar
According to the Clutchmasters website, both the FX100 and 200 have an increased holding capacity of 70%.
-Brendan
Old 12-31-2008, 02:07 PM   #20
JohnBlaze
My Ride: Black Sunshine
Good review
05 ZHP w/Epic tuned s54, Euro headers&Sect.1, Dinan 3.91 and a lot of other things built by Road Race Technologies
JohnBlaze is offline   Reply With Quote
