Old 02-03-2009, 11:49 AM   #21
winston330xi
My Ride: 2001 bmw 330xi
Thanks, i left it overnight and the tank is still full today. I checked with my peake scanner and no codes came up. I drove it to see it would help and temp stayed in the middle and the heater worked great. When I got home let it cool down and checked coolant, it was still full and dash light still on.
winston330xi is offline   Reply With Quote
Old 02-03-2009, 07:44 PM   #22
Paul180
My Ride: 2003 330ci
The level sensor is easily damaged, so it may be possible that it got broken at some point. My guess is that the sensor isn't functioning properly since your level is good. If all else fails, replace the level sensor.
Paul180 is offline   Reply With Quote
Old 02-03-2009, 09:29 PM   #23
adiazrael
My Ride: BMW 325i E46
Is it necessary to remove the coolant from the engine block coolant in order to replace the expansion tank only??
adiazrael is offline   Reply With Quote
Old 02-04-2009, 08:57 PM   #24
Paul180
My Ride: 2003 330ci
It is not necessary to drain the engine block if you are replacing the expansion tank. However, since you have to mix up coolant to add for the draining of the expansion tank and radiator, you might as well drain the block as well and change it all, but you don't have to.
Old 02-06-2009, 12:23 PM   #25
adiazrael
Thanks Paul!
Old 02-15-2009, 09:57 PM   #26
2003bmw330iLA
My Ride: 2003 BMW 330i
I just did the Expansion Tank myself. The new tank comes with the level sensor, plug it in and fill tank, the level sensor on dash should go off.
That's what the level senor do and nothing else. I had the sensor disconnected and fill the tank just to test if the dash sensor light stays on while it is not connected. So the dash level light stays on while it is disconnected. You may have a short on the sensor wires or it broke somewhere, do a circuit test on the sensor wiring. DIY weekender.
2003bmw330iLA is offline   Reply With Quote
Old 02-15-2009, 10:07 PM   #27
2003bmw330iLA
I replaced all the hoses, E Tank, sensors....etc. My problem is the temperature gauge goes into red very quickly as soon as I drive it around the block, and stays there. I think my themostat is stuck, since I felt both the before (lower) and after (upper) hoses on the Themostat housing is blowing up with pressure. I think my problem is the wiring on the Thermostat housing, but not sure, anyone knows anything on that???
Someone said something about the themostat open/close is controlled by the wiring on top of the Thermostat housing...can't confirm if that's true.... Thanks!
Old 02-16-2009, 01:07 PM   #28
Paul180
My Ride: 2003 330ci
I'd first check to make sure that you don't have any air trapped in your coolant system by rebleeding it (directions in DIY). It is possible that your thermostat failed, but highly unlikely unless you broke something along the way. My advice is to rebleed, if that fails, replace the thermostat since it's going to need replacing eventually anyways.
Old 02-16-2009, 04:29 PM   #29
stigz
My Ride: 2002 325xi
So what's the trick to the expansion tank? How stuck have yours been? I'm trying to replace mine but it won't budge.
2002 325xi - koni adjustables all around - Kosei R1's all around - double din pioneer f700bt
stigz is offline   Reply With Quote
Old 02-16-2009, 09:25 PM   #30
mujjuman
My Ride: not an E46
nice! just the thing i was looking for... along with a few other DIYs.
This would probably be too hard for me, but I'll give it a shot in a few months
mujjuman
2003 325xi 5MT
Jet Black, ZSP, ZPP, ZCW, OEM Xenon ^^RIP
sig by Solidjake
mujjuman is offline   Reply With Quote
Old 02-17-2009, 10:27 AM   #31
mdva
My Ride: E39, E90, E30
Did mine last week. After struggling with mine for about 30 minutes with it, I tried the floor jack and hammer handle method. Popped off like a champ.
This thread helped me out: http://forum.e46fanatics.com/showthread.php?t=208898
Current: 1991 325ic, 2003 530i, 2008 335i
Retired: 1986 325e, 1991 318i, 1998 528i, 2002 325xiT, 2005 325xiT
mdva is offline   Reply With Quote
Old 02-25-2009, 03:48 PM   #32
mattcarle21
My Ride: is Breakin My Wallet
Just finished doing mine. Took about 5 hours. Great write up! A couple things to note.
1) The lower hose was a huge pain in the a$$. I found that if you cut the hose off with a knife at the end with the temp sensor, it is much easier to then get under the car and pull and pry it off with plyers. This saved some busted knuckles and time.
2) You dont need to take the dust cover off the tensioner on the passenger side of the car. This one is for the a/c and can be left alone.
All in all great write up and it was well worth it
mattcarle21 is offline   Reply With Quote
Old 02-26-2009, 07:50 PM   #33
schnejerator
My Ride: 01 325i black bomb
AT owners watch that transmission thermostat when beating on things... It mates with the bottom of the expansion tank. I'm patiently awaiting a new one (yawn).
i'm pretty sure i promised a boat and a diamond before another bike...
liar!
KTHXBYE
schnejerator is offline   Reply With Quote
Old 03-12-2009, 11:15 AM   #34
EurosportAMG
My Ride: bm mb
great diy writeup
EurosportAMG is offline   Reply With Quote
Old 03-12-2009, 06:45 PM   #35
slysloth
My Ride: 2000 328i
did mine about a month ago and ran into an internal thermostat between the radiator and the expansion tank that was no good and did not come with the tischer kit so had to wait 3 more days to finally get it all done
slysloth is offline   Reply With Quote
Old 04-08-2009, 11:25 AM   #36
kataE46
My Ride: 2001 E46
Need Help!!!! I was on my way to replace my cooling system and have the DIY for it. I was wondering if anybody had the same issue that I am having right now. Here are the pics:
Notice the difference of picture 1 to picture 2.
I borrowed this pic from the DIY page just for comparison.
It might be because of a different model but mine only had one drain plug. I need to replace the expansion tank but it seems to be connected to this aluminum looking part. I really need some good advice on this one before I can proceed. Thanks
kataE46 is offline   Reply With Quote
Old 04-08-2009, 11:32 AM   #37
supratter
My Ride: 2001 330i
the aluminum part I believe it's the cooler for the automatic transmission and I think it's connected to the radiator not the tank, I don't remember doing anything to it when I replaced mine, it's a pretty straight forward process, just remove the bottom clamp that holds the tank, temp sensor, top clamps and it should come right off
supratter is offline   Reply With Quote
Old 04-08-2009, 12:25 PM   #38
kataE46
My Ride: 2001 E46
You are correct, I grabbed the new expansion tank and noticed that it has nothing to do with it. I just got worried for a minute when I did not see a second drain plug. Thanks again.
Old 04-13-2009, 08:48 PM   #39
kataE46
My Ride: 2001 E46
finally
Old 04-14-2009, 09:32 AM   #40
supratter
My Ride: 2001 330i
great !
