Old 01-27-2010, 07:24 PM   #61
moose82
My Ride: 04 ZHP
Great write-up! I did this on Saturday and didn't run into any problems. The lower radiator hose took about 10 minutes to get off, but aside from that, very simple DIY. It's been a few days and no issues so far after ~100 miles and plenty of stop and go traffic.
Thanks for putting this together. Between this and the manual, it was a breeze.
Chip
moose82 is offline   Reply With Quote
Old 01-29-2010, 10:14 AM   #62
01-ADANA
My Ride: 2002 325i
Great work Chip!!
Chip
2002 325I
01-ADANA is offline   Reply With Quote
Old 03-03-2010, 02:03 PM   #63
bimmer4life88
My Ride: '01 330ci
Hey guys, my water pump just went. Do I still need to remove everything outlined in this DIY if I just want to replace the water pump?
Thanks!
bimmer4life88 is offline   Reply With Quote
Old 03-03-2010, 02:05 PM   #64
bimmer4life88
My Ride: '01 330ci
Hey guys, my water pump just went. Do I have to remove everything outlined in this DIY to replace just the pump?
Thanks!
Old 03-03-2010, 04:33 PM   #65
mujjuman
My Ride: not an E46
Thanks!
you just need to remove the belt and the water pump pulley and the water pump itself.
i have never done this, so i could be wrong
mujjuman
2003 325xi 5MT
Jet Black, ZSP, ZPP, ZCW, OEM Xenon ^^RIP
sig by Solidjake
mujjuman is offline   Reply With Quote
Old 03-13-2010, 05:44 PM   #66
allthem
My Ride: 2001 325xi
Thanks for the great write-up! I did this project today and everything went very well. Since i was at 129000 miles i would say it was way over do for this car, it still had the original expansion tank, and who knows what else was original. It even had regular antifreeze in it. I feel so much better now that this is done.
allthem is offline   Reply With Quote
Old 07-09-2010, 12:25 PM   #67
sooper
My Ride: '99 323i
This is a great write up. Im bumping this old thread coz I replaced the upper hose after it exploded. There was a big rip right across the upper hose. Good thing it happened near my house and I made it safely to my garage. I got the part from the dealer since I didnt want to tow the car anymore. I looked at the part and figured it was an easy job till I tried. getting the hose off the radiator side of the hose was a PITA and i didnt want to damage the radiator fitting. Finally I got it off. Not a bigger pain, getting the hose on. How do I slide the hose into the radiator? There is just no leverage to squeeze it in. Any advise?
sooper is offline   Reply With Quote
Old 07-09-2010, 02:02 PM   #68
Sixracer
My Ride: '01 325xiT, '85 M635
You jsut have to keep working in on slowly, might take 15 mins just wiggling it. Also, make sure you put some coolant on the inside of the hose and on the radiator to lubricate it so it slides one easier.
...................2001 325Xi Touring..................1985 M635Csi..................
Sixracer is offline   Reply With Quote
Old 07-10-2010, 05:59 AM   #69
sooper
My Ride: '99 323i
Thanks for the reply sixracer. I just cant help but noticing that handsome 6 series in your sig. It's one of my favorite classic cars. I collect classics and im having an eye for that one. Nice!
Well, my friend mechanic who does my car in my garage called in sick today and cant make it over the weekend. This means I'll have to give the darn hose a shot.
Old 09-25-2010, 10:54 PM   #70
davect325
My Ride: 2001 325i
Paul,
Excellent writeup, worked perfectly on my 325i, took a little over 5 hours. Only trouble I had was my own fault, as I didn't get a new temperature sensor. When I put everything back together, that was my only leak. Got lucky though, partially drained the system, cleaned the sensor and reset it, no leaks.
Dave
davect325 is offline   Reply With Quote
Old 11-26-2010, 03:05 PM   #71
Twrench
My Ride: BMW 330i
Wow!. I am new to this group and what a write-up with pics. Awesome!!
I wish I had this when I sprung a leak on my cooling system. Had to change out the expansion tank and the upper radiator hose. Could not pull the lower one off and since it was not leaking left it alone. Did not change out the waterpump etc as did not have this write-up. Will get to that later. Thanks for the link to the OEM parts. I paid nearly 3/4 of the price of the Tischer kit and just got the hoses and the expansion tank.
One method that I found helpful and one which I used - found it on the net - to pull the expansion tank out was...prop a hammer/or some other solid piece of metal (like a metal rod, pipe etc) onto a jack. Use a small piece of wood on the jack side and push the other end of the hammer/piece of metal on to the expansion tank. Raise the jack and the expansion tank will come off with relative ease.
Twrench is offline   Reply With Quote
Old 11-28-2010, 11:16 PM   #72
JWade
My Ride: 2001 330CI
Just did my expansion tank and upper radiator hose this weekend. Great write-up! Thanks!
FYI, found an expansion tank online for under $40 ...
Yes, I had to tap the expansion tank from below as well to get it to break loose.
2001 BMW 330CI sport, 5 speed manual
2010 Chevrolet Equinox LT
JWade is offline   Reply With Quote
Old 03-13-2011, 05:40 PM   #73
tommytoyz
My Ride: 1999 e46 323i
I just changed out my expansion tank and I have a few observations, as I did it differently than instructed to here and I could not have done it any other way, I think. I took out the old expansion tank with the assembly it attaches to together. This was easy as pie. No hammering or pushing or anything. Though You do then have to unclip and disconnect the bottom hose as well ( don't know the name).
Then, I saw where the hard part was. With the old tank out, I ubclipped the bottom of the tank from the assembly and I could then slowly pry out the old assembly with a bit of force and a sturdy screwdriver. Viola. It would have been almost impossible to do this separation while the assembly was in the car.
Then I had to mate the new tank with the old assembly. Mere pushing with body weight is not enough. I was stumped into how I was going to mate them, as they were not wanting to. I reexamined the pieces to see if perhaps they didn't fit or something.
Then I got an idea that made it simple. I was able to mate the two by laying everything sideways on the ground and using my hydraulic car jack, also on its side, to slowly force the assembly into the new tank. No banging or grunting.
I did see how tough it was to mate the two and again, I can not even imagine trying this with the assembly in the car. Besides this unmating/mating issue, the next hardest thing is unclipping and clipping the lowest and 3rd hose as there is very little room, but not altogether that hard.
So if you can remove the assembly with the tank and then deal with the assembly once outside of the car, I think it will be much much easier. Also try to use some tool to squeeze the assembly together again. At first I tried placing everything in a door jamb, and that almost worked but the door jamb was a little too wide.
My assembly just unhooked from the radiator mountings and looked slightly damaged. I think whoever replaced the tank previously may have done this damage, making it easier to remove the assembly, but I am not certain.
tommytoyz is offline   Reply With Quote
Old 03-21-2011, 08:05 AM   #74
LeMansteve
My Ride: '04 330i 6mt ZSP ZPP
OP - great write up. Thanks!
I did basically a complete cooling system overhaul this weekend with a good friend (@ 85k). Everything went very smoothly, though we did get coolant EVERYWHERE. Once you think you've drained it all, you disconnect another hose and realize how wrong you were! Thankfully the stuff we drained was still nice and blue. A few notes:
1. I personally LOVE the BMW design of the spring clip hose connections. Very controlled, simple and precise. It allowed me to remove and install the rear engine block hose without being able to see it.
2. I consider myself lucky that removing and installing the expansion tank was much easier than expected. It pried off the lower mount fairly easily with a flathead and the new one slid right on. Lower radiator hose too.
3. We did not have a short enough torx socket to remove the screw from the top of the bracket. Tight clearance between the screw head and my headlight assembly.
4. Removing the engine block drain plug is definitely very messy! Somehow my friend fit his breaker bar in there at an angle to get it off. We tried to put tubing in there to control the mess, but it just didn't work
5. I filled the system with just under 8Q of 50/50 after it was all said and done. The manual calls for 8.8Q (<- lol looks like BBQ). Since the car was on ramps, my guess is there was about 0.8Q sitting in the back of the block that hadn't drained.
6. I went with a remanufactured OEM pump instead of the Stewart pump. I don't subscribe to the theory that the Stewart pump is better "because the impeller is metal".
7. I don't like plastic drain plugs and bleeder screws. Though we did not strip them, I was very nervous tightening them.
Thanks to ECS Tuning for having a great selection of OEM cooling system parts. Here is what I replaced:
thermostat (started to stick open @ approx 75k)
water pump
coolant temp sensor
expansion tank with new cap, coolant level sensor (old one was metal, new one is blue plastic) and lower spring clip
BMW coolant + distilled water
accessory drive belts
hoses replaced:
1. lower radiator
2. upper radiator/expansion tank
3. rear engine block to heater core "valve"
4. intake-side of engine block to expansion tank
5. heater core to expansion tank
Old 03-21-2011, 08:52 AM   #75
AUSS1E
My Ride: a Gulfstream
Thanks for the info.
I also struggled with the bottom hose for a while and finally decided to use a pry bar.
Just rest it on the edge of the radiator (The solid end part) and pry the engine side of the hose. Popped right off.
2004 330i ZHP
AUSS1E is offline   Reply With Quote
Old 05-21-2011, 12:24 AM   #76
BMWMac
My Ride: 325i
I was forced to undertake this complete cooling system overhaul after my expansion tank exploded last week. My parts just came in and so I started taking everything apart. That is when I discovered the situation was must worse than I had thought. When the expansion tank exploded, pieces of it must have hit the radiator fan because one of the fan blades was completely broken off and another one was cracked (by the way, fan came off easily with a cresent wrench and hammer strike technique). So I ran to the dealership today and paid $65 for a new fan. Tonight I got back to taking off parts. When I pulled the expansion tank off, I noticed a small part was broken where the expansion tank connects at the bottom. The part had a number on and I was able to determine it was the expansion tank thermostat. I don't want to wait to have one shipped so I will have to call and see if the dealership has the part. The list price is over $90 for that stupid little part. I also just discovered that the coolant level sensor was damaged in the explosion and I hadn't ordered that part either.
So my question to the forum is what other parts of the cooling system were possibly damaged in the expansion tank explosion? What else should I check out before I start putting everything back together? Thanks.
BMWMac is offline   Reply With Quote
Old 03-23-2012, 11:42 AM   #77
mjn77
My Ride: 330D Sport
Is the DIY the same for a 330 Diesel?
2004 330D Sport in Estoril Blue
mjn77 is offline   Reply With Quote
Old 11-15-2012, 01:57 PM   #78
jimbob55
My Ride: 323ci
I have 89000 on my 2000 323ci and am replacing cooling system. I am trying to replace heater hoses also. is this recommended. If so, how do I remove the one hose from rear of engine?
jimbob55 is offline   Reply With Quote
Old 04-10-2013, 03:51 PM   #79
4g63GSX
My Ride: 07 RRS 03 325 94 GSX
If I'm NOT doing the water pump (only upper/lower hoses, T-stat, sensor, and ET) do I need to take the fan off?
4g63GSX is offline   Reply With Quote
Old 04-10-2013, 04:26 PM   #80
Chris3Duke
It might be possible, but I wouldn't count on doing it with the fan.
Remember, if you have a manual, the fan is a cinch.
Chris3Duke is offline   Reply With Quote
