Old 05-15-2002, 04:51 PM   #1
rx5477330ci
My Ride: 2002 330ci
Had ssk installed and it vibrates
Had re ssk insltalled and it vibrates. not alot. not noticeable and it makes no noise. I can tell when iam shifting is this normal? What can I do if anything
thanks
rx5477330ci is offline   Reply With Quote
Old 05-15-2002, 05:02 PM   #2
jestr
is bester
My Ride: '02 Steel Grey 325i
Did you get the cartridge bearing upgrade and delrin carrier bushings?? Those will give you a more snug fit and smoother shifting. You also might want to check and see if everything is on and tight. Otherwise, It shouldnt vibrate at all.
jestr is offline   Reply With Quote
Old 05-15-2002, 05:13 PM   #3
rx5477330ci
My Ride: 2002 330ci
Does the re ssk come with those upgrades. Should go back toi the shop to mak everythid is tight
Old 05-15-2002, 05:17 PM   #4
jestr
is bester
Oh sorry, I didnt see that you had the RE installed, my comment was for the UUC.
But I checked RE's website, your kit should include
  • Short shifter lever specific for this vehicle
  • External vibration dampening collar
  • New clips, washers, and pivot cup
  • Replacement shifter carrier with Pivot Relocation Cup
  • Delrin shifter carrier bushings
hmm... have you tried contacting RE ?
Telephone #: 201.444.8150 M-F 9AM-5PM EST
Email: tech@rogueengineering.com
Old 05-15-2002, 06:15 PM   #5
Rob Levinson * UUC Motorwerks
Rob Levinson * UUC Motorwerks's Avatar
My Ride: 7s, M5s, M3s, others
Re: Had ssk installed and it vibrates
thanks
Well, even though you didn't get the UUC Ultimate Short Shifter, I think I can still help.
Things to check:
1) common shift boot leather vibration at top - lift up your shift boot, wrap a zip tie around the exposed flap. We see this happen even in original shifter-equipped cars.
2) check the installation of the SSK - under the leather boot is a rubber boot that is a heat and noise isolator. It is supposed to be tucked through the large hole in the floorpan. If it is not tucked in properly, you can hear noises from under the car.
3) check your shift knob itself, make sure it is seated properly. Some illuminated or wood knobs can vibrate after initial removal, but that tends to settle back down.
Please feel free to call us at UUC (732-398-0001) to troubleshoot other possibilities.
- Rob
- Rob Levinson
- Rob Levinson * UUC Motorwerks * 678-679-5360 * uucmotorwerks.com
BIG BRAKE KIT HEADQUARTERS!
ALL CURRENT UUC SPECIALS:
-[ CLICK HERE ]
Rob Levinson * UUC Motorwerks is offline   Reply With Quote
