Old 12-07-2008, 01:57 AM   #1
TKC
My Ride: 330cic & R6
Send a message via AIM to TKC
DIY: Made non-folding, OEM M3 mirrors auto fold. WARNING: LOTS OF PICS!
A brief background:
I had the chance to pick up a set of OEM M3 mirrors for a great deal, so I bought them. Unfortunately, these OEM M3 mirrors did not autofold, a feature that I really liked about my replicas.
Well it just so happened that I had an extra set of replicas lying around that I bought because the glass on one of my mirrors was broken when I bought it.
So what I did was swap out the internals from the replicas to the OEM. Here's how.
Getting started:
Remove the foam liner:
Go to the plug.....
Lift the tab out...
And slide the wires out of the casing.
Make note of these set of wires, as this is the side the 2 wires that add the autofold will connect to:
Remove the glass by Tilting the mirror all the way up, look inside along the bottom. You'll find a little prong you can slide a thin screwdriver into. Slide it in and push to the right to unlock the ring holding the mirror in....
Once off, pull off the 2 wires that are for the heated mirror function:
Undo the 3 screws holding the glass mount and remove it:
Unplug it and remove it
Undo the 5 screws holding the base inside the housing:
Once it's removed, there's one last screw holding the folding arm in place. Remove it as well:
In the base, you'll find 2 screws holding the folding arm to the base. Remove them.
You'll find 4 screws holding the arm mount to the arm. Remove them:
On the top of the elbow, LOOSEN, but don't remove the 3 screws that hold the arm to the elbow.
Ok, here's the space mirror I had lying around. Basically, repeat all the above steps for this mirror as well.
Once you get to the same point you were at with the OEM one, remove those final 3 screws at each elbow and swap that motor from the AUTOFOLDING elbow into the OEM M3 one. This is the mechanism/motor that does the autofolding function. It is accompanied with a Blue and White wire. Thread these 2 wires along with the rest of the wires.
When you start re-installing everything, I suggest using some loctite cause I've experienced mirrors loosening up over time and becoming wobbly.
Notice now, the Blue and White wires now included:
Put things back together in the reverse order you took them apart:
I used the help of a little screwdriver to help thread the new blue and white wires through the rubber grommet.
Ok, so from the old mirror, I cut off the old wire ends that go into the harness. I tapped them to the blue and white wires and plugged them into harness. If you recall from one of the earlier pics that shows the wire order, the colors should go in this sequence:
Green
Black
Grey
Red
White (the new one you just wired in)
Blue (the other new one you just wired in)
(I apologize, but I broke the connector that was on my blue wire, so I used a grey one, so in this picture the last wire isn't the correct color like yours should be) :
The finished product:
Put the mirrors back on the car!!!
A quick video of them in action!
I'll update this with a nice new pic of my car soon!
Hope this was useful, if not for the same purpose I did, at least to help with some mirror questions some may have.
Thanks!
EUROPROJEKTZ - Director, NorCal Chapter
TKC is offline   Reply With Quote
Old 12-07-2008, 02:00 AM   #2
NorCal Einstein
My Ride: E92 335i
Send a message via AIM to NorCal Einstein Send a message via Yahoo to NorCal Einstein
Nice work!
I never knew Kumon taught so much
Current:
2009 E92 335i Alpine White/Coral Red
Past:
2007 E92 335i Sparkling Graphite/Black
2000 E46 323i Steel Blue/Grey
NorCal Einstein is offline   Reply With Quote
Old 12-07-2008, 02:05 AM   #3
-Jay-
My Ride: 06 X3 3.0i
Send a message via AIM to -Jay-
good job Toby
-Jay- is offline   Reply With Quote
Old 12-07-2008, 02:14 AM   #4
FromE55toM5
FromE55toM5's Avatar
My Ride: 6spd E60 ///M5
great jon bro
Previous Whips:
330ci | ///M3 | E55
FromE55toM5 is offline   Reply With Quote
Old 12-07-2008, 02:28 AM   #5
Fatal Flash
My Ride: Kia
props to you man. didn't even know this was possible, and i didnt even think of it! sick sick mod. now wtf do i do with my ribbon connectors!
Fatal Flash is offline   Reply With Quote
Old 12-07-2008, 03:33 AM   #6
dmisc
My Ride: a car
Nice work dude!!!
dmisc is offline   Reply With Quote
Old 12-07-2008, 03:37 AM   #7
sillieidiot
My Ride: '06 AW 330ci
good work
Old 12-07-2008, 10:49 AM   #8
Lou39
My Ride: e46 Coupe
very nice job.
Lou39 is offline   Reply With Quote
Old 12-07-2008, 12:03 PM   #9
ACS Rob
pinoyfanatic
My Ride: This --->
great work toby! oem m3 mirrors are a big improvement look-wise over the rep!
ACS Rob is offline   Reply With Quote
Old 12-07-2008, 10:57 PM   #10
cyberkaa
My Ride: E46 332i,M3;E30 325i
awesome!
-Kalim
(klx photo studio)
Old 12-19-2008, 10:32 AM   #11
Bake
My Ride: AW F10 535 M-Sport
Great DIY. I inquired about this 2 years ago when I had rM3 mirror reps before I sprung for OEM's. Now I wish I didn't sell my reps. I might actually pick up a set of reps again and do this. I really miss the Autofold feature! Props to you for giving it a try.
Bake is offline   Reply With Quote
Old 12-26-2008, 09:08 PM   #12
Alex323Ci
My Ride: M3 & 323Ci (sold)
I see for the 12 pin the two wires for the motor arm go into the 12pin connector. On 6 pin they are seperate. I got all the way to the swap but the china made motors are such crap and noisey. When one side went out I just scrapped the whole thing a few years ago until I picked up some oem folding motors but the folding lost it's novelty for me and I never went back to the project. I think I still have one oem m3 and one autofold china m5 mirror in garage. Good work and write-up. I hope they last much longer than my motors.
Old 02-11-2009, 03:48 PM   #13
KYC
My Ride: 2003 325 xi
wow, I didn't know that you could take a replica's hardware and just swap it on an oem mirror... The car still needs to be prewired with autofold modules to have it work... but that's been addressed in other thread.
Good job
KYC is offline   Reply With Quote
Old 02-11-2009, 03:53 PM   #14
Custom3
My Ride: HellRot 330CI
WTF!!! i thought these replica mirrors were larger because of the parts that make the mirrors fold up....i thought you couldnt fit them on a oem mirrors....wow man...you proved me wrong...thanks for sharing...they look really nice.
Old 02-11-2009, 04:11 PM   #15
TKC
Thanks for the compliments guys! I was happy it worked out cause I like the novelty of the autofold function.
I forgot that I mentioned I'd post an updated picture of the car now that it has the OEM M3 mirrors so here they are. Thanks again!
The difference is the old Replica mirrors are large, bulbus, and sit really high up.
The OEM ones sit lower, follow the line of the car more, are more flat on the bottom, sleeker, etc.
Old replica mirrors (and old a lot of other things):
And now the new mirrors!
Old 02-28-2009, 08:57 PM   #16
adrian320
My Ride: 2002 2.2L I6 Sedan
TKC,
Really good job there. And the quantity and quality of the pics is great.
As a side note, what happend with this earlier thread about your friend:
http://forum.e46fanatics.com/showthread.php?t=59416
No, no, there is no climate change, it just getting hotter and hotter....and hotter. Yeah, right!?!!?
adrian320 is offline   Reply With Quote
Old 02-28-2009, 09:06 PM   #17
TKC
Originally Posted by adrian320 View Post
TKC,
Thanks!
As for Qbz, we haven't had time to mess with his car again since that day. He lives a little far from me, plus with our work schedules, it's been tough to work on it again. For now, he has them bolted on but just doesn't use any motorized functions until we can have a look at it again.
We'll update that post when we work on it again.
Thanks!
Old 05-28-2009, 04:44 PM   #18
jin8544
My Ride: 325xi
I have to have the auto folding feature in order to do this right?
jin8544 is offline   Reply With Quote
Old 06-11-2009, 10:55 PM   #19
showoffcafe
My Ride: 2000 323 CI
where do you buy these replicas?
showoffcafe is offline   Reply With Quote
Old 07-20-2009, 09:02 PM   #20
///Pulo
My Ride: 330CI///M individual
none of ur pics are showing up!
6s MT E46 BMW 330CIC Convertible M-Sport Individual Phoenix Yellow
///Pulo is offline   Reply With Quote
