Old 12-08-2008, 01:09 AM   #1
vlad089
My Ride: 330ci
Supersprint installing question...
Hello!
I have bought the full exhaust for BMW 330ci M54.
During the installation of it I got the problem.
The Superspint exhaust has 6 plases for lambda oxygen sensors - 4 at the manifold (787401) and 2 at the front exhaust (787402). But in the OEM exhaust I have only 4 lambda oxygen sensors.
Could you please tell me, how I must install my lambda oxygen sensors in SS and in which places?
vlad089 is offline   Reply With Quote
Old 12-08-2008, 08:30 AM   #2
bernstem
My Ride: 2000 328i
You only need 4 of the bungs. The other two are just extras. Most people use them for EGT or aftermarket wide band O2 sensors.
Pre-cat O2 sensors go at the bottom of the headers. most people install them in the first set of bungs. Make sure you keep banks 1 and 2 sorted out correctly or the car will have serious performance issues.
Post-cat O2 sensors go after your cats. With the supersprint exhaust (assuming you bought cats), you will need to extend your post-cat O2 sensor wires. If you don't have cats, you can plug them in wherever you want or leave them unplugged. Either way you will have a CEL.
bernstem is offline   Reply With Quote
Old 12-08-2008, 10:24 AM   #3
vlad089
My Ride: 330ci
Thank you for your answer. Now I understand the decision of my problems.
So, now I need to extend the wires. I don't have the additional wires with my exhaust package. Could it be there or no?
And if I extend with the wire like the OEM, but not very same, will I have any problems because it will be different strength of materials?
Old 12-08-2008, 02:16 PM   #4
bernstem
My Ride: 2000 328i
The exhaust does not come with wires. You will need to source your own wires to extend the sensors. I don't know what wires or where to buy them - my shop took care of it for me.
Old 12-08-2008, 11:43 PM   #5
vlad089
My Ride: 330ci
You are lucky man! And your shop is great! =)
That is the problem for me with wires.....
Old 12-09-2008, 01:15 AM   #6
330i ZHP
330i ZHP's Avatar
My Ride: have 5 doors and FI
if you dont have them - you will need to bung plugs (sounds funny) but they are large (about 1in or 2to3cm) bolts with brass ring gaskets - those will need to be screwed TIGHTLY into the two unused holes.
If you use 16 gauge wire and solder it on each end - you will be sufficient in wire size - also try to use shrink tubing at connection points and then further protect with electrical tape. make certain to run the wires AWAY from the headers and exhaust so you dont get burns or damage to the wiring
/_________\
O==[][]==O
Old 12-10-2008, 09:44 AM   #7
bernstem
My Ride: 2000 328i
They are good to me. I think they had some extra o2 wires from another e46 they were working on so they just used those and spliced them in. It seems to work fine and they didn't charge me for the parts since they didn't have to buy anything.
Old 12-11-2008, 04:31 AM   #8
vlad089
My Ride: 330ci
Yes, we did it!!
We extended the wires, than made the diagnostics, and now everything is okay. Thank you guys for your opinion!
Old 02-16-2009, 08:48 AM   #9
tinkwithanr
My Ride: '00 323i + '75 2002
So what do the o2 wires consist of, just two leads? If it just means soddering in a two wire extension for each that's not as bad as I thought it would be.
Tinker Engineering - 2014
Mica - 2000 BMW 323i - The one that started it all
Fiona - 1975 BMW 2002 - The Definition of Project Creep
Heidi - 1988 BMW M5 - The piece of BMW history
Silvia - 2013 Subaru WRX - Stock, for now
tinkwithanr is offline   Reply With Quote
Old 02-25-2009, 09:45 AM   #10
dpgrand
My Ride: 2005 330xi
There is no need to extend the stock wires, you simply just need to unclip the extra wire that is tied up under the plastic engine cover.
'05 330xi - Koni, H&R, Rogue, Supersprint, UUC, Dinan, Apex
dpgrand is offline   Reply With Quote
