Old 12-10-2008, 06:01 PM   #1
nuwde
My Ride: 2001 330Ci
Oxygen Sensor Adaptation Limit
Peake Tool, Table 19, E3 and E4
"Oxygen sensor adaptation limit, Cyl #1-3" and "#4-6"
Is this referring to post-cat or pre-cat? Also, I just changed all 4 oxygen sensors this past summer. Could it be something else?? TIA.
nuwde is offline   Reply With Quote
Old 12-11-2008, 07:02 PM   #2
nuwde
My Ride: 2001 330Ci
Does anyone have info on this? Please help. Thanks!
Old 12-11-2008, 07:20 PM   #3
Den4176
My Ride: BMW 328i,Ls3 2ss
i have the same codes too... they come and go and i also replaced all 4 os sensors i think you might have a bad maf or a intake leak too
Den4176 is offline   Reply With Quote
Old 12-11-2008, 09:38 PM   #4
nuwde
My Ride: 2001 330Ci
is there no fault code for maf? thanks for the info, i'll try to find out how to check my maf.
Old 12-11-2008, 10:07 PM   #5
peanut_man
My Ride: 2008 335i Sport Pkg
Went thru EXACT same experience.
From research and my own experience, I can almost guarantee you it's vacuum leak. Check DISA (adjuster) valve, and intake elbows and various hoses.
While you are at it, you can try the usual maint. items such as cleaning the MAF and chaning the fuel filter.
Good Luck.
peanut_man is offline   Reply With Quote
Old 12-12-2008, 04:28 PM   #6
nuwde
My Ride: 2001 330Ci
Good Luck.
thank you so much peanut man. I've never even heard of DISA valve or intake elbows. are there any diys here?
Old 12-12-2008, 04:41 PM   #7
RaDs330
Banned
My Ride: 02 E46 330
hey im going through the same problem and got the same codes from the peake...
RaDs330 is offline   Reply With Quote
Old 12-12-2008, 04:51 PM   #8
nuwde
My Ride: 2001 330Ci
did a bit more research...try this link...
http://forum.e46fanatics.com/showthr...774&highlight=
Old 12-12-2008, 06:01 PM   #9
RaDs330
Banned
My Ride: 02 E46 330
thanks bro
Old 12-14-2008, 09:39 PM   #10
TG01-330I
My Ride: 01 330I
I had the same codes and found I had a crack in the lower intake boot past the MAF . It has a small additional hose out the side of the boot that looks like an accordion this is a common area for cracks.
TG01-330I is offline   Reply With Quote
Old 12-14-2008, 09:41 PM   #11
Custom3
My Ride: HellRot 330CI
i have the same issue....did many things and still cant find the fix for it
Old 12-14-2008, 09:51 PM   #12
MATT200MPH
Past Site Sponsor
My Ride: E46 328i Sedan
Send a message via AIM to MATT200MPH
-_- im having problems too. it looks like its starting to affect my mpg too. i dropped from 20 city to 17 city... highway is still in the 30s tho.
i dont have access to a peake tool but generic scan always gives me precat 02 sensors(which i changed) and maf sensor 101 code(which i also changed).
i read somewhere recently that a lot of the time its just the dme receiving wrong impulses from the sensors. a reflash would cure the error codes.
MATT200MPH is offline   Reply With Quote
Old 12-15-2008, 06:12 PM   #13
RaDs330
Banned
My Ride: 02 E46 330
what i heard is that it is because the O2 sensors are bad, i got that conclusion from a tech. and i have to change them out, im going to clean the maf sensor as well... my mpg dropped crazy as well... after doing all that im a do a tune up and clean the throttle body and hope that will help
Old 12-17-2008, 03:19 AM   #14
dirsh
Hawaii 3.0
dirsh's Avatar
My Ride: sanbyaku sanjuu
I get the same codes from time to time. I've replaced all the intake hoses. I think it may be a small leak somewhere. I can live with the CEL for now because I don't wanna pay a shop to do a leak test
Hello dirsh it appears that you have not posted on our forums in several weeks, why not take a few moments to ask a question, help provide a solution or just engage in a conversation with another member in any one of our forums?
dirsh is offline   Reply With Quote
Old 12-27-2008, 11:32 AM   #15
reynaldo
My Ride: 2001 325i Sedan
Send a message via Yahoo to reynaldo
I concur. Follow the above recommendation. It is MAF or cracked intake boot.
reynaldo is offline   Reply With Quote
Old 12-27-2008, 11:35 AM   #16
reynaldo
How did you changed all the 4 O2 sensor?
Old 12-30-2008, 07:11 PM   #17
BVSJ
My Ride: 325I
My car had the same code with SES, won't pass smog check.
Replace pre-cat O2 sensor.
Problem solved.
BVSJ is offline   Reply With Quote
Old 01-21-2009, 08:28 PM   #18
nuwde
My Ride: 2001 330Ci
got a link/pic of exactly what to check? Thanks!
Old 01-21-2009, 08:30 PM   #19
nuwde
My Ride: 2001 330Ci
The pre-cat O2 sensors are easy to change out. The post-cat O2 sensors suck!
I'm sure there is a DIY on this somewhere. Let me know if you need a link!
Old 01-21-2009, 11:14 PM   #20
Steve@ASPTuning
ASPTuning
My Ride: 01' 320i
Could be your idler control assembly that has a leak in it.
Mine did... and it threw off all kinds of codes including the one your mentioning.
I also replaced my intake boot for no reason assuming it was that but my OEM intake boot was clean and no cracks.
Steve
ASPTuning
Steve@ASPTuning is offline   Reply With Quote
